Old 11-20-2012, 11:28 AM   #26
BrendanTheGreat408
Member#: 271207
2011 WRX
Originally Posted by NoGraffix View Post
It was a simple over-boost. It sounds like you attempted to go WOT in too high of a gear (5th?) where you had a high load situation. Since you didn't mention you had an EWG I'm assuming you dont and your IWG was unable to compensate for the amount of air the car was flowing. This caused the turbo to pressurize an excess amount of air. The MAP sensors saw you reached a certain defined limit and cut the fuel in order to stop the over boosting.
You learned a lesson; don't go WOT in high gears, always down shift. You can also inform eric of this happening and he can likely adjust the WGDC and TD tables to help prevent this (possibly even raise the limit since 21 psi isn't all that high). It's likely he wuill tell you to stay off WOT when in a high gear situation.
It actually happened in 4th around those exact RPMs however I dont think i was WOT when it happened since I was still in between getting the tune finalized.
An EWG is the only fix for a true boost creep/spike. If its poor tuning or the stock bcs issue those can be fixed with well proper tuning and a 3-port solenoid. Porting the IWG can help, but often you will still experience creep if your running an excess of 21 psi (as me how I know). Sounds to me like the OP has a case of unfinished tune. He put a new top mount on, the tuner turned up the boost a bit (since he can now, no more crappy plastic end tanks) and hasn't fully adjusted the WGDC or TD tables to properly achieve targeted boost.
I plan to add my EWG via protune soon
BrendanTheGreat408 is offline   Reply With Quote
Old 11-20-2012, 01:33 PM   #27
Tripintaz
Member#: 245218
2013 STI Limited
09+ cars boost creep easily when an aftermarket intake is used along with a catless turboback exhaust. You might be able to tune some of it out, but I would bet the OP's WGDC's are at 0% when he saw overboost in 4th gear. A 3 port EBCS can help as well, but you cant tune the WGDC below 0%. The best advice for the OP is either EWG or throw the stock intake back on and adjust the tune. The EWG will solve the boost creep. The stock intake and re-tune may not completely eliminate the problem but it would make it less of an issue.
Tripintaz is offline   Reply With Quote
