Old 11-19-2012, 07:20 PM   #1
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Default unequal length header leak?
Has any body else had an issue trying to get their header to seal right at that slip joint where the two pipes come together and if so what have you done to seal it thanks
illest2.5i is offline   Reply With Quote
Old 11-20-2012, 12:14 AM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Some people weld them. Mine don't leak.
Old 11-21-2012, 11:39 PM   #3
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
bugeyetex is offline   Reply With Quote
Old 11-26-2012, 07:55 PM   #4
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Where would i get this stuff or should i weld it im pretty good at stainless welding
Old 11-29-2012, 07:56 PM   #5
klaus_b2
Member#: 318411
17 WRX
CWP
you can probably get it at any auto store. i wouldnt recommend welding..itll be a ***** if you have to take it off in the future
klaus_b2 is offline   Reply With Quote
Old 11-30-2012, 07:44 PM   #6
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
A little off subject, when I did my exhaust the first time removed mY resonator no problem with the original header but now that I have an UN equal length header and no cat I get the horrible rasp with a little subie rumble should I put in a stock resonator or go for an after market one
