Old 03-26-2013, 04:15 PM   #426
voltic
Member#: 310385
Chapter/Region: HIIC
2016 BRZ Limited
Series.HyperBlue
Hey everyone, stay tuned to this thread for a custom Nexus 7 boot screen I'll be posting up tonight around 11pm. It'll be for STi only, but I can possibly make more if there's demand. Video to follow in an hour or two. I have no plans on changing the Google splash screen due to the complexity.
Demonstration Video
Thanks to GOFASTSTI over on IWSTI for the base image!
voltic is offline   Reply With Quote
Old 03-26-2013, 04:58 PM   #427
P.J.
Member#: 116369
2012 STi sedan
silver, Stage 2
you all are talking about menu screens for a Nexus 7 as headunit
I use "Car Home Ultra" as seen below.
Link and detail to my convertible tablet install: http://forums.nasioc.com/forums/show...3#post38633243
P.J. is offline   Reply With Quote
Old 03-26-2013, 07:02 PM   #428
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Really great work to all of you on the N7 integration. lots of great information in this thread.
I'm slowly finalizing my designs for a complete gauge cluster replacement using Torque and a Nexus 7. This will be in my 06 WRX, so there's nothing particularly interesting or mission critical in the cluster that Torque can't replicate. Currently the plan is to not use it for anything other than displaying gauge information. My Note 2 handles BT media streaming, calls, and navigation.
I think i have a path forward on controlling power and charging in a semi-permanent mounting solution, given my own research and the information in this thread.
As far as torque is concerned, the only thing i'm having trouble with is fuel level. I assumed fuel level was reported over OBDII in my car, but Torque does not seem to think so. Has anyone had any luck getting Torque to report fuel level in a GD or GR?
mechatricity is offline   Reply With Quote
Old 03-26-2013, 07:03 PM   #429
imrocksolid
Member#: 344254
2011 WRX STI
Pearl White
Originally Posted by voltic View Post
^ What's that custom home screen deal you have going on? I like it.
It's a photo shopped background. I used UCCW to make "invisible" widgets that I put over the words/buttons.
imrocksolid is offline   Reply With Quote
Old 03-26-2013, 07:40 PM   #430
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
Updated my post with a demo video. I'll release a CWM-flashable and a bootanimation.zip that you can install manually here tonight.
I suspected that's what you did.
Old 03-26-2013, 07:45 PM   #431
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
I can't speak for Torque, because it lacks USB support entirely, but I know my car (GR) reports it to DashCommand, so there's definitely a working PID for it somewhere.
Old 03-26-2013, 11:17 PM   #432
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
STi Boot Animation for the Nexus 7
Downloads:
CWM Recovery Flashable ZIP
Manual Install bootanimation.zip File
Thanks to GOFASTSTI at IWSTI for the excellent base image!
I don't currently have any plans of releasing this with other logos (eg., WRX, Subaru), but if enough people want it, I can probably be easily persuaded.
Yes, the spinny loading wheel loops much longer than this when installed.
Old 03-27-2013, 11:34 AM   #433
RobPaulson
Member#: 348679
2013 WRX
does the GPS react well for navigation? Meaning, is there any kind of delay or trouble connecting to the satellite?
has anyone used a 3g (or some data enabled) tablet? does it being in the dash kill your signal?
RobPaulson is offline   Reply With Quote
Old 03-27-2013, 11:42 AM   #434
RobPaulson
Member#: 348679
2013 WRX
Old 03-27-2013, 12:57 PM   #435
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
A few millimeters of plastic isn't enough to attenuate GPS in any noticeable way, and certainly not mobile data. Everything works fine.
Old 03-27-2013, 02:49 PM   #436
debbinkm
Member#: 227167
2011 WRX 5dr
Thought I'd throw my project up here for anybody who's thinking of doing this. It's not too difficult and I am loving it so far. Nothing too new as far as unique things I did, just took ideas from this thread as well as this thread.
Installed the USB DAC and 4-port hub in today and it sounds awesome. Still want to do some more testing with power (I have
thisthis
soldered onto the 12V switch wire and seems to be doing fine so far at keeping my tablet charged).
I relocated my head unit (Sony single-din) to under the passenger's seat and just use the AUX-in port on that to send sound to the speakers. ASWC Axxess for steering control (volume control mostly, but mute works, too, which is useful).
I'll be glad to answer any questions people have about the setup. Thanks to everyone who did this before me for the inspiration and answering my questions!
debbinkm is offline   Reply With Quote
Old 03-27-2013, 04:58 PM   #437
onsit
Member#: 292225
08 WRX (16g)
Installed the USB DAC and 4-port hub in today and it sounds awesome. Still want to do some more testing with power (I have this soldered onto the 12V switch wire and seems to be doing fine so far at keeping my tablet charged).
I can tell you are using USB Host ROM by Timur? Great ppi adjustment and such from that rom.
A few questions, I have been trying to get OTG + Charging to hook up to a USB hub. But I can seem to work out why it wont charge.
I use:
Amazon.com: StarTech.com Micro USB Cable - A to Right Angle Micro B (UUSBHAUB1RA): ElectronicsAmazon.com: StarTech.com Micro USB Cable - A to Right Angle Micro B (UUSBHAUB1RA): Electronics
And a USB Y power cable... However maybe im not using the right cable.
Mind linking the 2 cables you purchased, and the wiring behind it? Seems like it wont accept power.
onsit is offline   Reply With Quote
Old 03-27-2013, 05:09 PM   #438
debbinkm
Member#: 227167
2011 WRX 5dr
No problem. As I said before, the power is supplied by
this chargerthis charger
(just soldered ground and 12V switch wires to the contacts), then from there it goes:
  1. Startech.com Micro-USB CableStartech.com Micro-USB Cable
  2. Micro USB OTG "Y" CableMicro USB OTG "Y" Cable
  3. Amazon Basics 4-port USB HubAmazon Basics 4-port USB Hub
  4. FiiO E10 USB DACFiiO E10 USB DAC
The other end of the "Y" cable plugs into the tablet, although I had to cut and solder on a 90 deg male because the straight plug didn't provide the clearance needed for the trim to snap back on.
Yeah I'm using Timur's Fixed Install Kernel on top of JDX (13.2 at the moment) and it seems to work great. Make sure you read about how to use the kernel (ie. you have to boot with everything plugged in, etc.). Everything pretty much worked out of the box for me though. Try plugging it into the AC plug that came with your N7 maybe to make sure it's not a problem with the power supplied in your car. Good luck!
Last edited by debbinkm; 03-27-2013 at 05:12 PM. Reason: Lists not formatting correctly...
Old 03-27-2013, 05:18 PM   #439
debbinkm
Member#: 227167
2011 WRX 5dr
Also, although I'm not really using the USB Hub yet, I did test plugging in a USB flash stick and mounting it with StickMount and it works fine alongside the USB DAC. Plans are to wire up the USB port that is in the armrest to the hub so that I can just plug a USB stick in there with all my music and update it without taking the dash apart.
Old 03-27-2013, 05:35 PM   #440
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
So from what I've had the DAC has to be plugged in at boot to be recognized. Do you have any issues resuming from sleep after turning the car back on with the DAC not being recognized?
Old 03-27-2013, 06:01 PM   #441
debbinkm
Member#: 227167
2011 WRX 5dr
Nope haven't had any issues with that. With Tasker, I just have my tablet turn the screen and WiFi off so I'm not sure if that's what you mean from "sleep". The DAC definitely loses power, but again, no issues reconnecting to the tablet when I turn my car on.
Old 03-27-2013, 06:31 PM   #442
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
Interesting. My E10 should be in tomorrow... I really want to make that acrylic box some of you guys have been doing. The metal bar and cork works well but removal and replacement is a bitch. Edit: Ignore what this line used to be if you already read it. I had a derp.
Old 03-27-2013, 06:54 PM   #443
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
I use:
My cabling setup:
12VDC 3 Amp USB Regulator from this Ebay seller
IVSO Nexus 7 Tablet Micro USB Host OTG CableIVSO Nexus 7 Tablet Micro USB Host OTG Cable
Apricorn USB Power Adapter Y CableApricorn USB Power Adapter Y Cable
The 3A regulator I use is similar to this one but mine has no micro-USB cable. I went with this so I could be sure that I'd be able to run 4 different devices at 500mA (will never actually happen) and still be able to have 1A dedicated to the Nexus 7.
Setup:
Regulator gets the male grey side of the Y-cable (power only) plugged into it.
Nexus 7 gets the female OTG cable plugged into it.
OTG cable gets male black side of the Y-cable plugged into it.
Female end of the Y-cable gets the USB hub plugged into it.
Regulator gets attached to switched 12v. Done.
I run Timur's full fixed installation ROM. I see no reason to run anything else since it's just a CM10 base with some added features in all the right places.
Old 03-27-2013, 09:25 PM   #444
Andrew025
Member#: 303408
04 STi
Since the USB DAC has to be plugged in at boot, do you know if the same applies to just using power + USB otg flash drive? I've been having a hell of a time with one of faux's kernels to get power + usb otg support.
Andrew025 is online now   Reply With Quote
Old 03-28-2013, 03:57 AM   #445
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
Charging with OTG enabled isn't an option in most ROMs, you should check to see if faux supports that. I went with Timur because there is no question and this is what it was built for. I haven't really dealt much with external drives and OTG. I'll probably be getting a flash drive here soon for it.
Old 03-28-2013, 04:08 AM   #446
Andrew025
Member#: 303408
04 STi
Charging and OTG does work with faux kernel, it's just a pain in the ass with making sure things are plugged in the correct order and such.
I was mostly wondering if it happened to be implemented a little better with the Timur ROM.
Old 03-28-2013, 09:24 AM   #447
debbinkm
Member#: 227167
2011 WRX 5dr
I went straight to the Timur kernel with mine (just because I was most familiar with it - hadn't heard of Faux kernel). Everything worked well as long as it was plugged in at boot. I even tried plugging in a USB flash drive after boot into the 4 port USB hub and it was recognized right away with StickMount.
Anyway, I would give Timur kernel a shot. It takes 5 seconds to flash a kernel and 5 seconds to go back if it doesn't work for you.
Also, I tried Timur's ROM (which is basically CM10.1 with Timur kernel) and it was okay, but JDX 13.2 with Timur's fixed install kernel seems more stable to me.
Old 03-28-2013, 11:00 AM   #448
onsit
Member#: 292225
08 WRX (16g)
Also, seems like Torque can now recognize USB OBD2 devices....
Curious if a Tactrix cable can be used as the connecting interface! Bluetooth is just too slow for engine updates.
Old 03-28-2013, 06:13 PM   #449
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
I've never had to tinker with orders of plugging things in.
How was the ROM unstable? I like it because of options that go beyond the kernel.
Yeah, I had Torque up and running last night over USB OBDLink... it was working great, way more responsive than DashCommand, like damn near instant feedback, but now it's not connecting. Android recognizes the device and launches Torque but then Torque says it can't connect. I really dislike the way these Torque gauges look, too. They're small and difficult to read, have you guys found a good skin?
Old 03-28-2013, 07:01 PM   #450
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
The gauge size in Torque is customize-able.
