Old 11-19-2012, 03:48 AM   #1
kcook737
Member#: 331453
2002 BUGEYE
(DRUNKMANN TUNED)
Question few questions about python remote start 02MT
so, ive somehow talked myself into trying to install this again, (first attempt ended with procrastination) and im finally making progress. im having a few issues figuring out where a few wires go and if anyone can help id appreciate it. also if i have made mistakes please point them out, ive had to compile my data from multiple sites!!!!!!
python 5204P / 02 wrx manual transmission
WIRE PIN- COLOR- POLARITY
CONNECTION/CONTROL-COLOR (IN CAR) -LOCATION (IN CAR)
h3/1 pink (+)
ignition 1 input/output> Black/green [ignition harness]
h3/2 red/white(+)
ignition 2/flex relay input 87 (fused 30a)>
h3/3 orange(+)
accessory output>black/blue [steering column]
h3/4 violet(+)
starter output >black yellow [ignition harness] *car side*
h3/5 green(+)
starter output >black yellow [ignition harness] *key side*
h3/6 red(+)
ignition 1 input (fused 30a)>
h3/7 pink white(+)
ignition 2 flex relay output>
h3/8 pink black(+)
flex relay input 87A (key side) of flex relay>
h3/9 red black(+)
accessory/starter input (fused 30a)>
h3/10 No Connection
ive been replied to with this in the past:
"Pink - hook up to ignition wire at ignition column.
red/white,red,red/black - hook all wires together, and hook up to 12V wire at ignition column.
orange - hook up to accessory wire at ignition column.
violet - hook up to starter wire at ignition column.
green - dont hook up
pink white - dont hook up unless you want starter cut.
pink black - dont hook up unless you want starter cut."
but it kinda confused me because some of the stated connections contradict what ive found other places.. im not 100% sure what im looking for to begin with so if possible a color/description would be helpful!
oh and before you even start, ive searched the forums ive looked around, but i cant quite find what im looking for. and dont give me crap about installing myself or on a manual tranny. i know the risks. get off it.
many thanks guys
kcook737 is offline   Reply With Quote
