Welcome to the North American Subaru Impreza Owners Club Thursday October 23, 2014
Old 11-18-2012, 11:19 PM   #1
poly_poly-man
Member#: 262988
2002 WRX Wagon
Default TGV delete install, car won't stop revving
I just put on the TiC TGV deletes I got as part of the group buy. I got my car back together, and after making sure the spark plugs were on right and all the final sensors were plugged in, it starts up, but it instantly revs up to my launch control, regardless of throttle input. I can't see anywhere big enough to make this much revving, I was hoping somebody else would have an idea about this.
Car: '02 WRX
ECU: Carberry Speed Density with 4500rpm launch control.
Any ideas where to look for this big air leak?
poly_poly-man is offline   Reply With Quote
Old 11-19-2012, 06:03 AM   #2
quazimoto
Member#: 70395
Got to be something that came off so either the TGV or intake manifold has a vacuum leak. Or if the TIC ones are reusing the sensors then the position sensors were not preloaded.
Old 11-19-2012, 11:44 AM   #3
poly_poly-man
Member#: 262988
2002 WRX Wagon
ah - something stupid. Of course I forgot to re-tighten the bolts holding the TGV to the heads after I had to shift that all around last night. Car works great now, if you're running into this problem, don't forget the obvious.
