Old 11-17-2012, 05:32 AM   #1
Boxerscoopy90
Member#: 309974
Default Rear sway bar fitment question
Guys i have 07 impreza and unfortunately it didnt come with a rear sway bar ( yes it didnt) in my country . so i was asking if i could fit one . I know that i will need endlinks, bushings and brackets any thing else ?
But my question is would i be able to fit it because when i had a look under the car i didnt find that piece that the endlink should be attached to . I know u might not understand me put i'll take a picture to show what iam talking about
Boxerscoopy90 is online now   Reply With Quote
Old 11-17-2012, 05:47 AM   #2
Boxerscoopy90
Member#: 309974
Old 11-17-2012, 06:30 AM   #3
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
I don't see mounting points for the endlinks on the control arms. My guess is that you could swap in WRX or USDM Impreza control arms that have the endlink mounting points. I'd research that first.
The other question is do you have the threaded holes for the sway bar mount brackets?
FCmaniac is offline   Reply With Quote
Old 11-17-2012, 07:16 AM   #4
Dr. Mitsubaru
Member#: 289846
2002 Wrx
For the rear, the endlinks mount on the rear Lateral Arm, so buy some usdm rear lateral arms, or weld on some brackets. Also make sure you do have the threaded 8x1.25 holes for the mounting brackets as stated above.
Dr. Mitsubaru is offline   Reply With Quote
Old 11-17-2012, 10:46 AM   #5
Boxerscoopy90
Member#: 309974
Thxx guyss . Do u think it would be a good idea to weld it or should i buy 2 new lateral links ?
I'll make sure that i have holes for the upper bracket but if i didnt is there also a solution flr that ?
Old 11-17-2012, 06:45 PM   #6
Boxerscoopy90
Member#: 309974
Also is there any way i could fit it without changing the lateral arms
Old 11-18-2012, 03:40 AM   #7
Boxerscoopy90
Member#: 309974
Any help ?
Old 11-18-2012, 03:42 AM   #8
sc00by4life
Member#: 97135
You need the correct lateral links.
No.
Any help ?
there is absolutely no need to bump a thread every hour. it takes time to get responses.
