Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-10-2012, 03:06 PM   #1
Cory51191
Member#: 332781
2006 STI
Default Dying clutch?
Last night I decided to give my car a little push. When I got into 3rd gear (clutch was all the way up) my rpms stayed at 7k and slowly went down as the clutch grabbed. It's the first time this has happened to me. I can still smell my clutch a little bit today as I'm driving casually.
Cory51191 is offline   Reply With Quote
Old 11-10-2012, 03:17 PM   #2
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
if you think your clutch is slipping, put it into 3rd gear and go WOT from 2k or 3k rpms. if the rpms go up fast and the car barely accelerates, you need to get a new one
Old 11-10-2012, 11:42 PM   #3
Cory51191
Member#: 332781
2006 STI
In 3rd gear at 2k rpm I'm going 26mph. And at 3k rpm I'm going 39mph. Not going to accelerate very fast at all at those numbers lol. But no the clutch didn't slip @ WOT... Again at those numbers I don't really even see a bad clutch slipping. Maybe you thought I have a 6-speed. 02 WRX.
Old 11-11-2012, 10:26 PM   #4
Phillysubaru89
Member#: 328527
2015 WRX
Glaxy Blue Pearl
If you clutch is slipping, your rpms will shoot up really fast, that's what he means. If your clutch is good, it will hold the rpms and take a while to accelerate.
Phillysubaru89 is offline   Reply With Quote
Old 11-12-2012, 01:03 AM   #5
curiousfish
Member#: 89283
2008 WRX Premium
SSM
curiousfish is offline   Reply With Quote
Old 11-12-2012, 02:11 AM   #6
LAPTOPER
Member#: 337646
Cory,
When I first noticed my clutch slipping, it was in the 3-4k range. If the clutch is in fact slipping, it'll only get worse over time. The fact you could smell your clutch definitely means you've got a problem. Mine had around 100k before it started. Had to replace it within 5k miles...
LAPTOPER
LAPTOPER is offline   Reply With Quote
Old 11-12-2012, 12:10 PM   #7
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
It could be that valve that prevents excessive drivetrain shock from dumping the clutch. I had something similar happen to me the one time I tried to launch my car, and it looks like you tried a very hard 2-3 shift at redline.
You should fill out your profile so we know what car you have, and can give better advice.
ResidentR is offline   Reply With Quote
Old 11-17-2012, 01:01 PM   #8
Cory51191
Member#: 332781
2006 STI
I didn't dump it though. Once it started to engage, I added throttle and let off the clutch evenly
