Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 11-20-2012, 01:10 AM   #1
dmg
Member#: 82445
2004 WRX STI
Default Can someone take a pic of their throttle body vacuum lines? 03 WRX
I can not figure out where a vac line on the drivers side goes.
dmg is offline   Reply With Quote
Old 11-20-2012, 02:12 AM   #2
DabiDa
Member#: 307041
2002 impreza wrx
psm
Check out the Faq section you may be able to find a pic there..Or try to google it if anything has posted about it it will pop up and bring to the site,forum etc..
DabiDa is offline   Reply With Quote
Old 11-20-2012, 11:36 AM   #3
dmg
Member#: 82445
2004 WRX STI
Thnks Dabida but I already used google images and searched the site. I could almost see it in the thread about eliminating the coolant lines to the throttle body but not quite.
Old 11-20-2012, 11:50 AM   #4
biodude
Member#: 271720
which one on the drivers side? your not trying to connect the breather from the TGV motor are ya?
biodude is offline   Reply With Quote
Old 11-20-2012, 12:26 PM   #5
dmg
Member#: 82445
2004 WRX STI
The one at a 45* angle
Old 11-20-2012, 12:53 PM   #6
sorrowfulkiller
Member#: 170439
I <3 Lamp
If you are talking about the one that is on the intake manifold under the throttle body it goes to the bypass valve, most people who use a boost gauge also tap into this one.
sorrowfulkiller is offline   Reply With Quote
Old 11-20-2012, 02:17 PM   #7
biodude
Member#: 271720
I can only think of a few vac hoses on the drivers side,
one is about 1/4 in and its the one I mentioned that's for the tgv motor, it kinda just floating around.
another would be larger 3/8 maybe. and its to the brake booster. this hose goes towards the far left side near where the fuel rails hoses are.
off the TB itself there are two larger hoses, but those arent vac, they are for coolant
and then as sorrowfull said, the BPV hoses is often tapped for a pressure gauge.
Old 11-20-2012, 02:34 PM   #8
dmg
Member#: 82445
2004 WRX STI
Thanks, Biodude. It looks like the hose in your first pic but that one goes to the bypass valve on this car.
The one I am looking for is below the TPS, low on the throttle body.
Old 11-20-2012, 02:55 PM   #9
dmg
Member#: 82445
2004 WRX STI
This one
Old 11-20-2012, 05:52 PM   #10
biodude
Member#: 271720
Old 11-20-2012, 09:48 PM   #11
dmg
Member#: 82445
2004 WRX STI
Crap. What do I have attatched to the bypass valve
Old 11-21-2012, 08:20 AM   #12
biodude
Member#: 271720
moar pics please
Old 11-21-2012, 09:33 AM   #13
quazimoto
Member#: 70395
Originally Posted by dmg View Post
This one
That's not even on the throttlebody. It's on the intake manifold. And as stated,it goes to the BPV.
quazimoto is online now   Reply With Quote
Old 11-21-2012, 09:42 AM   #14
biodude
Member#: 271720
well..
Old 12-05-2012, 10:28 PM   #15
dmg
Member#: 82445
2004 WRX STI
I haven't had time to mess with it for a while. If that goes to the bypass valve, what goes to the TGV motor?
Someone else took this thing apart. I greatly appreciate the help.
Old 12-06-2012, 07:27 AM   #16
quazimoto
Member#: 70395
Nothing goes to the TGV motor. It is just an atmospheric vent tube.
Old 12-15-2012, 03:56 PM   #17
dmg
Member#: 82445
2004 WRX STI
LOL. Thanks guys. I am not as retarded as I seem, just not that familiar and someone else took this apart. Thanks, Again.
