Old 05-06-2012, 05:30 PM   #1
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Default Bluetooth contacts with iphone
So I've done a bit of research on how to transfer my contacts to the headunit. So far I've come up with trying to sync my macbook and sending a vcard of all my contacts. Didn't work. The pc wouldn't connect to the phonebook, but would recognize it as an audio device.
Other option is to use my jailbroken iphone and find a bluetooth app that will allow file sending. So far I've found airblue but am skeptical if it will work.
Anyone had any luck sending over a vcard?
Ladeef is offline   Reply With Quote
Old 05-16-2012, 11:29 AM   #2
CraigHwk
Member#: 320242
2012 Impreza2.0i 5dr
Dark Gray Metallic
I don't know how much different my '12 radio is from yours, but it does not accept contact transfer. Even verified this in the manual. All contacts must be inputted manually or by adding a number from an incoming call you took in the car.
This is in the '12 2.0i Limited without navigation. If you have the nav, I apologize for butting in.
CraigHwk is offline   Reply With Quote
Old 05-22-2012, 10:55 AM   #3
dodman
Member#: 320415
2012 Impreza Sdn Lmt
Ice Silver
Default Download Contacts From e71 Nokia
I finally figured out how to download my contacts from my aging e71 Nokia to my 2012 Impreza Limited HD Radio. I had no problem pairing my phone with the Impreza, but could only get my contacts loaded by using the manual mode. This worked but incoming calls just showed the number and no caller ID. Anyway I figured out how to download the contacts from my phone and it works well. You have to do them one at a time, but I only loaded 20 or so of my most used contacts. The process is as follows: First, turn your key to the Aux position so that your radio is powered. Next push the steering wheel on button and then select phone book. Once selected select ADD CONTACT and then BY PHONE as the method. Go to you phone and highlight the contact you want to download. Select SEND, then BUSINESS CARD, then VIA BLUETOOTH, then CAR MULTIMEDIA or whatever unique name you gave your radio when you paired the phone. Once selected the phone will send the contact to your radio, the radio will announce the phone number and ask you to confirm. Once confirmed the radio will ask you to give the number a name. Follow the prompts and confirm the name. Now when one of the contacts you have downloaded calls your number, both the number and name will display on the radio display. This is how the e71 Nokia works and I am sure it would be similar for other cell phones as well. I will say the Impreza Bluetooth is a little hokey, but after a few weeks I have it working better than I experienced with other cars I have owned.
dodman is offline   Reply With Quote
Old 05-22-2012, 12:21 PM   #4
2012ruimpreza
Member#: 316776
2012 Impreza hatch
Thanks dude this is very helpful
2012ruimpreza is offline   Reply With Quote
Old 05-22-2012, 12:35 PM   #5
CraigHwk
Member#: 320242
Dark Gray Metallic
Hm, I'll have to try this! Thanks a lot.
Old 05-22-2012, 04:02 PM   #6
somebody else
Member#: 21618
So, dodman...
Department of Defense?
somebody else is offline   Reply With Quote
Old 05-23-2012, 02:44 PM   #7
dodman
Member#: 320415
Ice Silver
Retired Graphic Arts. No DOD. LOL!
Old 05-23-2012, 03:40 PM   #8
dodman
Member#: 320415
Ice Silver
Hope my Nokia post helps some folks. Have to tackle the wife's iPhone 4 next. Don't think it's possible with the iPhone OS but maybe an App that can send files via bluetooth? Anyone have any success with the iPhone?
Old 05-23-2012, 03:49 PM   #9
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
tried with Airblue share (jailbroken) to no avail, it's one of the only bluetooth sharing apps I've seen
Old 05-23-2012, 07:34 PM   #10
2012ruimpreza
Member#: 316776
2012 Impreza hatch
Couldn't find a way to do this on my iPhone 4 unfortunately.
Old 06-09-2012, 11:36 AM   #11
dodman
Member#: 320415
Ice Silver
Default iPhone
I have researched this extensively and have concluded there is no way to download contacts from an iPhone to the 2012 Impreza bluetooth head unit. There is nothing in the iPhone iOS or available App to provide this capability. There are phones that will allow you to download contacts one at a time (such as my Nokia e71), but after owning the car for about a month I now understand why Subaru does not allow downloading more than one contact at a time regardless of which cell phone you own. The reason is you must dictate a verbal name for each contact which takes almost as long as just manually entering the entire contact. What I ended up doing was just adding my top 10 or so contacts which probably covers 90% of my phone activity. The bluetooth works very well, better than any in several previous cars I have owned. Even at highway speed I get no complaints on voice quality. The icons showing signal strength and battery status are a nice bonus. There is nothing about this Impreza that I don't like.... it's great.
Old 06-12-2012, 01:03 PM   #12
huskies87
Member#: 318203
Is there anyway to have the name of your contact come up on the head unit when they call?
huskies87 is offline   Reply With Quote
Old 06-12-2012, 01:33 PM   #13
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
nope even with the name and number programed in they still dont come up. With the poor sound quality and these little details missing. I thought it was time to upgrade.
Old 10-17-2012, 05:13 PM   #14
dodman
Member#: 320415
Ice Silver
The name does come up on the head unit if you recorded a name for voice dialing. The number does not appear, just the name. In other words, if you recorded "Boss Office" to use for voice dialing your boss, "Boss Office" will appear on your head unit when the boss calls. Without recording a unique name for the numbers you have programmed, only the phone number will appear. I have a 2012 Limited Sedan with the HD Radio (no nav) and this is how it works in my car.
Old 10-18-2012, 06:08 AM   #15
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Is there any way to get the HU to display contact names or is it even possible for that matter? I have voice dialing set up already for certain contacts.
Old 01-03-2014, 02:11 PM   #16
nemos_black_wrx
Member#: 372679
2012 impreza
does any one have a easy way to do this for the 2013 base model impreza 20I ? been trying all morning. phone iphone 3gs
nemos_black_wrx is offline   Reply With Quote
FS : Alpine Head Unit w/ Bluetooth and ipod/iphone cable **SOLD** 08BlackWRXCT Interior/Dressup/Audio & Security 10 08-09-2011 10:32 AM
How to sync iPhone contacts with Pioneer AVIC-Z2 Bluetooth?? island boyeee Car Audio, Video & Security 2 01-20-2010 11:41 AM
Jabra BT800 Bluetooth Headset with Caller ID & Digital Display... BongMonster Non-Subaru Stuff 0 05-15-2007 10:09 PM
