Old 11-30-2012, 01:27 PM   #26
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Originally Posted by patrickyazon View Post
argghhh... which section is it at? Im getting all excited here...
sorry i thought you were blurr..
did that fog light from ebay have that chrome cover around the fog lens?
If its between $250-300, it will have the chrome exterior housing. The link I posted to ebay is just for the lights themselves. What you see is what you get.
Blur125 is offline   Reply With Quote
Old 11-30-2012, 05:19 PM   #27
patrickyazon
Member#: 334670
2012 Impreza Premium
Ice Silver
Originally Posted by Blur125 View Post
@patrickyazon: If you shine a flash light through the port covers, you will see a connector. I'd be shocked if it wasn't there, but then again, the plug for the switch isn't removable, so it wouldn't be the first shock I've experienced so far...
sorry im ignorant....the port cover is where the fog light will be mounted?
if you refer to the pdf file Section#13 A. WHere is that A wire located?
would help if you post pictures...
some other guy said just look for it under there...
so the nuts did not come with the fog light from ebay?
patrickyazon is offline   Reply With Quote
Old 11-30-2012, 07:11 PM   #28
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Step 1: Get down on your knees
Step 2: Bow to me
Step 3: Where your fog lights "would be", shine a light through the honeycomb looking port cover (Figure 10 in PDF)
Step 4: You should see the connector on the side adjacent to the radiator. Its plugged into a dummy port with Green/White wiring.
Again, for the ebay link, what you see, is what you get. No nuts/bolts, switch, relay bezel, nothing. Just the lights. You could go to a dealer and see how much the additional parts will be. My estimate is about $100 + the lights, but I haven't actually done any of the work yet so I don't know.
Here's a parts site and you can research yourself:
https://www.1stsubaruparts.com/partscat.html
Old 12-02-2012, 08:33 PM   #29
bigheathbar
Member#: 339326
I'd just like to take this time and state that idk about 2012s but on the 2013.. The fog lights are terrible..
bigheathbar is offline   Reply With Quote
Old 12-02-2012, 09:02 PM   #30
97OBLimited
Member#: 224432
1997 Outback Limited
2012 DGM Impreza Hatch
I just picked up a 2012 without fog lights because i knew they would be basically useless. I plan on grabbing a set of Hella projectors and mount them in the factory location. Might have to fab up a bezel or cut the block off plates but I know it will be worth it. I also have the sport grill and am considering getting a set of Hella Black Magics to throw behind the grill. Nearly invisible when off but massive light when they are on.
97OBLimited is offline   Reply With Quote
Old 12-02-2012, 09:29 PM   #31
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Wow never seen those Hella driving lights before, cool technology! Any idea which specific model fog lights you'll be going with? Far as I've read, the stock lights with a yellow tint make them great for fog, but no real difference as driving lights.
Also, the real ticket is to retrofit the headlights with projectors. Looks too involved for my skill level, but man are they sweet.
Old 12-03-2012, 12:17 AM   #32
patrickyazon
Member#: 334670
Ice Silver
did you get an HID kit for it>? Im sure you know that there are tons of kits out there.. but I bought The Onex brand for about $50 bucks.. cheap upgrade and its super bright and I'm waiting for the LED bulb DRL Highbeams!
Old 12-03-2012, 12:18 AM   #33
patrickyazon
Member#: 334670
Ice Silver
Step 2: Bow to me
hey thanks for all the info!! Im waiting for Santa to deliver my FOglights!LOL
Old 12-03-2012, 11:38 AM   #34
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Cool! Just an FYI, you might talk to this guy. I just bought a set of stock fog lights for $150 shipped. Don't know if he has any left, but worth a shot!:
http://forums.nasioc.com/forums/show....php?t=2418590
Old 12-03-2012, 11:39 AM   #35
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
So question...you are running HIDs without projectors. Typically, this is not optimal, as there can be too much light scatter (vs. a focused beam). What's your opinion on that?
Old 12-03-2012, 02:55 PM   #36
patrickyazon
Member#: 334670
Ice Silver
well... yes and no....it's still better than the regular Halogens!!and besides I like the way it's spread out....as long as it doesnt bother the oncoming traffic!LOL
Old 12-04-2012, 06:35 AM   #37
Guzzi 1
Member#: 338666
2013 Impreza Premium
Dark Grey Metalic CVT
hey there, I have 2012 prem too, and i was checking under the hood where the fog lights will be mounted and I did not see any wiring though...
this would make it more difficult for me to run the wires then?Argghh
You will not find the plugs under the hood. When you take the inner fender loose under the car, the plug is right there near where the lights end up. You do not have to run any wires for the install.
John
Guzzi 1 is offline   Reply With Quote
Old 12-04-2012, 01:43 PM   #38
patrickyazon
Member#: 334670
Ice Silver
John
hey thanks! blurr pretty much described the location of the plugs...and I actually saw it! Now the question is, could we change the Bulbs?
to HIDs or any after market yellow bulbs?
Old 12-04-2012, 07:37 PM   #39
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
The bulb is listed as 2504, see here:
http://bit.ly/VkOI3w
2504 is not a common bulb type...so might take some research to figure what will work. It may also be: PSX24W
So you could do search for an HID kit or something like that.
One example: http://www.blindinghid.com/b.php?bulb=2504
As for me, I'm just going to cover with yellow tint such as this:
http://www.jdmfanaticvinyls.com/12-1...6_7911132.aspx
Old 12-04-2012, 07:48 PM   #40
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Seems like this guy has got the right idea with his lighting:
http://forums.nasioc.com/forums/show....php?t=2369342
Old 12-05-2012, 12:28 PM   #41
patrickyazon
Member#: 334670
Ice Silver
Yes.I guess so..dunno know about the tinted taillights,,,,looks cheesy...
just my opinion..
Old 12-06-2012, 02:56 PM   #42
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Originally Posted by dcon9999 View Post
so got everything installed today except the lights themselves (which look like the easiest part). I'll post some pics next weekend.
Where's your pics guy?
Old 12-06-2012, 06:16 PM   #43
patrickyazon
Member#: 334670
Ice Silver
,..I just installed a set of the led bulbs (9005) for the highbeams, they look really nice but the downside is it deleted the HIghbeam itself! I guess its just for the DRLs....
Old 12-12-2012, 12:48 PM   #44
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Thought I'd post a pic of the switch bezel, as you will need it for installing the OEM fog light kit. You don't, however, need the fog light bezel. The only advantage to replacing is the kit comes with a chrome ring around lights (vs. stock all black bezel)
Old 12-15-2012, 07:56 PM   #45
kzinti
Member#: 340730
I just installed the switch and the relay on an Impreza 2013.
Installing the switch was a trivial thing to do, took about 15 min. I did ruin the original bezel by removing the blank plates from it. If you care about it, be very careful when pulling the blank plates.
As for the relay... Well I spend over 1h30 trying to remove the glove box without ever managing to properly do it. In the end I was able to put the relay in and put back everything together (watch out for the glove box light that keeps popping off).
I wish I had checked under the glove box before any of this, because it turns out that the relay panel is in plain sight and easily reachable without having to do anything. Just lay on your back with your head under the glove box and your legs outside the vehicle. The relay panel is right there above you and the slot you want is the closest one (bottom right).
Still have to install the lights, I'll probably do that tomorrow.
kzinti is offline   Reply With Quote
Old 12-16-2012, 12:50 AM   #46
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Haha I had the opposite experience. Switch bezel was a pain in the butt and I definitely ruined the old plate getting the switches out. I definitely wouldn't think about cutting the original plate for the fog light switch, it wouldn't look pretty unless you deem yourself skilled in plastic cutting.
Relay wasn't as bad for me, glove box came right out when you disconnect the catch on the right side. I pulled way more screws though than the install manual called for. Almost freaked out when I saw white padding, thinking it was my airbag. I was lucky it was only padding between the plastic and airbag container.
Lights were pretty simple, just remove body clips and one screw to get access to the light ports. Had to pull on the wiring a little bit to get the slack I needed, but all is well and the lights work great.
2 Things I noticed though:
1) There's a slight hum when the car is on but not started.
2) There's a slight gap between the lights and light bezel, which could allow for moisture to get in.
Anyone else have that, or for those with stock lights installed, do you see a gap?
Old 12-17-2012, 01:22 AM   #47
kzinti
Member#: 340730
I finished up the work. Installing the lights was pretty straightforward.
I do notice a hum coming from the main headlights. I didn't notice this before you pointed it out and had the fogs installed, but I doubt it has anything to do with this installation. Unless you activate the fog light relay, there is nothing electrically different than before. And again, the hum is coming from the main headlights.
Old 12-17-2012, 01:14 PM   #48
patrickyazon
Member#: 334670
Ice Silver
let me see the front ....
Old 12-17-2012, 03:31 PM   #49
kzinti
Member#: 340730
The humming/buzzing sound isn't there when the headlights are cold. That explains why I never noticed it before.
Old 12-17-2012, 05:07 PM   #50
Blur125
Member#: 88514
2012 Impreza 2.0i
Dark Gray Metallic
Is there a gap between the lights and the chrome bezel for you?
Message Board Statistics All times are GMT -4. The time now is 10:16 AM.
