Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 09-11-2002, 08:59 PM   #1
WReXinEfX
Member#: 20405
2000 OBS WRX Swap
Green
Default Need Suby Shop in Queens - LI area for Oil Change.
I typically would go to the locals for a quick lube, my car just made it to 2000mi and I'm looking to go Mobile 1 5w-30s
However I know not all quick lube place may carry the WRX oil filter, any of you guys know a good place in Queens or LI that does oil changes at a reasonable price??
WReXinEfX is offline   Reply With Quote
Old 09-11-2002, 09:06 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's reaaallly easy to do it yourself, and it's an opportunity to bond with the car
The oil filter is a Purolator L14460, readily available at your local parts store. Purolator makes 'em for Subaru so it's essentially the same as the OEM one.
Don't ever go to a quick lube place, that's the equivalent of going to a witch doctor for surgery
Old 09-11-2002, 09:08 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
2000 mi sounds kinda early to be putting in synth.
The WRX filter isn't anything special, you can use anything designed for pretty much any Honda/Acura.
RidinLow is offline   Reply With Quote
Old 09-11-2002, 09:54 PM   #4
gldenchld
Member#: 19994
I usually go to TMOC right across the street from Nassau Col. they are pretty good and I used to use 5-30 mobil 1 but was told it is too light for the car and use 10-30 mobil 1 now.
gldenchld is offline   Reply With Quote
Old 09-11-2002, 09:57 PM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
I use 5w30 in the winter and 10w30 in the summer, although in theory, 5w30 should be fine in the summer too.
Old 09-12-2002, 08:55 AM   #6
Rich10
Member#: 14934
I also use 5w30 in the winter and 10w30 in the summer. BTW, it is very easy to change the oil on a WRX. It should take 15 minutes or less.
Rich10 is offline   Reply With Quote
Old 09-13-2002, 01:21 AM   #7
atomicapples
Member#: 12626
02 2.5 rs
yes it is very easy to change the oil...
but what i hate is the plug is on a angle. plucking oil always has a mind of its own.
but the good thing is. the oil spills out at like 400mph. oil is drained in like 2 mins.
atomicapples is offline   Reply With Quote
Old 09-13-2002, 01:21 AM   #8
atomicapples
Member#: 12626
02 2.5 rs
Subie shops in the Seattle area? Subiecalifragilistic North West Impreza Club Forum -- NWIC 15 09-24-2008 05:11 PM
any good alum/tig welding area in queens/LI area? SQC120 Tri-State Area Forum 2 05-29-2007 03:10 PM
Any shops in Queens/LI with Hunter Tire machine? PinnacleChronos Tri-State Area Forum 13 06-08-2005 01:11 AM
Need Subie Shop in Atlanta RoadRageDev South East Region Forum 19 01-12-2005 03:53 PM
any recommended shops in queens/LI? atomicapples Tri-State Area Forum 1 09-15-2003 07:53 AM
