Old 11-21-2012, 11:43 PM   #1
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Default My Sideways STI
UPDATE ON PAGE 5!
REBUILDING FOR 2013!
I decided to make this thread for kicks. I'm sitting at home, doing nothing.
I had a build thread on iWSTi for a while, but that got old really fast.
Anyways, here's my 2008 RWD STI.
I am the second owner of the car. Purchased the car early 2010, I did the conversion in January of 2011.
The rest was history.
Any questions? Ask.
Haters have fun.
Engine/Exhaust:
CP Pistons + Rings (100mm pistons)
ACL Rod/Main Bearings
Eagle Rods
ARP Rod Bolts
Gates Timing Belt
OEM Gasket Kit
OEM 11mm Oil Pump
Gates Super Strong Power Steering & Alternator Belt
Killer B Oil Pickup
Killer B Oil Baffle
OEM Nitrided Crankshaft
Air Pump Delete
Balanced Bottom End
Radial Valve Job
Perrin Cold Air Intake
Invidia Catless Downpipe
P&L Motorsports Catback
325WHP/360WTQ
Suspension/Bushings/Drivetrain:
-BC Racing Coilovers 8k/10k
-Perrin Super Steer Kit
-Shortened Front Endlinks
-Whiteline Steering Rack Bushings
-Whiteline Rear Diff Inserts
-Whiteline Rear Subframe Inserts
-6mm Inner Tie Rod Spacers
-Cusco Type RS 2 Way LSD
-Watanabe Service Drift Center Differential
-Exedy Stage 1 Organic Clutch
Interior:
-Sparco 345 Steering Wheel
-2 1/2 inch Shift Extender
-Powered By Max Hydraulic Handbrake
Brakes:
-Stoptech Stainless Steel Braided Lines
-Project mu HC Titan Kai brake pads
-Dual Rear Brembo Calipers
Exterior:
-Flat Black Mustache
-Flat Black Fog Light Covers
-Debadged and Stuff
-V limited front lip
-Rear Tail Light Overlays
I'm pretty sure I'm missing a bunch of stuff. LOL
Info/interview found here:
Interview with Jason Cancio – Creator of the RWD Subaru STI Drift Machine Breaking Drift News
jasoncanseeoh is offline   Reply With Quote
Old 11-21-2012, 11:43 PM   #2
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Most current pictures as of 11/2012:
A Few Random Videos:
<----- Won't embed for some darn reason.
Thank you all for all your love, hate, support, criticism, and compliments. Much appreciated.
Old 11-21-2012, 11:49 PM   #3
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Originally Posted by jasoncanseeoh View Post
Could you show more pics and elaborate on this? Very cool and have never seen a setup like that.
Digital Dillon is offline   Reply With Quote
Old 11-21-2012, 11:53 PM   #4
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Thanks, man. It was a fully custom setup done by 425 Motorsports. A second set of brackets were made to hold the second set of calipers. As far as elaborating on it goes, it locks up wayyyy better than my parking brake does, that's for sure. Haha. So initiating a drift is much more predictable.
Old 11-21-2012, 11:57 PM   #5
Digital Dillon
Member#: 288727
2008 WRX premium
Found a good video of it being done to a 240. so you have the normal e-brake. and then the hydraulic lever for the rear end?
Old 11-21-2012, 11:59 PM   #6
jdmjack
Member#: 248430
2003 PSM Bugeye
Love!
jdmjack is offline   Reply With Quote
Old 11-22-2012, 12:36 AM   #7
Spec-C 2010
Member#: 337849
What size rims are those they tuck perfect! Did you have to roll the fenders?
Spec-C 2010 is offline   Reply With Quote
Old 11-22-2012, 12:40 AM   #8
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
Haters will hate, **** em.
Awesome ride!
saar is offline   Reply With Quote
Old 11-22-2012, 12:43 AM   #9
Gex
Member#: 330000
05 LGT Wagon
RBP
Want to hate, but deep down I love it. Moar sidewayz
Gex is offline   Reply With Quote
Old 11-22-2012, 12:57 AM   #10
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
There's something about a sideways hatch that makes me smile! Nice work!
dburgoon is offline   Reply With Quote
Old 11-22-2012, 01:03 AM   #11
garudatwo
Member#: 322385
Minus the drifting on public roads, you're my hero! That's so badass
garudatwo is offline   Reply With Quote
Old 11-22-2012, 01:06 AM   #12
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Thanks for all the support guys!
Yes sir.
The white ones? Those are 18x9.5 +15. Fenders are rolled.
Old 11-22-2012, 01:09 AM   #13
garudatwo
Member#: 322385
Any chance you have videos of a run through a course? I'd love to see some more action scenes that are longer than 13 seconds (of the car from the outside, not from the inside).
Old 11-22-2012, 01:12 AM   #14
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Yeah, I couldn't get a few to embed, so I said forget it.
But here is a few.
Old 11-22-2012, 01:16 AM   #15
garudatwo
Member#: 322385
That's exactly what I was asking for, thank you sir! If you're ever in the NY area, I'll buy you a drink if you can let me ride shotgun around a few corners
Old 11-22-2012, 01:21 AM   #16
arf80
Member#: 125580
2011 WRX 5dr
What turbo are you running? Or is the built motor just for durability at high RPM?
arf80 is offline   Reply With Quote
Old 11-22-2012, 01:26 AM   #17
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Hahahaha. Even though you're all the way across the country, I suppose that sounds good to me!
Exactly. I spun a bearing early this year and I had to build my motor up to withstand what I put it through. Stock turbo @ 20 psi is more than I could ask for.
Old 11-22-2012, 02:45 AM   #18
Digital Dillon
Member#: 288727
2008 WRX premium
Consider a twin scroll turbo. You can make more torque at lower RPM's and with the revs down your car wont see as much abuse!
Old 11-22-2012, 03:01 AM   #19
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
I'm very satisfied with where my car is right now, but I'll take that into consideration. Thank you.
I have a few more things in mind for her, but as far as power mods goes, I'm really comfortable with how she drives at the moment.
Old 11-22-2012, 03:50 AM   #20
Silver Sedan
Member#: 259220
2005 RWD STi
So why is she "on vacation", Jason?
Silver Sedan is offline   Reply With Quote
Old 11-22-2012, 04:00 AM   #21
mt1101
Member#: 291990
2003 BUGEYE WAGON
so hot!
mt1101 is offline   Reply With Quote
Old 11-22-2012, 07:14 AM   #22
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
very cool. have always loved watching the videos that are floating around of the drifting. Nice to see someone doing something a little different with these cars. not much of a fan of the drifting on the public roads, but either way keep up the good work.
VTSubieRS is offline   Reply With Quote
Old 11-22-2012, 10:31 AM   #23
LeodCeb21
Member#: 311991
2007 wrx impreza
satin white pearl
the pictures are great! but im sure seeing you drift around in person would be even better...sweet ride/mods/idea! car looks great
LeodCeb21 is offline   Reply With Quote
Old 11-22-2012, 11:28 AM   #24
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Kyleeeee!!!! Well, she's been digging a hole in pocket since day one, I just want to live a normal life! LOLOL. Honestly though, I've even been talking to Melina about it.... I can't even remember the last time I bought myself a shirt because all my money goes into my car! And really, I've just been focusing on school. Setting my priorities, making sure the future goes well.
Originally Posted by mt1101 View Post
so hot!
Thanks man! Appreciate it!
Thank you sir. I appreciate that. I understand why people are putting down drifting on public roads, but as cliche as it may sound... it's really something else, it's a different feeling compared to the track. Don't get me wrong, I'm not sliding like every single freaking corner I see. Nor do I choose to drift when there is traffic/people around. I miss going to the track actually, I miss it a lot! But there are nights when a bunch of buddies and I get together and want to play around, so we find empty roads in the middle of nowhere. KEYWORD: EMPTY
Trust me, if anybody thinks I'm willing to crash my car and hurt anyone in the process, they're wrong. That is all.
Old 11-22-2012, 11:50 AM   #25
1VIPWRX
Member#: 107554
yellow
awesome man... keep it up
1VIPWRX is offline   Reply With Quote
