Old 11-21-2012, 12:33 PM   #1
twinturbomeow
Member#: 315546
03 wrx
Default Check engine Code P0457?
This recently came on after replacing both gaskets for uppipe, any advice on where to start looking?
twinturbomeow is offline   Reply With Quote
Old 11-21-2012, 12:36 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Moved to your specific powertrain forum.
Could be as simple as a loose gas cap or something more complicated. Up pipe has nothing to do with this code.
Old 11-21-2012, 01:27 PM   #3
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Do you smell gas fumes at all? Check for things like an open evap hose, loose gas cap, or the gas cap o-ring.
EDIT:
I probably won't be checking this thread again if you do happen to reply to it, so I'll just list more specific causes under this CEL code... check your drain valve (also known as a "canister vent valve"), check the hoses behind your alternator (you may have tugged one off while lifting the engine, if you did that is...), or maybe check the canister's purge solenoid. Hopefully it's something stupid like your gas cap being screwy, but it's probably related to the evap system. If you can't figure it out, bring it to a mechanic. Best of luck.
Mr Wrex is offline   Reply With Quote
Old 11-21-2012, 08:17 PM   #4
Strider327
Member#: 131280
2004 Impreza WRX
If not the gas cap. Check the evap canister and or the evap solenoid.
Strider327 is offline   Reply With Quote
Old 11-21-2012, 11:32 PM   #5
zman519
Member#: 118086
2003 WRX
Check the evap solenoid by the charcoal can. Unplug it & put 12 volts to the solenoid if it dose not click then you found your problum
zman519 is offline   Reply With Quote
Old 11-22-2012, 07:42 AM   #6
quazimoto
Member#: 70395
Type "P0457" into the search box and read the decades worth of causes and solutions......
quazimoto is offline   Reply With Quote
