Old 10-23-2012, 08:39 PM   #1
WhatTurboLag?
Member#: 243992
2006 WRX TR
Default high speed/rpm lockout in 3rd
so i have about 800 miles on my brand new 07 sti trans and clutchmasters fx400 6 puck and today i had an issue shifting into 3rd twice. first time i obviously didnt expect it and revved it real good thinking i was back on the throttle. second time i was testing it and it in fact did lock me out, not a missed shift.
what causes this? just the clutch or fluid or it all being new?
didnt notice this until today. i did my first race launch on a very humid night the other night with no issues.
WhatTurboLag? is offline   Reply With Quote
Old 10-24-2012, 10:37 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
do you have a lot of slop in the shifter? On cars with a good bit we've seen things get stuck between 3 and 5 as you overshoot the slot for 3.
Old 10-25-2012, 10:23 AM   #3
WhatTurboLag?
Member#: 243992
2006 WRX TR
nope, i have your holy shift set
i havent had it recently, it just happened those two times.
Old 11-18-2012, 07:48 AM   #4
Pullski22
Member#: 337410
2016 WRX STI
Hyperblue
Impreza WRX STi
turbolag I have the same problem sometimes on my 06 STI...It's been really scary because I've been on the road with traffic behind me and almost been rear ended. I've found that it helps sometimes to kinda ease it into third and let the clutch out a little slower than the other gears. Like you said though it only happens every know and then
Pullski22 is offline   Reply With Quote
Old 11-18-2012, 09:37 AM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
What was your previous clutch? Is the current disc a sprung unit?
Old 11-18-2012, 02:22 PM   #6
WhatTurboLag?
Member#: 243992
2006 WRX TR
it hasnt happened since i made this post, like almost 1000 miles and a rear axle later
i had a stock 06 wrx clutch with 30k miles on it to a sti 6 speed with a clutchmasters FX400 sprung clutch.
Old 11-18-2012, 04:07 PM   #7
Pullski22
Member#: 337410
2016 WRX STI
Hyperblue
Fuji, it's a stock Exedy 06 STI setup, and Turbo what did you do to fix your issue?
Old 11-18-2012, 04:08 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Sprung 6 pucks are usually heavier. It'll have the gear lockout effect and wear out the synchros at a quicker rate.
We had this incident once at the drag strip after we installed a sprung 6 puck disc onto a WRX of ours. We where running a PPG Trans on a 18G & E85. We ended up dropping the tranny and took off the clutch setup and reinstalled everything. It went away so it made me wonder if the pressure plate wasn't flush with the flywheel. After a few runs i was able to get us into the high 11's trapping at 118mph.
Old 11-18-2012, 07:02 PM   #9
WhatTurboLag?
Member#: 243992
2006 WRX TR
Nothing at all I haven't been able to do any good 1st-4 runs to really test it yet
