Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 11-22-2012, 01:19 AM   #1
Joe02wrx
Member#: 284636
2002 Wrx wagon
Default boost leak testing: disappearing boost problem
okay so recently i just put a air oil separator on my car and now when i boost leak test my car i have a problem. I should also say that now my idle AF correction is maxed out on learning view from RR but wide open throttle pulls doesnt pull any fueling maybe like two % which is okay.
The Problem: when i boost leak test my car i plug the little hose off the intake manifold that goes to the purge control valve, and i also plug the crankcase breather hose that goes into the into my turbo inlet. when i pressurize the system all air disappears. i do not know where it goes? if i pressurize my system and pull the hose off immediately that i just used to put air in the system no air even comes out.. can somebody point me in the right direction please? i know its long i apologize. could something be up with the idle air control valve where it just releases all the air?
Joe02wrx is offline   Reply With Quote
Old 11-22-2012, 05:25 PM   #2
Joe02wrx
Member#: 284636
2002 Wrx wagon
pulled off the throttle body to just clean in and saw that the gasket was blown. the piece between the idle air control valvle and the throttle body was barely hanging on. i believe i have found my problem but i won't know for sure until i can go to subaru and get a gasket tomorrow.
Old 11-23-2012, 09:42 PM   #3
Joe02wrx
Member#: 284636
2002 Wrx wagon
Replaced gasket. Air still disappears
Old 11-24-2012, 04:18 PM   #4
Joe02wrx
Member#: 284636
2002 Wrx wagon
It was my air oil separator Guys. Can delete
Old 11-24-2012, 06:48 PM   #5
danger1138
Member#: 279525
04 rex luger!
Which one is that^^? Off what sensor.?
danger1138 is offline   Reply With Quote
Old 11-25-2012, 02:39 PM   #6
Joe02wrx
Member#: 284636
2002 Wrx wagon
The actual throttle body gasket was blown
Old 11-25-2012, 02:40 PM   #7
Joe02wrx
Member#: 284636
2002 Wrx wagon
Unless you're referring to the air oil separator, that's an aftermarket part and doesn't have any sensors to it
