Old 11-17-2012, 04:17 PM   #1
bobdole888
Member#: 316658
2012 Impreza limited
5dr silver
Default Parking brake clunk
My impreza makes a loud clunk sound when I apply the parking brake.
This is the only car that I have ever driven that does this.
Is this normal?
It only happens when the car is moving. If the car is already parked, then it doesn't do it.
So if the car is moving ~5mph or more and parking brake is applied, a lound clunk sound is heard. This happen even when the brake is applied lightly.
I thought part of the break-in procedure is to apply the parking brake while the car is in motion. So it can't be that this parking brake is not meant to be engaged when the car is in motion.
Have you guys experienced this?
bobdole888 is offline   Reply With Quote
Old 11-17-2012, 05:33 PM   #2
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Is this normal?
Mine does exactly the same thing, I'm not sure if it has something to do with the hill assist but it is definitely meant to be applied I while the car is in motion in an emergency situation.
BoxerSport2.0 is offline   Reply With Quote
Old 11-18-2012, 01:07 AM   #3
bobdole888
Member#: 316658
5dr silver
Mine is a CVT, I don't think there is hill assist feature on CVT model.
The clunk sound seem to indicate something is loose.
Old 01-08-2013, 10:36 PM   #4
bobdole888
Member#: 316658
5dr silver
Has anyone else have this parking brake clunk?
Old 01-08-2013, 11:01 PM   #5
ans2k
Member#: 315631
2012 Impreza Sport
cvt and it does
ans2k is offline   Reply With Quote
Old 01-09-2013, 09:13 AM   #6
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
The OP says this clunk only happens when the car is moving. Stupid question:
Why are you applying the parking brake while your car is moving?
I can only think of two reasons to do this:
  • You've lost your main brakes and you're using the parking brake to slow the car down.
  • You're trying to break the rear end of the car loose to force it into a drift.
Am I missing something?
EDIT: I see that the OP says the owner's manual states that applying the parking brake while in motion is part of the break-in procedure. I don't remember seeing this in the owner's manual, but maybe I missed it. I'm not sure why this would be part of a break-in procedure.
sgoldste01 is offline   Reply With Quote
Old 01-09-2013, 09:46 AM   #7
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
It's on page 11-20 of the manual. I nearly missed it myself, until someone in another thread mentioned about it.
lymphomaniac is offline   Reply With Quote
Old 01-09-2013, 10:07 AM   #8
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Hmm. I didn't do that as part of my break-in, and I'm not sure what break-in purpose driving with the parking brake engaged would perform. I know that normal brake shoes go through a break-in/setting process from normal use, but this is the parking brake we're talking about, so I wouldn't think that would be necessary.
Regardless, I still don't understand the concern over this clunking sound. Other than the documented break-in procedure, and the bulleted items in my post above, I can't think of any other reason to apply the parking brake while in motion. If you don't like the clunk, then don't use the parking brake while you're rolling!
Old 01-09-2013, 10:56 AM   #9
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
If you can hear the clunk it means youre not giving it enough gas around the turn.
Old 01-09-2013, 10:56 AM   #10
M45
Member#: 333446
2013 Impreza SL CVT
does the parking brake utilize the normal brakes? on my old car it was a cable to the rear brakes. it basically just bypassed the brake lines.
M45 is offline   Reply With Quote
Old 01-09-2013, 12:14 PM   #11
bobdole888
Member#: 316658
5dr silver
Thanks for all the response, but I still haven't heard any feedback from '12 impreza owner whether their car does this or not.
Note, not much effort is needed to be applied to the hand brake to have the clunk sound. Not even enough pressure to feel any slowing down.
It just seems like the brake pad is loose and as hand brake is applied it shifts and makes the clunk.
Old 01-09-2013, 01:37 PM   #12
myrt1987
Member#: 323103
2012 Limited 2.0i
I will try it today. It will prob make the sound. I suspect its normal. Probably something to do with being awd.
Old 01-09-2013, 01:50 PM   #13
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
I think in the cvt the multi plate clutch center might be programmed to go full open mode if the e-brake is pulled to protect the drivetrain. This might be the source of the sound and could explain why it occurs with little brake application. The switch in the handle probably releases the clutch to full open if the handle is lifted at all. If you were previously moving and had some amount of locking rate between the axles, the sudden clutch release or the actuator moving might produce a sound.
saabarupp is offline   Reply With Quote
Old 01-09-2013, 01:59 PM   #14
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I would have suggested that it might be the Hill Hold feature, but you guys are hearing this clunk in CVT cars. Do CVT cars have Hill Hold too?
Old 01-09-2013, 02:22 PM   #15
M45
Member#: 333446
2013 Impreza SL CVT
it seems like that could be accomplished via other means...
Old 01-09-2013, 10:10 PM   #16
Piper
Member#: 32242
2014 DGM Forester XT
2015 XV Ice Silver
My ‘13 CVT has the clunk as well. I use the E-brake every once in awhile when I notice a familiar set of headlights in the rear view and need to slow down without drawing attention
Piper is offline   Reply With Quote
Old 01-09-2013, 10:20 PM   #17
the_dog
Member#: 287417
2013 Impreza Spt Lmt
Originally Posted by Piper View Post
My 13 CVT has the clunk as well. I use the E-brake every once in awhile when I notice a familiar set of headlights in the rear view and need to slow down without drawing attention
I use the paddle shifters for that...
the_dog is offline   Reply With Quote
Old 01-10-2013, 08:54 AM   #18
myrt1987
Member#: 323103
2012 Limited 2.0i
Yes mine does this. Holy crap i was not expecting it to be that loud either. lol definitely something mechanical going on before the brake pad actually hits the rotor.
Old 01-10-2013, 09:14 AM   #19
M45
Member#: 333446
2013 Impreza SL CVT
I didn't notice a clunk this morning when I tried this out. Maybe I wasn't listening carefully enough???
Old 01-10-2013, 09:40 AM   #20
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I just looked at the design of the parking brake shown in the service manual. It looks like the parking brake is more of an old-fashioned shoe/drum arrangement. The parking brake does not use the rear brakes' pads and rotor.
Old 01-10-2013, 10:11 AM   #21
M45
Member#: 333446
2013 Impreza SL CVT
one thing I did notice was that the car did not stop as fast as I expected. on my old car if I pulled the parking brake it was not a gentle stop.
Old 01-10-2013, 10:19 AM   #22
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
thanks for being out crash test dummies guys
aeoporta is offline   Reply With Quote
Old 01-10-2013, 10:29 AM   #23
Kharn
Member#: 306129
The parking brake is for making sure your vehicle does not run down the hill without you, not stopping while in motion.
Kharn is offline   Reply With Quote
Old 01-10-2013, 10:35 AM   #24
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
My thoughts exactly. I really don't understand the concern with the clunk. If you don't like the clunk, don't use the parking brake while in motion. Problem solved!
The **only** time I've ever used a parking brake while in motion was when I was teaching my daughter winter driving skills in my old Civic. In a snowy parking lot, I'd have her get up to speed and then I'd pull on the parking brake to simulate a loss of control/over-steer situation on a slippery road, then I'd release the brake so that she could practice regaining control of the car. Good lesson.
Other than that, I've never used my parking brake while a car is in motion.
Old 01-10-2013, 11:00 AM   #25
myrt1987
Member#: 323103
2012 Limited 2.0i
Haha that sounds like a fun lesson^
