Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-20-2012, 09:13 PM   #1
mikeamoss
Member#: 262723
1996 Impreza L Wagon
Maroon
Default Disc Brake Conversion
Hey there.
I have a 1996 Subaru Impreza L wagon. I was interested
in upgrading the brakes to 4 wheel discs. Currently the car
is a disc/drum setup. What car(s) could I source the needed parts?
Which parts will be needed?
What year Imprezas have compatible parts?
Any other models have compatible parts?
Should I look at upgrading the whole system (front and rear)?
Thanks for any help or info!!
mikeamoss is offline   Reply With Quote
Old 11-20-2012, 09:45 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
you can use the disk brakes from any legacy or impreza (not STI).
you will need the rear backing plates, rotors, calipers, and lines.
if you have single piston brakes in the front, you can upgrade to the duel piston calipers. you will need calipers, and rotors only.
-=Suberdave=-
suberdave is offline   Reply With Quote
