#201 | |
Member#: 342257
SCIC
Vehicle:2013 impreza premium Blue Marine pearl |
#202 |
Member#: 57378
South East
Vehicle:2002 wrx w/ sti swap 04 sti, 11 forester xt |
Block heater FTW, and I live in GA where it only snows once every couple of years. I set a timer the night before so it comes on just long enough in advance for it to be warm. Instant warm air from the vents, and the oil temp gauge is starting to climb by the time I get out of the driveway. I hate hearing piston slap.
#203 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
I use the block heater whenever possible, year round. In any case, the car is moving within 30 seconds.
#204 |
Member#: 342369
Vehicle:2007 impreza silver |
5 - 10 minutes
#205 |
Member#: 311522
South East
Vehicle:2012 WRX Icy Silver Metallic |
5 min or so
#206 |
Member#: 194132
Vehicle:2009 WRX Sedan SSM |
3hrs with a brick on the accelerator pedal. Nothing like the sound of a subie engine bouncing off it's rev limiter for hours on end.
#207 |
Member#: 159721
NWIC
Vehicle:08 WRX WRB |
I am warming up all of my subies until the arrow reaches the first mark. My 2003 Forester got 220K miles without any issues until I sold it last summer.
#208 |
Member#: 175565
Vehicle:2005 STI CGM Built 351whp/368tq |
With new pistons in the car and it being winter time I let it warm up to the second mark which is about 10 minutes.
#209 |
Member#: 323545
Vehicle:Old Racekorrrrr! Multi |
#210 |
Member#: 309930
RMIC
Vehicle:2013 STi Sedan Stg 1 Plasma Blue Pearl |
I wait for it to hit 1500 rpm before taking off, idk why I do it though ;P . Then I keep her under 3k until warmed up.
#211 |
Member#: 342487
Vehicle:2002 Subaru WRX Matte White |
Once my car is heated inside and is nice and warm
#212 |
Member#: 336054
Vehicle:2012 WRX Hatch Ice Silver |
Good 5 minutes, then keep under 3k rpm for a few miles
#213 |
Member#: 83266
NESIC
Vehicle:2011 WRX Sedan SWP |
I remote start it for about 5, then take off keeping the rpm's down as others have stated.
#214 |
Member#: 297396
Long enough for the piston slap and TO bearing squeak to go away. Then drive off like a sane human being.
Been in the low 20's in PA lately. |
#215 | |
Member#: 304662
Vehicle:2001 Impreza L coupe Sedona red Pearl |
I have a bad TOB too, lol. To keep with the thread, I just bought a magnetic plug-in heater yesterday. For now I'm using it on the oil pan, just to see how it helps with cold-start cranking. It will also be able to stick to the block and act as a block heater if I want. I used it on the oil pan this morning but I don't think I let it go long enough. Guess it needs over an hour. |
#216 |
Member#: 325432
Vehicle:2002 WRX WRB |
None. I just start my car and drive away at low RPMS (1-2.5k) until temp gauge is normal. THEN DRIVE IT LIKE I STOLE IT.
#217 | |
Member#: 284046
NESIC
Vehicle:2000 Impreza w/ WRX |
#218 |
Member#: 293186
Vehicle:2008 WRX WRB |
Usually 5 min but lately its been 10-15 min because its been in the single digits
#219 |
Member#: 341903
Vehicle:2013 WRX 4dr WRB |
I am sure this has been covered in the thread, but based on some reading I did years ago one of the worst things you can do to a car is a cold start with long idle.
Example 1- let the car idle until its in normal op temp. Not a good idea. Example 2- start car cold and move it and then shut off. Also read that is horrible to do. For example back out of garage to wash car. The best thing you can do is start the car let it idle for 30-60 secs and then drive. The car is MUCH more efficient at warming up while driving vs sitting. Dont rev it up high of course but keep rpms low until operating temp is reached. |
#220 |
Member#: 335013
RMIC
Vehicle:2013 Premium WRX 5dr WRB |
Less than a minute since I park in a closed garage.
#221 | |
Member#: 304662
#222 |
Member#: 304662
Kind of a follow up from my last comment:
Got to take advantage of my magnetic heater finally. Guess it takes atleast 2 hours to make a difference in heating the oil in the pan. Starting a car from a completely cold start with warm oil is awesome. To my surprise, the car took about half as long to warm up as usual. I bought the magnetic heater just for cold-starts this winter, to help with the thicker, cold oil. Turns out it could help with the piston slap as well. The quicker my pistons heat up and expand the better. This also means less time and gas spent letting my car idle to warm up. |
#223 |
Member#: 273906
NESIC
Vehicle:1831 Conestoga Wagon My oxen all died. |
#224 |
Member#: 304662
The 'wear' on your engine from driving while your pistons are slappin' away (still cold), out weights the 'wear' from letting your car idle too long to warm up.
Atleast for me. That's how I look at it. Although, I'm sure some will disagree. Last edited by ManualOverAuto; 01-06-2013 at 06:11 PM. |
#225 |
Member#: 273906
NESIC
Sounds fishy to me. I've never heard that Subaru piston slap was anything other than an annoyance with very minor effects on longevity. However, there is plenty of evidence that prolonged cold idle periods are quite bad for the vehicle.
