Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 09-11-2002, 11:18 PM   #1
fookiethedookie
Member#: 19284
Default how to clean engine bay
what would be the best way to clean out an engine bay?
how can i get it really clean, like showcar clean.
fookiethedookie is offline   Reply With Quote
Old 09-12-2002, 08:24 AM   #2
SubaruPilot
Member#: 10461
bump
I would like opinions too please.
Thanx.
SubaruPilot is offline   Reply With Quote
Old 09-12-2002, 09:06 AM   #3
Rojorex
Member#: 19687
'02 WRB WRX
Non-sedan
I believe certain places will steam clean the engine. As to where to go to get it done... ???
Rojorex is offline   Reply With Quote
Old 09-12-2002, 10:04 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
simple green it... then powerwash it...
dry it off...
hit it w/some more simple green in any greasy/rough spots
aint gonna get much cleaner than that!'
Jamie
www.subiegalracing.com
Old 09-12-2002, 10:07 AM   #5
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
i found a place in new rochelle,ny that does it (steam cleaning/engine detailing), but that doesn't really help you florida/vermont people. i heard from a number of people that if you cover up the electronics/intercooler you can spray the engine with "Simple Green" then hose it down and start scrubing ("simple Green" eats paint too, so be careful where you spray it). Auto shops sell engine degreaser/cleaner kits in the waxes/polishes section. hope it helps. i know there was a thread about this in the archives too....
Darby is offline   Reply With Quote
Old 09-12-2002, 12:58 PM   #6
occhy
Member#: 20667
2002 wrx
blue pearl
Just go to your local detail shop. For $100 they will do the engine, buff your car and do the inside. It will make the engine look brand new. Worth every penny.
occhy is offline   Reply With Quote
Old 09-12-2002, 08:22 PM   #7
Hoos WRX
Member#: 23786
2003 WRX 5-speed
Yellow, Sonic Yellow...
Yeah, similar to Simple Green, you can try Spray9 (available at car parts stores) but it is more potent...
To finish, go mad with Silicone spray. It not puts a great protective coat on hoses, but also lubes the throttle body spring/wire, and puts a nice shine to everything...helps repel water as well.
Hoos WRX is offline   Reply With Quote
Old 09-12-2002, 10:09 PM   #8
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
i use "gunk" engine cleaner it works really good
hpracingwrx is offline   Reply With Quote
Old 09-13-2002, 12:25 AM   #9
zsurfrin
Member#: 11034
Platinum Silver
I think "gunk" and similiar degreaser are too harsh on the aluminum parts. I'd never thought about using simple green. I always clean the engine after i wash my car with the damp towel i used to dry my car. That way the engine always looks good and its not overwhelming task to detail it, when needed..
zsurfrin is offline   Reply With Quote
Old 09-13-2002, 11:50 AM   #10
TGC
Member#: 16255
2004 Mazda 3 5dr
2013 Mini Cooper S
I work at a detailing shop.... what we do is wet the whole front of the car down, engine and paint. that's to keep the degreaser from staining the paint. then we spray the whole engine down with degreaser (anykind will work). concentrating on really bad spots, and scrub them if possible. then power wash it clean. there's nothing that can be hurt by this. if your worried next time you go shopping get plastic bags and use them to covor up any worry spots. it'll keep that part dry. then once you use the power waher use a reagular hose and rinse everything off, incling the paint around the engine bay. then use a polish spray.... i can think of any off the top of my head but i'm sure you can find one.
it's that simple and if you do that every couple of months the engine will stay nice and clean.
hope that helps.
CHAD
TGC is offline   Reply With Quote
Old 09-13-2002, 01:23 PM   #11
gm6
Member#: 23622
what parts would need to be covered before spraying the engine?
gm6 is offline   Reply With Quote
Old 09-13-2002, 02:22 PM   #12
ppek
Member#: 15349
2002 Impreza WRX
The only thing I cover when I do mine is the alternator, and I know some folks who don't even do that. I use a small piece of tin foil, since you can form it really good around it. I also use simple green, and make sure I hose everything down (including the paint around the engine) before and after.
Paul
ppek is offline   Reply With Quote
Old 09-14-2002, 12:49 AM   #13
Subayai WRX
Member#: 18589
2002 WRX, Formerly
it was blue
Just go easy with the hose, and you should be OK. All engines are made to injest water in the engine comparment, else everything would die when it rains, and you go splashing through puddles.
I would recommend that no one steam clean their engines. I've known quite a few mechanics that spent days, and months trying to figure out all sorts of strange problems with customers cars, only for it to come down to corrided connectors in the engine compartment. Steam cleaning forces moisture into place that splashing water would not get to. Everytime it was in all the wiring connectors, like the fuel injectors, or any mid-wire connectors.
Subayai WRX is offline   Reply With Quote
Old 09-14-2002, 02:02 AM   #14
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Default Is this okay?
If I goto coin wash
Spray the whole engine with degreaser...
Power rinse the whole engine...
Spray the whole engine with water without cover anything...
Its not gonna hurt anything?
Once I start the engine when engine bay is WET, will I be okay?
I mean, risk free?
ImpreziveWRX is offline   Reply With Quote
Old 09-14-2002, 07:41 AM   #15
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
1. cover up alternator (unless you plan on leaving the engine bay open to air dry for a few hours
2. Simple Green - spray liberally on the engine bay
3. hose down
4. repeat
Ed
edkwon is online now   Reply With Quote
Old 09-15-2002, 01:18 AM   #16
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Thanks Ed
Old 09-15-2002, 02:10 AM   #17
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
One more thing, make sure the engine is cold. You dont want to spray water onto a a hot block. Can potentially crack. I dont have any personal accounts of this but i'ver heard it in a few places. Think of a chilled glass and pur hot water into it. same concept.
moogooob is offline   Reply With Quote
Old 09-15-2002, 04:23 AM   #18
Ugly
Member#: 19143
02 WRX
OK... since you all are talking so highly of simple green I want to get some to try it out. But... where do I get it? Does any random autoparts store carry it? Autozone? Pepboys?
Thank yas
Ugly is offline   Reply With Quote
Old 09-15-2002, 07:33 AM   #19
ppek
Member#: 15349
2002 Impreza WRX
You can get simple green at most stores. I got mine at autozone, and I have seen it at Meijer.
Old 09-15-2002, 02:29 PM   #20
Ugly
Member#: 19143
02 WRX
Cool... thank yas
Old 09-15-2002, 03:34 PM   #21
Beau
Member#: 24213
After you simple green it, try using CD-2 engine detailer. Spray it on everything, then wipe it off with towels. It cleans, shines and protects. I used this on my '91 Mustang and the original hoses (there was only one actually) looked new. I've gotten many compliments on how clean it is.
Beau
Beau is offline   Reply With Quote
Old 09-15-2002, 06:34 PM   #22
GeoT100
Member#: 16180
15 15' DGM STI
02' Bugeye
wd-40......does the trick
after you clean it and dry it add some wd-40
you shiet will shine like a buh!
GeoT100 is offline   Reply With Quote
Old 09-15-2002, 07:54 PM   #23
EJ22
Member#: 14561
96 impreza
black
WD-40 works great after you have cleaned it, then all the dirt sticks to the WD40,a nd you can easily powerwash it off, and reapply a fresh coat.
EJ22 is offline   Reply With Quote
Old 09-16-2002, 01:58 PM   #24
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
A while back I posted lots of pics of my engine cleaned and all.
those pics are gone now but it looked great.
heres the description:
I started by Spraying the engine down with a strong mist type spray on my nozzle. Then I did a more direct hard spray on parts. After that I sprayed some Simple Green all over and let it sit for about 10 mins. After the 10 mins I Hosed that off, then I wiped down some spots with a rag and then I blew all of the water out with a leaf blower. The last thing I did was spray stoners trim shine all over the plastic parts and I took pics right after, thats why it looks SOOO shiny. I already tryed starting it up and it ran fine even though I didnt cover the alternator or the battery at all so no need to worry.
Sometime around thanksgiving I will be cleaning the engine once again taking before and after pics to try and help people who are scared of hurting something that it is fine to put some water on it.
Bryan
2k2 is offline   Reply With Quote
Old 09-16-2002, 03:04 PM   #25
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
Default where to get simple green
you can get simple green at most grocery stores and hardware stores as well as autoparts stores...
How to Clean MAF 02 WRX RdRx02 Newbies & FAQs 10 06-02-2010 10:05 PM
Best way to clean engine bay? sabubarub Interior & Exterior Modification 18 11-29-2005 09:12 AM
Products to clean engine bay? g0tb00st Interior & Exterior Modification 40 08-07-2005 12:34 PM
how to clean engine bay fosgate769 Interior & Exterior Modification 14 01-10-2005 10:07 AM
How to Clean Engine Bay and Underbody? Josico Interior & Exterior Modification 1 04-20-2002 07:49 PM
