Old 11-17-2012, 09:41 AM   #1
ewd199
Member#: 336163
Default turbo swap boost help
Hi guys. I've got a wrx that had a vf39 turbo with all supporting mods and tuned ran at 19 lbs for about 2 years flawlessly. just put in an identical rebuilt vf43 from six star speed. now car holds boost but only reaches max 15 lbs and is slow to get there after 10 lbs. I didn't change anything but swap out the vacuum lines on the wastegate and boost solenoid to a little thicker gauge. anyway do you think there could be a leak somewhere? I hope the turbo is not faulty. it makes sense it's a leak because the boost is slow to peak after 10 lbs. anyway please help!!!
thanks.
ewd199 is offline   Reply With Quote
Old 11-17-2012, 11:40 AM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Did you tune it at all?
Old 11-17-2012, 02:01 PM   #3
ewd199
Member#: 336163
all I did was switch out an identical turbo I was told retune was not needed. If I sent mine in to be rebuilt and then put it back in I wouldn't get the car retuned. It doesn't make sense everything is same it's jus newer.
Old 11-17-2012, 04:01 PM   #4
ewd199
Member#: 336163
nvm looks like I had a small leak. and I replaced the vacuum lines again. holy **** the car moves.
Old 11-17-2012, 04:58 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Pretty sure going from a 39 to 43 you'll need a retune. And by pretty sure, I'm 99% sure.
Old 11-17-2012, 07:03 PM   #6
skatinboarding
Member#: 233960
2011 WRX HATCH
WHITE
same turbo, but retunes wont hurt anything.
skatinboarding is offline   Reply With Quote
Old 11-17-2012, 08:19 PM   #7
ewd199
Member#: 336163
Ya it wouldn't hurt. may do it in the near future.
Old 11-17-2012, 08:22 PM   #8
ewd199
Member#: 336163
so if I had a bone stock sti. BONE STOCK. and the turbo goes so I put the same factory subaru vf back into the car. am I going to go tune the car? lol no.
Old 11-17-2012, 09:01 PM   #9
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
If you interchange a 39 fora 43 or 48, yes... You need a retune. They do not share the same wastegate actuator.
Black94Snake is offline   Reply With Quote
