Old 11-16-2012, 11:03 AM   #1
gerardt20
Member#: 329086
2002 impreza obs
white
Default bucking when wheels turned all the way to the left or right
when i turn the wheel all the way to the left or the right it starts to buck and shake the whole car. what could this be?
gerardt20 is offline   Reply With Quote
Old 11-16-2012, 01:03 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
In motion? Or sitting still? Engine running, I assume?
Old 11-16-2012, 01:50 PM   #3
HonduhPowa
Member#: 269076
2012 Wrx
Could be a bad diff
HonduhPowa is offline   Reply With Quote
Old 11-17-2012, 01:57 PM   #4
aod12
Member#: 282701
2008 FXT
I'd check the power steering
aod12 is offline   Reply With Quote
Old 11-17-2012, 02:04 PM   #5
medfordhotrodguy
Member#: 144379
05 sti R.I.P.
98 Legacy 2.5 GT
Could be center diff solenoid. I've seen it a lot lately at the shop. The car gets stuck 4wd locked up and not letting there be a speed difference.
medfordhotrodguy is offline   Reply With Quote
Old 11-17-2012, 02:29 PM   #6
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Torque bind.
Is the car an auto or manual
There's a few things that can cause this. First, check and make sure that all tires are the same size/brand/wear. I got my first subaru for free basically because the previous owner put one band new tire on with three old ones. This burned out my duty c solenoid, and can also cause damage to to the center diff. (This was on an auto)
If that looks good, try doing a transmission flush. If that doesn't help, then things are going to get expensive.
ResidentR is offline   Reply With Quote
Old 11-17-2012, 06:15 PM   #7
KelConquer
Member#: 321498
1998 Legacy W. EJ25
Mine does the same, pretty sure since I bought my car almost 2 years ago. I've never really paid much mind to it. I wouldn't be surprised if my diff is off though since I've been running marginally different sized tires in the rear for a while now (passed 2 months). It hasn't gotten worse since I bought it though and it's not often at all that I'm turning that sharply.
I'm not saying you shouldn't look into it if you plan on having the car for a while, though.
(mine is an auto)
KelConquer is offline   Reply With Quote
Old 11-19-2012, 12:30 PM   #8
That guy in Maine
Member#: 256642
Power steering would be the first thing to check, then the more serious differential problem...my PS fluid was low and it caused the car to not turn smoothly at full lock.
That guy in Maine is offline   Reply With Quote
Old 11-19-2012, 08:51 PM   #9
Dr. Octawakaoctapus
Member#: 262003
1994 Legacy
teal
Try ATF flush if automatic first, and if thar doesn't work fix center diff. If manual just gotta replace. But like the others said check tire dizes and even differences in brands.
Dr. Octawakaoctapus is offline   Reply With Quote
Old 11-20-2012, 08:01 PM   #10
Ultra Sonic
Member#: 338462
The center diff is not free. If it's an auto trans then it might be an electrical problem. If it's a manual trans then the fluid in the LSD is 'gummy'. I don't know about '02, but earlier ones were sealed, so changing the trans oil doesn't help....
Ultra Sonic is offline   Reply With Quote
Old 11-26-2012, 04:48 PM   #11
gerardt20
Member#: 329086
2002 impreza obs
white
ok so i meant to check this and reply but yea idk how to even approach this. its a manuel trans forgot to mention that. it only does it sometimes. often yes, but other times like when the car is still cold nothing happens.
Old 12-04-2012, 10:13 AM   #12
Gravy188
Member#: 335911
2006 WRX STI
center diff.
Gravy188 is offline   Reply With Quote
Old 12-04-2012, 02:23 PM   #13
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
^ +1 on Center diff. Mine did the same thing- only after a drive. It isn't too hard to do DIY style. 4 hours or so with little experience. There is a few how to's posted with decent pics if you search a bit.
bugeyetex is offline   Reply With Quote
Old 12-04-2012, 02:36 PM   #14
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
It's definitely a DIY project for anyone who's willing to try. The parts are either $400+ for a new diff assembly or you can chance it an get a used out of a junk car. The latter will give you a chance to pull one apart without the worry of messing anything up so when you do it on your own transmission you will know what to expect.
Old 12-04-2012, 04:12 PM   #15
giosoccer20
Member#: 328622
1999 Impreza 2.5 RS
I'd say viscous coupling inside the center diff, and you saying it doesn't do it when it's cold further makes me think that. Mines does the same exact thing, after 15-20 min of driving, slow and sharp parking lot speed turns is when the problem becomes noticeable.
+1 on the whole center diff having to be changed. My problem isn't so bad, so I'm just not doing anything about it until it gets so bad that the car just stops rolling haha
giosoccer20 is offline   Reply With Quote
