Old 11-21-2012, 04:45 PM   #1
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Default Access bolt oil leak? Or something else?
I've had a small oil leak for about a month now, after putting 13K miles on this engine. I had investigated it earlier and determined it was almost certainly coming from behind the timing belt tensioner... Decided to fix it during the long weekend. After removing the tensioner, I was presented with what you see below.
Seems like it could be the access bolt, but I know of no way to pressurize the oil system and actually check it without starting the engine. So, should I pop this out, replace the seal, and hope my problem is solved, or could there be something else leaking in this area? Oil leak from the top of the water pump? Never heard of it. Something leaking oil further back or higher up? Anything else to check?
RP31 is offline   Reply With Quote
Old 11-21-2012, 08:54 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Not uncommon. I would find the torque spec and snug her down. Thew wrist pin access plugs on the front of our 05 were all loose and leaking at 50K miles :/
KillerBMotorsport is offline   Reply With Quote
Old 11-21-2012, 09:00 PM   #3
RP31
Member#: 123574
CGM STi
Thanks, I will do that. I've got some new seals for them on hand just in case. Could there be anything else in this area that's leaking? It doesn't look like it but I'm not sure if there's something behind the bracket that the tensioner mounts to.
Old 11-22-2012, 12:24 AM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
No nothing else, that looks like your leak.
Old 11-22-2012, 07:11 AM   #5
RP31
Member#: 123574
CGM STi
Found this in the FSM, posting it here for future reference in case someone is searching... Wrist pin access bolt torque spec is 51.4 ft-lb, and you are supposed to apply fujibond to it, and use the metal gasket/ring.
Old 11-22-2012, 07:20 AM   #6
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
Like killerB said, it is a pretty common issue, I see many cars that come into the shop with oil leaking from there, pull it off, fujibond it up and re-torque
carnz-pj-410 is offline   Reply With Quote
Old 11-22-2012, 08:23 AM   #7
RP31
Member#: 123574
CGM STi
Well ****... I don't know how this could have been the source of my leak... The damn thing stripped when I tried to remove it. No idea how I'm going to get it out now.
Old 11-22-2012, 10:02 AM   #8
RP31
Member#: 123574
CGM STi
Maybe we were wrong... Can the case bolts leak oil? I noticed that the tensioner bracket gasket to the top right of the access bolt had started to fail, degrading because of oil. It was hanging down, the adhesive had failed. When I realized it was only 4 quick bolts to remove the tensioner bracket, I popped it off and found the back of it, above the failing gasket, coated with oil. Looked around and the only thing I found was the case bolt to the left. It was coated with oil and grime, and actually looked a bit loose. Checked it and... It was loose! I tightened it back to spec.
I pulled my old block out and checked this out. It doesn't really seem like oil should be getting into this case bolt hole. Should I be worried if it turns out this was the source of my leak?
Old 11-25-2012, 01:19 PM   #9
RP31
Member#: 123574
CGM STi
I've got everything back together now, after tightening both the access bolt (after attempting to loosen it, just in case), and tightening the case bolt. So far no leak, but now my car is idling at ~17:1. Dammit! I've either got a leak somewhere, or the timing belt is off.
