Old 11-19-2012, 04:09 PM   #26
ecbmxer
Member#: 228059
2010 WRX
Spark Silver Metallic
Just get a downpipe and a good stage 2 protune. Tell the tuner you want it to be a bit more conservative. You'll be good to go with minimal mods. I'd skip the IC until you want to go further with the car. Spend the extra money on a wideband and boost gauge so you can keep tabs on things. Should be as reliable as stock if you take care of the car, don't drive crazy, and datalog things regularly.
ecbmxer is offline   Reply With Quote
Old 11-19-2012, 04:34 PM   #27
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Originally Posted by 424wrx View Post
how are you gonna have less heatsoak then a larger quality tmic? get a turbo blanket. not with a small oem tmic.
Larger intercoolers are much heavier with more mass that will absorb heat and be harder to cool once heatsoaked.
The smaller stock intercooler with the plastic endtanks flows pretty well and won't transfer heat from the turbo as easily as an all metal unit, and it's small enough that if it does heatsoak, say at a stoplight, it will cool back down almost instantly once air starts moving through it again. Unless you plan on tracking the car, the stock intercooler is fine at those levels and beyond.
The turbo blankets are definitely an awesome investment though. Every test has shown them significantly reducing underhood temperatures.
ResidentR is offline   Reply With Quote
Old 11-18-2014, 11:00 PM   #28
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
Sent from my XT1030 using NASIOC mobile app
Syndr78 is offline   Reply With Quote
Old 11-18-2014, 11:01 PM   #29
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
Old 11-18-2014, 11:02 PM   #30
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
Old 11-18-2014, 11:02 PM   #31
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
Originally Posted by Syndr78 View Post
I actually received my PTP lava turbo blanket yesterday.
I to at some point...
Old 11-19-2014, 02:41 PM   #32
1wrxtra
Member#: 316364
2012 WRX
Upgrading the intercooler certainly won't hurt you, but there are other mods you can do for much cheaper which will also fill that supporting role.
You could get a fuel pump, or as Unabomber mentioned, you can get an air-oil separator or catch can which will eliminate the blowby oil you will get in the intercooler, which will reduce the octane of your gasoline, potentially leading to detonation.
A richer fuel mixture will also allow help to cool the intake charge.
Neither of these mods require a tune, and both will help to support the longevity of your motor (the AOS moreso than the fuel pump). At stage 1 a fuel pump is probably not required, but it's cheap and easy to install. The AOS is a bit of a PITA to install if you've never done it before, but it certainly makes a difference.
Personally, I installed both an IC and a fuel pump at stage 1. I installed an AOS about a few thousand miles ago, but I'm running somewhere between stage 2 and stage 3. Probably should have done that sooner, but I never noticed any oil in my IC.
1wrxtra is offline   Reply With Quote
Old 11-19-2014, 05:25 PM   #33
Razgeiz
Member#: 358782
2013 STi
The best thing you can do for longevity is control the loose nut behind the driver seat.
Sent from my XT1254 using NASIOC mobile app
Razgeiz is offline   Reply With Quote
