#26 |
Member#: 237221
Vehicle:2003 Hybrid VF39 E85 PDX WRX PSM Wagon |
I work midnights mostly and when its 30 deg or below I start the car, get out, check things out around the car (scrap frost if need be), throw my jacket in the back and get in then slowly drive off. So I'd say 2-3 min. About 2 miles down the road it's at a good temp.
#27 |
Member#: 331099
At least 15mins
#28 |
Member#: 41618
Vehicle:2008 WRX Hatch wrb |
In summer, not much.. a minute maybe then baby it until it reachs 1/4 needle..
In winter, where it gets to -35 here, i plug it in and let it warm up 10-15 minutes... i dont care about gas, i want my ass to be warm and the car too. If it's good for snowmobiles to let it warm up so you won't blow the engine or two strokes, it surely not bad to do on a car where the outside temp is -25 or -35. |
#29 |
Member#: 52726
Put key in turn it once (i think) wait for lights to turn off, start engine, wait 30 seconds, drive. If its below 32F I give it additional 30 seconds.
#30 |
Member#: 151079
Vehicle:2005 2.5RS RBP s-techs mad tyte yo |
I just start driving. If I wait a little bit, it's because I'm adjusting myself and the music. I want the engine and transmission to warm up together.
#31 |
Member#: 166085
TXIC
Vehicle:2010 STI OBP S.E. 05 FXT Stg.3|06 LGT Stg.2 |
I usually just warm the car up to operating temperature. I'm not just sitting in the car waiting though, I usually finish things up in the house for 5-10 minutes before heading out. All while the car warms up.
#32 |
Member#: 337170
Vehicle:2003 wrx silver |
if it's REALLY cold outside, I let it warm up while I finish up in the house and then come out to a warm inside
otherwise, I start it and shift around 2500 till she's warm and then BOOST&BOOST&BOOST&BOOST 💨 |
#33 |
Member#: 316278
TXIC
Vehicle:2010 WRX Sedan WRB |
Until the idle drops to normal speed. As long as its idling high, I don't put load on it
#34 |
Member#: 318736
Vehicle:2013 WRX Hatch CBS (BLCK) |
5 minutes @ least before going anywhere
#35 |
Member#: 248202
Vehicle:2013 WRX Sedan SWP |
Lot of wasted gas in this thread
#36 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Modern vehicles don't need to be warmed to be driven... however... you don't want to be putting the engine under major load before the OIL is warmed fully. Cold oil + high engine load = BAD for bearings and Subarus are prone to bearing failures.
Oil gets warm a minute or two after the coolant needle stops moving. So I don't "warm my car up" before driving, but I don't hammer it until my oil pressure gauge drops to normal when the car is idle (a minute or so after the coolant needle stops moving.) |
#37 |
Member#: 338159
NESIC
Vehicle:2005 Legacy LGT Red |
In Maine it gets really cold so if I haven't started it for a while I'll usually let it run for a few minutes and take it easy until it's on normal
#38 | |
Member#: 262760
Vehicle:2011 WRX Hatch Limtd Satin White Pearl |
Same as most people...let it idle down for a little before driving. Just a few moments. |
#39 | |
Member#: 166085
TXIC
#40 |
Member#: 249659
Vehicle:2012 WRX Limited SWP |
When its less than 30 degrees, I warm my car up enough that my seats are warmed up so I don't freeze my testiculars off
#41 |
Member#: 167739
Vehicle:04 WRX |
#42 |
Member#: 249659
Duhhh, you have to drive like that sometimes. It improves your shift timing my .05 seconds
#43 | |
Member#: 307359
South East
Vehicle:'05 STi Stage II OBP |
#44 |
Member#: 100300
Vehicle:06 WRX CGM |
I let my car idle for a few before moving and I also do something else. I gently tap the throttle and the rpms rise and then fall lower than they were before I hit the gas. What's the reason for the rpm drop?
#45 | |
Member#: 316278
TXIC
#46 | |
Member#: 213548
Vehicle:2004 BMW 330ci |
#47 |
Member#: 318521
NWIC
Vehicle:08 WRX sedan WRB |
#48 |
Member#: 315748
Vehicle:2012 wrx White pearl |
Thanks for the response ladies, I let mine sit fit about 30 sec then I ride the 2k idle till it drops and lightly keep it in 2k in each gear till its fully warm
#49 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
As long as it takes me to get out of the driveway. Thats 500 feet then floor it.
#50 |
Member#: 96919
Vehicle:2004 sti black |
i installed a block heater
