Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Closed Thread
Old 11-22-2012, 01:44 PM   #1
RallyBot 6.0
Member#: 337195
Maroon/black
Default full exhaust combo - pass emissions NORTH WEST?
so i just bought an 02 rex. got an exhaust leak at the 0 ring @ cat and also a leak @ my uppipe, its cracked. im looking to buy an up pipe, downpipe, and full cat back. i have a couple questions..
Can i go 3" downpipe back to 3" full exhaust with no other mods other then an intake and bov? and still run ok?
Do u NEED all the cats to pass emissions? if i can get by using a non catted up pipe and down pipe it would save me some cash.
if i got catted ill buy an invidia, non catted ill go with the erz. want both bungs so i can run wideband in the future. dont know which up pipe to go with, external wastegate? or normal.
i will need to pass deq in washington. i know there has been alot of debate over this stuff i just havnt found any answers to what pertains to me. thanks.
RallyBot 6.0 is offline
Old 11-22-2012, 03:36 PM   #2
corvallisbattery
Member#: 333030
'05 WRX
Dude seriously.. .you clearly made no effort to become knowledgeable on the subject. Quit wasting my data plan on stupid questions and use the search button
corvallisbattery is offline
Old 11-22-2012, 03:42 PM   #3
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Stop wasting your data plan posting dumb responses. If you don't like a thread just move along.
Sorry op I have nothing to contribute to your question.
fxt05 is offline
Old 11-22-2012, 04:51 PM   #4
Viral E
Member#: 242246
2002 Impreza WRX
FWIH, you can run with only one normal Cat or two high-flow Cats and still pass emissions. Run your car a little hard before the emissions test. I hear getting the converters a little over normal operating temp helps with passing HC section of the test. You should remove the cat in the uppipe anyways. F*ck emissions, save your turbo.
Also, Seafoam in the gas tank is an old trick used by truck owners. My friend successfully lowered his emissions on his dodge using a can of Seafoam (at least according to the test station he went to).
Lastly, I don't know how much this helps, but somebody told me if you tune your cruising load a little leaner you can help lower both HC% and CO%
Viral E is offline
Old 11-23-2012, 04:23 AM   #5
token85
Member#: 105974
2002 02 bug eye
05 blob eye
when i lived in the NW all they did was a OB-II check, to make sure you didnt have any cells. i ran a full 3 inch no cats never had a problem. You just going to have to have some one delete a line out of your ecu so you stop getting a cell for no cats, or just the the cell delete plug that goes into the DP. search the NW chapter its in there.
token85 is offline
Old 11-23-2012, 08:48 AM   #6
cmiovino
Member#: 134005
2004 WRX Premium
FYI, keep in mind you do need to get some sort of tune to run the downpipe safely. Well, 2002's can get away without it... but I'd still highly suggest getting one, even if it's just running the Cobb stage 2 MAP.
As far as emissions, look into what is legal even in your county. I know here is Pittsburgh, you have to be catted (visual check) and they check for CELs. Up north a hour, you can run catless no problem. All depends where the car is registered.
cmiovino is offline
Old 11-23-2012, 09:50 AM   #7
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
If you live in kitsap county, we do no emissions testing. It all depends on what county your in. I run a full catless uppipe/downpipe.
Amazing Asian is online now
Old 11-23-2012, 10:14 AM   #8
rustmonkey
Member#: 262703
2006 STi
SGM
Full invidia catless exhaust and love it in Kitsap county!
rustmonkey is offline
Old 11-23-2012, 10:40 AM   #9
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Full catless on both cars, one does the tail sniffer and the other on OBD-II, both pass in SnoCo.
With your OBD-II car, you can tune it and have it pass. I don't think any county in WA has any scrutinizing visual inspections (eg: they really look underneath to see a cat).
Pakin is offline
Old 11-23-2012, 10:50 AM   #10
hillsboro
Member#: 84823
11 STI
05 Outback XT
http://forums.nasioc.com/forums/show...ight=emissions
A little effort goes a long way around here. This has been thoroughly covered, along with what kind of (blank) should I get/buy.
I ran fully cat less on my 02 and it was fine. If you want to get the most out of the parts you purchase get a tune. With out one you will need to LOOK up the CEL fixes for the up pipe and down pipe.
Get to a meet ASAP.
hillsboro is offline
Old 11-23-2012, 10:58 AM   #11
Crazymonk88
Member#: 200532
05 Legacy
GRP
A little effort goes a long way around here. This has been thoroughly covered, along with what kind of (blank) should I get/by.
Yay! Intelligence.........
Crazymonk88 is offline
Old 11-23-2012, 12:14 PM   #12
Fade2black02
Member#: 309997
2010 STI
Blick
Many cities don't require emissions testing, just drive there and renew. No questions asked because if the government is good for one, and one thing only...it's they never say no to extra tax money.
Arlington and Enumclaw in WA, to name a couple. With a little research you can find several more in your area I'd imagine as well (it wasn't specified where you live).
Fade2black02 is offline
Closed Thread
