Old 11-19-2012, 07:43 AM   #26
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Originally Posted by LastResort View Post
Breath dude. He was responding to drewvdw, who claimed that there 15W40 type of Rotella T6.
Originally Posted by bluesubie View Post
Thank you. Apparently there was a reading fail by Aaron.
-Dennis
Um.... I feel foolish... Sorry guys, I was all like "what did "I" do wrong"... my appologies...
Old 11-19-2012, 08:00 AM   #27
Jessekrs123
Member#: 236927
1993 Legacy Sedan
1984 BRAT
Originally Posted by drewvdw View Post
To those that said there's only 1 T6 oil, you're wrong. There's the 5/40 and the 15/40...yeah, I accidentally ran 15/40 for a bit...and I have a busted motor, but I don't know how much that contributed, if at all.
I run diesel grade Rotella/Delo400/Delvac 15w40 in all four Subarus in the driveway with absolutely zero issues. It actually stopped oil consumption on my mother's 95 Legacy, and keeps my HLA motors nice and quiet. I highly doubt the 15w40 caused your busted motor.
Using 15w40 diesel grade oil was the best switch I made, and now will always be my choice.
And these guys are worried about diesel grade 5w40...
Jessekrs123 is offline   Reply With Quote
Old 11-19-2012, 08:08 AM   #28
tibug
Member#: 273906
2017 Dodge
Dakota
Originally Posted by Uncle Scotty View Post
sweetie...;pull the tampon and take a midol and it will be ok in a couple days
THERE IS NO POSSIBLE ISSUE WITH USING EITHER OF THE OILS YOU HAVE PICTURED ABOVE
jesus h ****ing christ these kids are getting dumber and dumber every ****ing DAY, here
Agreed, as long as you don't let your oil drain overnight you'll be fine. It causes the engine internals to rust and tarantulas like to make homes in your oil pan and spin a web over your oil pickup, then your engine goes kaboom. You're such a smart guy...
tibug is offline   Reply With Quote
Old 11-19-2012, 08:23 AM   #29
HonduhPowa
Member#: 269076
2004 Wrx WRB
12.7@109
Have ran Rotella T6 5w-40 in both of my Wrx's and my wifes Impreza for a year now, nothing but great results.
HonduhPowa is offline   Reply With Quote
Old 11-19-2012, 09:00 AM   #30
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
"S" is for spark ignition and "C" is for compression ignition.
This oil is good.
It's a mixed fleet gasoline/diesel oil.
Specifications, Approvals & Recommendations
· API: CJ-4, CI-4 PLUS, CI-4, CH-4, CG-4, CF-4, CF ·API: SM, SL, SJ, SH
API "C" specifications are for diesels and "S" specifications are for gasoline engine. Check your owner's manual. It will say API SM.
-Dennis
CRAZYHAWK is offline   Reply With Quote
Old 11-19-2012, 02:19 PM   #31
JUICEB0X
Member#: 243090
Speaking of t6, it's 19.99 at my local O'reilly auto. I stocked up.
JUICEB0X is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 04:01 AM.
