Old 11-23-2012, 12:21 AM   #1
legacybov
Member#: 285229
Default 2003 Legacy Wagon moon roof leaking....
So we found out that our Wagon has a leak coming from the passenger side rear ceiling hook (used for car seat latches).
I removed the headliner enough to see that the two drain tubes on the rear of the pan were still attached. I also flushed out both sides and made sure the drains were still letting water out.
It still looks like it is leaking and the water is dripping from where the copper pipe attaches to the pan (to the left of the drain nipple plug).
Any other ideas on why it is leaking?
legacybov is offline   Reply With Quote
Old 11-24-2012, 09:00 PM   #2
k2snow
Member#: 10449
03 Legacy BH
I just recently had the same problem on mine. the drains might be clogged and mine was leaking through the map light. I ended up just taking mine to the dealer to clean out as my normal shop couldn't figure it out.
k2snow is offline   Reply With Quote
Old 11-28-2012, 08:58 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Likely clogged drain tubes. Letting leaves & crap build up, or not washing enough usually makes this worse.
Sometimes snaking a piece of 18ga building wire down the tube will clear it out.
