Old 11-16-2012, 08:28 AM   #1
cole70
Member#: 334033
2013 Impreza SP
Default Issues starting in cold weather
I have had my 2013 Impreza Sport Premium with CVT for 4 wks now. Recently the temps have gotten into the teens/twenties at night. My Impreza is kept in the garage. I have found it hard to start in the morning. The dash lights up but the car will not turn over. I turn the key back, wait a few secs and try again and it will turn over but rather reluctantly. It rough idles after start up too. I do not have my foot any where near the gas pedal. There is a strong smell of exhaust at idle too at this time. There is a bit of an incline in the garage so the nose of the car is a bit higher than the rest. Also I did finally have to fill up the tank right before this started happening.
Anyone else experience this? Anyone have a clue as to what this could be?
cole70 is offline   Reply With Quote
Old 11-16-2012, 10:06 AM   #2
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Did you "top off" when the last fill was accomplished? If so, that is a "no no". Fill until the first click and then stop - adding a few more cents worth of gas would be OK; however, don't fill it up completely.
G-Omaha is offline   Reply With Quote
Old 11-16-2012, 10:19 AM   #3
cole70
Member#: 334033
2013 Impreza SP
Nope, did not "top off" when I filled the tank. In fact I stopped it just short trying to get a rounded dollar amt. :-)
Old 11-16-2012, 10:32 AM   #4
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Happened to me too a while ago. The engine didnt want to turn over. Eventually did but scared me.
Also a little off topic, after filling my tank i turned on the car and still displayed an empty tank and then after 30 seconds slowly returned to full.
these only happened once so far so hopefully nothing
Old 11-16-2012, 10:39 AM   #5
cs1986
Member#: 314334
2012 Impreza 2.0i
Try turning the key to ON for a few seconds and let the fuel pump do its thing. and start the car.
Also make sure you did turn the key all the way to the start position.
If that doesn't help I'd bring it back to the dealer.
I've started my engine cold in 0f weather without issue, except it cranks and little slower but that's expected.
cs1986 is offline   Reply With Quote
Old 11-16-2012, 10:45 AM   #6
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
By not turn over, you mean the starter doesn't engage?
Commander Keen is offline   Reply With Quote
Old 11-16-2012, 11:38 AM   #7
Zeeper
Member#: 299286
2015 WRX CVT
Take it to the dealer, it should start in the cold every time, it is a new car (and your issue is not normal).
Zeeper is online now   Reply With Quote
Old 11-16-2012, 12:29 PM   #8
WStrembitsky
Member#: 323877
2012 Impreza Limited
I agree with Zeeper, it hit -17C in Edmonton a week ago and I had no issues starting my car.
WStrembitsky is offline   Reply With Quote
Old 11-16-2012, 01:09 PM   #9
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
So many variables
1 hold key and let instrument lights turn on for few seconds that way fuel pump starts and car turns over Easily
2 rough idle in winter normal for subie and for pzev
3 the toaster of a bat might be on its way out or not enough cca
Bring it to stealership if they say nothing's wrong have them test bat and also record the fact that you had this issue. Force them to check starter as well Bring a pair of headphones to past the time
aeoporta is offline   Reply With Quote
Old 11-16-2012, 01:18 PM   #10
Commander Keen
Member#: 319157
If you mean the engine turns over (starter engages) but has trouble firing, I'd give it some time.
Many ECUs will refine their starting parameters over time for different conditions. If this is the first time your car has ever started in these temperatures, it may still be learning. Don't be afraid to crank it for 5-10 seconds.
I had some extended cranking times at first, but they're very short now.
Old 01-23-2016, 11:45 AM   #11
m_anderson_33
Member#: 311621
2016 STI
I'm having the same issues with my '16 sti and the nearest dealer to me is 80 miles away where the temps arent near as cold as here, so they cant do anything about the problem. Mine takes 2 or 3 minutes sometimes in 10 degree weather to get it started
m_anderson_33 is offline   Reply With Quote
Old 01-23-2016, 11:59 AM   #12
drpoop
Member#: 421858
Your cars come with 390CCA batteries. It's a wonder they start when it's below 95 degrees out. Buy new batteries.
drpoop is offline   Reply With Quote
Old 01-26-2016, 09:34 PM   #13
mKTank
Member#: 428932
Huh. My car started just fine a few weeks back when we had -35C in Winterpeg...
Don't know what to tell you OP. Maybe let the dealership do some inspection?
mKTank is offline   Reply With Quote
Old 01-28-2016, 07:49 PM   #14
Kottosen
Member#: 431290
2013 impreza
I remember hearing there is a problem with the camshaft positioning sensor that causes this...i could be wrong
Kottosen is offline   Reply With Quote
Old 01-28-2016, 08:00 PM   #15
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
This is a correct possibility. I believe there's a technical bulletin for this where the technician shims the sensor(s) to adjust their alignment.
Having said that, my car experienced this symptom on occasion, but very infrequently (like maybe 3x/year). However, I replaced my OEM battery a little over a year ago, and haven't experienced the hard starts since.
This is the battery I installed:
https://www.pepboys.com/product/deta...02.0L%2520DOHC
sgoldste01 is offline   Reply With Quote
