Old 11-18-2012, 05:43 PM   #1
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Default Air/Oil separator
Hi all I'm currently running stage 2 set up on my 2011 wrx. Current power mods are
Turbo back turboxs exhaust
And Cobb sf intake
I am currently in the process of deciding what mods I want to add before protune. As of right now I want a
Dw65 265lph fuel pump
Pw TMIC
Grimmspeed ebcs
Now my question . . . Is an air/oil seperator worth getting. Also I anybody recommends another mod or replacing one of these mods with something else let me know. Thanks
ryblair is offline   Reply With Quote
Old 11-18-2012, 06:09 PM   #2
424wrx
Member#: 171948
08 wrx vf52 swap
best et,[email protected]
i think you mean an air oil seperator. i have a grimmspeed aos. it helped with oil in my intercooler issues.
424wrx is online now   Reply With Quote
Old 11-18-2012, 06:11 PM   #3
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
That's exactly what I meant I was just about to change what I said lol. Thanks for the reply what issues were you having without it?
Old 11-18-2012, 07:28 PM   #4
424wrx
Member#: 171948
08 wrx vf52 swap
i was getting blow by issues. my perrin tmic was geting alot of oil inside and making the lower tmic hose loose. it wasnt enough oil to need a top off between changes. its just not good to have too much oil in there cause it can lower the octane and cause detontation.
Old 11-18-2012, 07:59 PM   #5
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Good stuff!
Our set ups whether stage 1 or 4 should have 1 installed IMO
sense of nature is offline   Reply With Quote
Old 11-18-2012, 08:14 PM   #6
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Well thanks for the info guys looks like I will as it to my list. Any other mods I should possibly add? I don't think injectors are necessary until turbo upgrade am I right?
Old 11-18-2012, 08:18 PM   #7
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
I've been debating on getting an air/oil separator myself. From what I've read the Crawford is the way to go but so far I haven't had any problems without one. I do drive the car pretty conservative.
Mods.. Invidia tbe, AEM intake, Forge bpv, Grimmspeed ebcs, Process West tmic, protune.
ERL2011wrx is offline   Reply With Quote
Old 11-18-2012, 08:23 PM   #8
424wrx
Member#: 171948
08 wrx vf52 swap
grimmspeed aos has been proven to be more than enough for most dd cars. tracked cars would be better with a crawford system.
Old 11-18-2012, 08:23 PM   #9
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
It's all in what you want and your future plans. A fuel pump and injectors wouldn't be a bad idea but not "needed" if you never plan on running an E85 tune or upgrading the turbo. My IDC was at 95% with stock injectors on pump gas so it's pushing the limits. You could always do an EWG before the tune also.
Old 11-18-2012, 08:47 PM   #10
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
AOS's are fairly useless.
Old 11-18-2012, 10:20 PM   #11
Ballistic1350
Member#: 156877
04 sti
Proof to said statement?
Ballistic1350 is offline   Reply With Quote
Old 11-18-2012, 11:08 PM   #12
rob1n1
Member#: 276425
2013 335is
Alpine White
All catch cans?
rob1n1 is offline   Reply With Quote
Old 11-19-2012, 12:05 AM   #13
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Eventually I would like to upgrade the turbo but not now. Ewg seems like a great idea and I would like to do it but isn't it expensive? Last I check its like a 600 dollar mod and that's if you install it yourself. Correct me if I'm wrong. And also do you guys think m stock injectors would be fine until I do upgrade the turbo? I was planning on just the fuel pump for now as far as fuel mods go
Old 11-19-2012, 06:48 AM   #14
424wrx
Member#: 171948
08 wrx vf52 swap
why are you a mod now? all you do is spurt out stuff like a mini unabomber. its getting old. proof about your statement??
Old 11-19-2012, 08:20 AM   #15
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Proof is the MILLIONS of cars that have blow by (hint all of them in the past 40+ years) that not once needed an AOS or catch can. Blow by still happens. Blow by is not a horrible thing. Where is the evidence showing an AOS/Catch can has extended the life of a motor? I trust car engineers, if it was needed there would be one.
Old 11-19-2012, 11:17 AM   #16
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Hinshaw, there is one built into your engine...it just isn't a very good one when you add power and mods. It's like saying you trust the engineers did a good job on the pistons and therefore will never have to worry about them.
drewvdw is offline   Reply With Quote
Old 11-19-2012, 11:36 AM   #17
WRXLTD
Member#: 136314
2014 Grand Cherokee
This is what happens when WRX owners become Moderators...
WRXLTD is offline   Reply With Quote
Old 11-19-2012, 01:55 PM   #18
apexslider
Member#: 168101
15 BRZ Limited
SS
This^^^^^
apexslider is offline   Reply With Quote
Old 11-19-2012, 02:17 PM   #19
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
One can argue they used the "weaker" pistons for cost saving measures. But let's not go into ringland issues.
I've always been against AOS's. And as much as most people like to say it, my opinions have stayed the same since becoming a MOD, and being one has nothing to do with them.
Simple fact is, one can be MADE for cheaper then bought, and the money can be used for better needs.
Old 11-19-2012, 05:35 PM   #20
pippen
Member#: 171290
2008 STi
well that sucks.. just bought the GS AOS.. how can i make one lol
pippen is offline   Reply With Quote
Old 11-19-2012, 08:51 PM   #21
guygettnby
Member#: 298231
2011 WRX
Do a quick google search for the $20 catch can. May not be what your looking for but they work lol
guygettnby is offline   Reply With Quote
Old 11-19-2012, 11:22 PM   #22
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
You have almost the exact setup im working towards, how dramatic were the gaine from the tmic and grimmspeed ebcs with a protune, those are my next steps.
And as far as the aos goes i dont know what to do about it know. Im starting to think ill do that down the road. I had just read somewhere that it was a good safe mod when running 91 oct. Thats all i can get here in nevada it sucks. and no e85 here. My friends evo is now running on meth at 430whp its insane. The meth made a huge difference besides having to refill it all that time haha. Once again thanks for the replies guys much appreciated. I may just call a well known tuner i may go to. . . if i can find one in slc or reno and ask what he thinks.
Old 11-20-2012, 01:03 PM   #23
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
It was a nice gain in power. Not a lot on top end but huge gains in the midrange. The car is smooth and very fun to drive now. Every car and dyno is a bit different but I ended up with 315whp/342wtq @ 20.5psi on 93 octane. I can PM you the graph if you want to check it out.
Old 11-20-2012, 01:12 PM   #24
WRXLTD
Member#: 136314
2014 Grand Cherokee
I running a GS AOS because I don't want to be emptying a catch can all the time.
Old 11-20-2012, 01:14 PM   #25
pippen
Member#: 171290
2008 STi
The GS EBCS is my favorite mod so far.. the thing works magic. Definitely worth the $100 or whatever it is.
