Old 11-18-2012, 11:20 AM   #1
some dude
Member#: 100300
06 WRX
CGM
Default Screen installed over TMIC
Put a window screen (standard aluminum stuff) over the TMIC. I don't think it impedes airflow much at all. Am I wrong? I don't have any way of knowing if the IC isn't working 100%.
some dude is offline   Reply With Quote
Old 11-18-2012, 12:02 PM   #2
Kevwa451
Member#: 314408
2011 WRX Stage 2
I probably would've went with something with a little heavier mesh and a little bigger openings. Birds and rocks are about all you gotta worry about, most non-Amazonian bugs won't damage your tmic too bad or at all. Take it out and put it in front of a decently powered fan and see how much air flow you get through it. Not real world driving conditions but it'll give you an idea.
Kevwa451 is offline   Reply With Quote
Old 11-18-2012, 12:09 PM   #3
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Originally Posted by some dude
Put a window screen (standard aluminum stuff) over the TMIC. I don't think it impedes airflow much at all. Am I wrong? I don't have Amy way of knowing if the IC isn't working 100%.
I come from an industry where I deal with the airflow in and out of things. Your screen will lead to slower airflow which will get worse if leaves, debris, etc. get stuck on the screen. This can and will lead to additional heat in the IC, but frankly without knowing what else you have done under the hood, it is tough to say how much. That is something a heat gun could answer. If you are in stock mode and haven't done anything else, the heat increase should be minimal and should not affect your performance...SHOULD being the operative word.
stikboy is offline   Reply With Quote
Old 11-18-2012, 12:34 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
It will impede airflow, how much no one knows. Take it off and live your life. Will the screen work better than a few bent fins caused by bugs....who knows...who cares....if there was a need, the 79 engineers at Fuji Heavy Industries would have put one there.
Old 11-18-2012, 01:03 PM   #5
some dude
Member#: 100300
06 WRX
CGM
The car is totally stock. I've had a screen on there since I bought the car. Just replaced it for the first time. The fins are in great condition probably from the protection the screen gave them.
Old 11-18-2012, 04:48 PM   #6
wrxlaunch
Member#: 181298
This thread is ridiculous... are you just bored and wanted something to do so you added a screen over your tmic because you dont want bent fins? Did you do the same for your radiator while you were at it?
wrxlaunch is online now   Reply With Quote
Old 11-18-2012, 06:38 PM   #7
some dude
Member#: 100300
06 WRX
CGM
F yeah I don't want bent fins!
Old 11-18-2012, 06:43 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah....just mutha****in yeah
Old 11-19-2012, 08:28 PM   #9
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
i resemble that remark.
use hardware cloth (at any home supply place) $5 buys enough for your tmic and radiator. i tripled over my tmic. air flow is not an issue. i clean when anough bugs/rocks/debris shows. paint the radiator screen flat black and no one will know its there. andrew at andrew tech endorses this. only noobs think no protection is safe
mhoerath is offline   Reply With Quote
Old 11-19-2012, 08:45 PM   #10
Ghostwhite
Member#: 254958
I like the idea but I don't want a restriction.
I have a tweezers in the door pocket, I use it to straighten out fins while filling with gas.
Ghostwhite is offline   Reply With Quote
Old 11-19-2012, 11:08 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
YOU are just WAY outa yer mind....that is all
Old 11-19-2012, 11:14 PM   #12
P4GTR
Member#: 294328
2011 WRX
Did you put a 20lb ballast in the trunk and an intake restrictor on too?
If you're going to mod the car, MOD the car. Otherwise, leave the engineering to the engineers.
P4GTR is offline   Reply With Quote
Old 11-20-2012, 08:06 AM   #13
mhoerath
Member#: 131379
justablue hatch
