Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 10-24-2012, 08:56 PM   #1
cny12owner
Member#: 322250
2015 WRX Premium
Ice Silver Metallic
Default Any iPhone bluetooth issues?
About to pull the trigger on an iPhone 4, 4s or 5, and am curious if there are any compatibility issues between the non-navigation stereo in my '12 and these iPhones, using the bluetooth connection to make/receive phone calls. Not really concerned with any of the music playing issues that have popped up, as my intent is to continue using my iPod for music. Did a quick search and didn't see anything else on the topic that couldn't be fixed by a quick read of the manual. Thanks in advance.
cny12owner is offline   Reply With Quote
Old 10-24-2012, 09:08 PM   #2
ans2k
Member#: 315631
2012 Impreza Sport
iPhone 4 checking in. works fine for me
Old 10-24-2012, 09:31 PM   #3
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Once paired, the phone works great; however, the iPhone will be playing music in the background and discharging your battery because of the hooky way the Bluetooth audio connection works. You may not even realize that the iPhone is on. This was covered in one of the older threads.
Edit: Problem is not limited to the iPhone.
G-Omaha is offline   Reply With Quote
Old 10-24-2012, 09:44 PM   #4
cny12owner
Member#: 322250
2015 WRX Premium
Ice Silver Metallic
Is this issue common to all iPhones, or just to some of them? Saw the older thread dealing with this, but obviously it was before the iPhone 5 came out. Music issue is not an issue for me, but the discharging battery is...
Old 10-24-2012, 09:50 PM   #5
ans2k
Member#: 315631
2012 Impreza Sport
its happens to all iphones and to some others as well. also, randomly, when this does happen, sometimes when you turn off your car the iphone will play the music on speaker phone. happend to me twice in 6 months and happened to another member. it is rare but yea.
Old 10-25-2012, 12:55 AM   #6
billmang
Member#: 335757
Worked fine with my iPhone 4S. When I upgraded to the 5, it's having trouble syncing with the phone on start. I have to manually "select audio device" to pair it.
Wish one of the steering buttons would trigger Siri, but does not.
Also, I find the handsfree to be virtually useless at 30+mph. No one can ever understand me when there's road noise.
billmang is offline   Reply With Quote
Old 10-26-2012, 05:20 AM   #7
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I have a Samsung Galaxy S3 and I too had a couple instances where my music would play over the speaker phone after my car is turned off. So right now I have media audio unchecked, which basically stops my phone from playing music via Bluetooth while I'm driving, which would stop the battery drain.
Old 10-26-2012, 12:53 PM   #8
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Checking in with the iPhone 5. I also have the non-nav stereo, No Bluetooth issues. Had to delete the old one from the car memory & re-pair using voice commands. When I paired with te menu buttons it didn't re-pair every time I got in the car. But pairing by the voice commands fixed that somehow.
SleepNMnky is offline   Reply With Quote
Old 10-30-2012, 02:09 AM   #9
pkL
Member#: 313093
2012 Impreza 2.0i
This a bit off topic, have you set up your HU to display names instead of phone numbers for incoming and outgoing calls?
Old 10-30-2012, 10:12 AM   #10
Slys'08STI
Member#: 175300
2014 STI
What up pkl... I also have a S3 & 2012 STI Limited/nav. I have changed the names and everything seems to have taken, but I have been having... connection issues. Phone will connect then disconnect as it pleases! Are you having the same issues? If not, you know the fix?
Slys'08STI is offline   Reply With Quote
Old 10-30-2012, 11:46 AM   #11
archmikus
Member#: 323805
2012 Impreza Sport
Sage Green
No issues with the iPhone 5 and the non-nav head unit. Works great. Pairs automatically within seconds of starting the car, and music sounds great playing over bluetooth.
archmikus is offline   Reply With Quote
Old 10-30-2012, 12:27 PM   #12
53x12
Member#: 206332
The one issue that I have is that I need to "connect" my iPhone to the car each time I get in. If I pair with just the radio prior to starting the car, then I need to do the process again when I start the engine.
Have to do the whole iPhone setup: settings-- general--bluetooth--on--CAR M_MEDIA connect. Also need to make sure Impreza radio is on and set to bluetooth option.
53x12 is offline   Reply With Quote
Old 10-30-2012, 12:34 PM   #13
SleepNMnky
Member#: 302491
Try deleting that & pairing it through the voice commands. That worked for me to fix the same problem.
Old 10-30-2012, 12:54 PM   #14
53x12
Member#: 206332
Awesome. Thanks SleepNMnky. I will have to give that a try.
Old 10-30-2012, 07:15 PM   #15
Chingyul
Member#: 333537
2013 Impreza 5dr
Touring DGM
No issues with my iPhone 4, but haven't used it too much yet.
Wish there was an easier way to sync phone numbers though.
Chingyul is offline   Reply With Quote
Old 10-30-2012, 09:07 PM   #16
cny12owner
Member#: 322250
2015 WRX Premium
Ice Silver Metallic
Haven't pulled the trigger yet, but thanks to everyone for the input! Leaning towards the 5....
Old 10-31-2012, 02:44 PM   #17
redzone6196
Member#: 322454
I have had my Impreza since the middle of June and I have had no problems easy dodger when it comes to the Bluetooth with my 4s. I have the Satellite Navigation system so everything that comes with that has worked awesome for me.
redzone6196 is offline   Reply With Quote
Old 10-31-2012, 03:33 PM   #18
53x12
Member#: 206332
Just a follow up, did it the way you recommended and haven't had that issue since. Thanks again.
Old 10-31-2012, 04:15 PM   #19
SleepNMnky
Member#: 302491
Glad it worked for you too. Makes no sense at all to me, but it works.
Old 10-31-2012, 07:12 PM   #20
JohnNevets
Member#: 331193
2012 Impreza
Camellia Red Pearl
Not to hijack, but has anybody else had issues getting the iphone5 working via the USB to lightning cable? Mine works fine via Bluetooth, but although it sees it when plugged in to the USB, it doesn't play nice. It will start to play and then stop almost instantly, and the menu controls won't surf through the file structure either.
Just curious.
JohnNevets is offline   Reply With Quote
Old 11-01-2012, 07:06 PM   #21
SleepNMnky
Member#: 302491
Just curious.
Once paired with Bluetooth my iPhone no longer works with the USB period. That's how it was with my iPhone 4. So I have a separate iPod connected to USB & don't use it for my iPhone.
Old 11-02-2012, 12:31 AM   #22
pkL
Member#: 313093
2012 Impreza 2.0i
Nope I never had that problem, maybe you an try what SleepNMnky did and pair it through voice commands?
Old 11-26-2012, 12:11 AM   #23
cny12owner
Member#: 322250
2015 WRX Premium
Ice Silver Metallic
Ended up going with an iPhone 5. Quite the easy setup, just deleted the old phone as others noted, then used the voice commands to set it up. No issues so far with the bluetooth connection. Thanks to everyone for the advice and comments.
