Old 11-17-2012, 03:14 PM   #1
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
Default Wearing clutch
2011 WRX , 30,000 miles. 275hp 303lbs tq. Clutch I assume is about to go. RPM's spike and car doesn't respond right around boost. It eventually catches but with what feels like much less torque. When I replace my clutch how heavy do I go? I would like to eventually like to get bigger turbo, injectors, fuel pump, and inter cooler. Looking to eventually be at 330-350hp. Any advice would be appreciated,thanks.
Avoegeli is offline   Reply With Quote
Old 11-17-2012, 03:17 PM   #2
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Yep sounds like its on its last leg.. most will recommend another stock clutch as to save the rest of the drivetrain. Going with a heavier clutch will stress the tranny out more
ColeBerkenbile is offline   Reply With Quote
Old 11-17-2012, 03:30 PM   #3
lappit
Member#: 283660
07 wrx
If you want to upgrade and push for more horsepower you should just replace the clutch with a stronger one now cause once u do gain more power your stock clutch wont be made for that. And then you wont have to pull ur tranz twice.
lappit is offline   Reply With Quote
Old 11-17-2012, 03:36 PM   #4
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
That was my thought process. I'm gonna let the tranny do it's thing. I think it will handle my power mods. But I don't want to replace again cuz stock clutch won't handle it
