Old 11-18-2012, 03:37 PM   #1
Serkan
Member#: 180514
2004 Sti
Default Automatic shifter position not right
I just swapped a different automatic transmission to my 04 legacy.
When the shifter is set to "P" position the transmission is actually is in Reverse (says on cluster)
And when I position it to 3rd it is actually in 1st gear. And shifter will not move pass 3rd gear.
So it needs an adjustment but where do I do the adjustment ?
At the inhibitor switch or the cable nuts right under the shifter box ?
Thanks.
Edit: Solved the issue
Serkan is offline   Reply With Quote
