Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 11-20-2012, 11:14 PM   #1
Rodwrx23
Member Sales Rating: (76)
Member#: 170948
Default Driveshaft Shop Carbon Fiber Install and Review 04-07 Sti
After years of drooling of this piece, I finally scrounged up enough change together and bought this baby. I searched for install instructions, but couldn't find any so decided to combine my review and install for anyone else curious about how th throw this baby on.
Install difficulty: 3/10
Tools needed:
Jack
4 Jackstands
14mm socket and wrench
12mm socket (ratcheting open ended wrench is easier)
Rag or towel )for dribble of tranny fluid that comes out when driveshaft is removed)
1) Jack up all 4 corners of the car
2) Remove Midpipe (not required but I decided to do it for the extra room)
3) Remove the 2 14mm bolts retaining the center joint of the stock driveshaft
Make it look like this
4) Remove the 6 14mm bolts from the rear diff protector plate
6) Put the car in gear to prevent the driveshaft from rotating. Alternatively, tell your wife to push the brake pedal for you.
Using your 12mm open ended ratchet, remove the 4 12mm nuts on the propeller side of the rear joint to the rear diff. While the car is in neutral (or no brakes applied), rotate the shaft and put it in gear (or have your wife hold the brake) so you can get to 2 at once. Rotate to access the other two and repeat.
I forgot to take a pic of the removal, so here is one of them reinstalled on the Carbon shaft . Note how the flat part of the bolt faces inward and makes contact with a lip on the joint.
7) Pull the driveshaft out of the tail section of the tranny by pulling back. A little bit of oil will drip out so throw a towel or rag underneath.
8) Make fun of your stock driveshaft for being so heavy and goofy
9) Reinstall in reverse order and enjoy!!!
Rodwrx23 is offline   Reply With Quote
Old 11-20-2012, 11:17 PM   #2
Rodwrx23
Member#: 170948
Here are some pics to show the tons of clearance this shaft has
There is a little exposure from the tail section but I don't beleive it will be an issue
Old 11-21-2012, 07:17 AM   #3
WRXLTD
Member Sales Rating: (17)
Member#: 136314
2014 Grand Cherokee
Tell us how it performs on the street for God's sake !!!!!
WRXLTD is offline   Reply With Quote
Old 11-21-2012, 08:43 AM   #4
Rodwrx23
Member#: 170948
I will once I put some miles on it. I'm having trouble uploading before and after videos
Old 11-23-2012, 11:16 AM   #5
Rodwrx23
Member#: 170948
So after a couple hundred miles on this baby, all I can say is WOW! The car just wants to go at any rpm in any gear. Taking off in 4th gear at 2k rpm at 15 mph is no problem. No more chattering or vibration and it just picks right up.
The only concern I have is that I keep smelling tranny oil burning. My guess is because of the exposed part coming out of the tail section but I've had the car up on stands while running and can't see any leaks. Hopefully it's just the little bit if tranny oil that got on my wrapped DP during install still burning off.
Old 11-23-2012, 09:17 PM   #6
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Did you have that 'bounce' feel in lower gears when on/off throttle?
I've done all of the drivetrain mods on my 2012 WRX, and I think the 2-piece driveshaft is still a major weakness.
blehhh is offline   Reply With Quote
Old 11-23-2012, 10:49 PM   #7
Rodwrx23
Member#: 170948
No more bounciness or herky-jerky feeling. It is a hell of a lot smoother. I just put a stock clutch back in too and they balanced the whole assembly for me.
Old 11-23-2012, 10:56 PM   #8
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Someday I'll get one... someday.
Old 12-04-2012, 01:42 PM   #9
Driveshaft shop
Vendor Sales Rating: (0)
Member#: 306253
Nice write up, thanks
__________________
The Driveshaft Shop
1531 S. main st
Salisbury, NC 28144
800-564-2244
Driveshaft shop is offline   Reply With Quote
Old 12-04-2012, 07:02 PM   #10
Rodwrx23
Member#: 170948
Thank you guys for making this awesome piece of automotive pornography! I've fantasized about having one for years.
Old 12-14-2012, 01:48 PM   #11
fourseasonsandles
Member Sales Rating: (24)
Member#: 94816
06 STI EFI Tuned
EFI Block, GTX30, 278s
Thanks for this. I am planning to get a CF shaft from DSS in the spring. Just what I was looking for!
fourseasonsandles is offline   Reply With Quote
Old 12-29-2012, 12:02 AM   #12
Monkey king
Member#: 209401
2005 Sti
So did you notice any gain in MPG on this mod?
This is on one of my to do lists for my 05 STI and I'm glad to see your happy with the investment.
Monkey king is offline   Reply With Quote
Old 12-29-2012, 03:16 AM   #13
WaterfordRex
Member#: 311224
2011 Impreza WRX
I love step #8 hahaha. Has the burning smell gone away? Youre not leaking any fluid from the trans?
WaterfordRex is offline   Reply With Quote
Old 12-29-2012, 09:24 AM   #14
Rodwrx23
Member#: 170948
You're very welcome. I made it because I couldn't find one.
I did not notice any increase in mpg. Just much better driveability, throttle response, and reduced noise.
It did once I replaced the output shaft seal. $8 from the dealer and basically a reinstall of the shaft.
Old 01-09-2013, 11:02 PM   #15
10MTN-bugeye
Member Sales Rating: (3)
Member#: 288093
2002 Bugeye
PSM and parking lot scars
What is the deal with the gap between the ds and the transmission? I just bolted mine up, noticed the same gap, and assumed I had been sent the wrong length. Before complaining I figured I'd check other installs. Your's is the second write up I have seen that shows the gap/exposure between the transmission and driveshaft. I haven't seen any pictures showing a more flush install, so I'm going to assume it's normal for dss driveshafts.
10MTN-bugeye is offline   Reply With Quote
Old 01-09-2013, 11:27 PM   #16
Rodwrx23
Member#: 170948
Yup, it's normal for them. As long as you're not leaking any fluid because of a bad seal, don't worry about it. It won't hurt anything.
Old 01-10-2013, 03:33 PM   #17
Dr. octagon
Member Sales Rating: (40)
Member#: 171127
2015 Subaru
In for results on DSS paired with ej20
Dr. octagon is offline   Reply With Quote
Old 08-11-2014, 03:03 AM   #18
shaunisradd
Member#: 364909
2004 Subaru WRX Sti
World Rally Blue Pearl
Great write up, thanks for the heads up on the seal. saved me some time!
shaunisradd is offline   Reply With Quote
Old 06-29-2015, 12:12 PM   #19
cpasti
Member Sales Rating: (16)
Member#: 50582
A few tidbits to add to this, just installed over the weekend. Not sure if the above post was able to reuse the stock diff flange and the design has since changed, but the most recent CF DSS unit that now comes with 10MM larger hardened bolts. This requires you to remove the rear diff flange and enlarge the 4 bolt holes to fit.
Removal and modification is straight forward, use a 27MM impact socket to remove the nut holding the rear diff flange and carefully tap it off. Hold the flange in a vice and drill out the holes to fit (good two person job to ensure you're drilling straight and to keep lubing the drill bit). I used a 3/8" drill bit first, then finished it off with a 25/64" drill bit, perfect fit. Test fit the redrilled flange and bolts to the DSS axle and if all lines up, put the flange back on the diff then reinstall the new axle per above.
I'd also suggest having some diff oil and fluid pump to top off what drips out of the front diff at the output shaft and also what will come out of the rear diff when you remove the flange. You'll want an actual drip pan for the rear.
cpasti is offline   Reply With Quote
Old 06-29-2015, 12:28 PM   #20
cpasti
Member#: 50582
A few pics for reference
