Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 11-23-2012, 02:13 PM   #1
frayz
Member Sales Rating: (9)
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Default UK: 573bhp V7 Prodrive Edition STI. Syvecs, GT35R, massive spec!
Here goes,
Firstly I really have no idea where to begin with talking about selling my car.
I've owned her for the last 8 years of which in that time I've poured my heart and soul into it.
I've reached a time in my life where I want a new direction. I'm a huge car enthusiast and would like a change, maybe even sit on the sideline for a bit?
I have absolutely no reason to sell so am in no rush whatsoever, I may even decide to keep her if nobody offers me a fair price.
No expense spared meticulous build, and built as a package to be a monster, S7 WRC inspired road car, she has her carpets and air conditioning.
She has been fully documented throughout her life and has many custom parts and details. I've put way over 60K into this car and literally thousands of man hours.
Her life is documented here:
http://bbs.scoobynet.com/projects-40...ld-thread.html
This car has been maintained regardless of cost and wants for absolutely nothing.
Just love it the way I have/do. :cry:
2002 Prodrive Edition STI Type UK
47K miles (2,800 miles on her built engine and performs beautifully)
Blue/Black pearl
MOT and Tax.
Only ever driven on Vpower or Momentum99
Always warmed up and cooled when used.
Here's her full specification:
Built entirely by myself (Frayz-Engineering)
Mapped by Simon Roe (JollyGreen Monster)
Engine
New EJ257 block (modified by FE)
New EJ257 crankshaft
ACL race series main bearings
ACL race series big end bearings
Lateral Crower "long" H section forged con-rods
Lateral Wiseco custom pistons
RCM modified oil pump
Cosworth sump baffle plate
XWORKSS baffled sump
JDM Spec C long runner intake manifold
10mm Phenolic spacers
Walboro lift pump
Custom swirlpot
Bosch 413 Motorsport fuel pump in custom FE QR cradle
Fuelab billet filter
Custom FE fuel rails
Injector Dynamics 1000cc injectors
Fuelab FPR
JDM "Big Port" Spec C heads (modified by FE with custom combustion chambers and port work)
Supertech Stainless/Nitrided intake valves
Supertech Inconel exhaust valves
JDM Spec C cams
NGK Racing 8 spark plugs
PE Kevlar timing belt
CDF billet timing guide
New Genuine OEM waterpump, piston rings, gaskets/seals
GT-Spec Gen II, Zircotec ceramic coated tubular manifold
Custom T-Logic twisted inconel up-pipe
Garrett GT3582R turbocharger with Tial .82 V-band housing
DEI titanium turbo blanket
DEI titanium wrapped downpipe
Custom XWORKSS twisted downpipe
Tial 44mm External wastegate
Bespoke 3" lightweight race exhaust system from Simpson Race Exhausts. (Ceramic coated with bent down tailpipe)
Grimmspeed EBCS
3bar map sensor
160mm K&N filter mounted on custom 6x4 carbon intake trumpet
Custom FE/XWORKSS breather system and RTS catch tank
Exedy Hyper Compe-R twin plate carbon clutch
Exedy Hyper Compe-R forged billet flywheel
Goodridge braided clutch line
APS DR725 front mounted intercooler with custom FE pipework
Hardrace engine/gearbox mounts
Setrab 19 row oil cooler with custom FE housing
Ixiz-Concept bonnet dampers
Odyssey PC680 race battery
Hand built custom engine wiring harness
Samco hosing - coolant
Speedflow Fittings/hose - fuel
Power/Torque limited to 573bhp-520ftlbs @2.1bar
ECU
Syvecs S6 (Launch Control & AntiLag) with 8 individual cals adjustable on the fly
Braking system:
AP Racing 6 pot CP7040 calipers, 356mm AP grooved discs,
Pagid RS29 front pads
Colour coded black/yellow STI rear Brembos
Performance Friction Z/compound rear pads
Goodridge stainless braided hoses all round
Motul RBF600 brake fluid
Suspension Modifications:
Whiteline adjustable front sway bar
Whiteline adjustable rear sway bar
Whiteline HD mount kit
Whiteline camber bolts
Whiteline rear diff locking kit
Whiteline roll centre adjustment kit
SD Motorsport solid rear diff mount
KW Variant 3 External reservoir coilover dampers
CDF billet front ARB drop links
CDF billet rear ARB drop links
CDF billet pitch stop
CDF billet anti lift kit
Super Pro poly lower arm bushes
Super Pro poly outrigger bushes
Super Pro poly gearbox cradle bushes
AS Performance delrin gear linkage bush kit
Noltec billet clubsport pillow ball adjustable topmounts.
Custom STi front strutbrace
Custom (track bias) geometry setup
STI8 Spec C steering rack on Whiteline bushes
Wheels/Tires:
18x8 Speedline Turini
235-40-18 Michelin Pilot Super Sport
RAYS extended black lugnuts
Genuine Prodrive valve caps
Interior/Exterior Modifications:
Interior
Prodrive/Sparco Pro WRC carbon drivers seat
Prodrive/Sparco Pro WRC GRP passenger seat
Flocked dash with custom gauge pods
Flocked A pillars
Flocked Steering column cowlings
Flocked centre console
Satin black dash trims
Speedware stainless harness bar
WRC/Group N carbon rear firewall
WRC/Group N carbon rear seat bench replacement
WRC/Group N carbon 3 piece parcel shelf
TRS Magnum ultralite WRC FIA 4 point harness's
Genuine STi carbon door sills
Genuine STi mats
DSG white delrin gear knob
Full Works Bell QR steering setup with Momo Mod 07 steering wheel
Lifeline 4ltr plumbed in fire supression system
Lifeline 2.25ltr handheld fire extinguisher
Exterior:
6000K HID lighting (High-Low)
Carbon STi wing blanks
Genuine Prodrive WRC S7 Carbon mirrors
Genuine Prodrive WRC S7 Carbon bonnet vent
Smoked side repeaters
Custom gurney flap on upper wing blade
Custom fog light covers with flush mounted cold air feeds. (oil cooler/air box)
Genuine Spec C type RA roof vent
WRC plain black Kaylan mudflaps
Polished/painted Prodrive rear diff guard
PIAA Silicone wipers
Aerocatches
Data acquisition:
Syvecs S6 ECU
Defi BF 60mm gauges - Oil Temp, Oil Press, Water Temp, Fuel Press, Exhaust Gas Temp, and Boost Press.
RB Motorsport ACT gauge
Innovate Motorsports Wideband Lambda sensor with USB hub output
Phormula KS3 knock analyzer
frayz is offline   Reply With Quote
Old 11-23-2012, 02:14 PM   #2
frayz
Member#: 106909
Edition... Black!
If you're wondering, she sounds like this.
I have literally thousands of photos of his car throughout her life with me and can supply further information to any genuine enquiry.
As said, I do not need to sell her and at the moment purely testing the water if I get the right offer or not. Spares and registration not included in sale but are open to negotiation.
No tyre kickers
No test pilots
This car is truly unique, there is not another built quite like it. To me it's absolutely priceless and has taken a huge part of my life.
Must be seen to be appreciated and any inspection is welcome.
Still don't actually know if I can watch it drive away but will be listening to offers over 25,000GBP
(Car is in the United Kingdom)
Thank you for reading.
Frayz
Old 11-23-2012, 02:49 PM   #3
06stidude
Member#: 157956
2008 WRX STI
GRAY
06stidude is offline   Reply With Quote
Old 11-23-2012, 02:58 PM   #4
dub c
Member#: 145069
Keep It Sleazy
Noooooooooo.
This is the most well built Subaru on here.
Such a classic build.
Great job Frayz.
dub c is offline   Reply With Quote
Old 11-23-2012, 03:25 PM   #5
2subiesinyard
Member Sales Rating: (18)
Member#: 139562
2015 Launch Edition
WRBoo
Sooooo freaking nice....I hate you. Hahahhha
2subiesinyard is online now   Reply With Quote
Old 11-23-2012, 03:34 PM   #6
scoobasaurusrex
Member Sales Rating: (1)
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
well that's kinda nice i guess.
scoobasaurusrex is offline   Reply With Quote
Old 11-23-2012, 05:27 PM   #7
.Boston.
Member Sales Rating: (19)
Member#: 223096
'02 SRP STi,'04 R32
Blouch Twinscrollolol
One of the best bugeyes I have ever seen, beautiful car!!
.Boston. is offline   Reply With Quote
Old 11-24-2012, 06:50 AM   #8
digitaljigga
Member#: 132451
03 WRX
Default Negoations
Dear Sir,
I would like to begin negotiations with you in regards to your ****ing beautiful car.
Can you please provide me with your contact information as I would contact you to determine your availability to show the car.
I have enclosed within my linkedin profile to give you more information about my background and my intent.
http://www.linkedin.com/pub/corey-wh...pdmp/5/556/6a5
Anxiously awaiting your response.
v/r
Corey White
01-360-977-3374 (M)
digitaljigga is offline   Reply With Quote
Old 11-24-2012, 08:55 AM   #9
frayz
Member#: 106909
Edition... Black!
Corey, I've seen your message. However I'm away this weekend for my birthday. I will get back to you on Tuesday.
Kind regards
Frayz.
Old 11-24-2012, 10:38 AM   #10
02wgn
Member Sales Rating: (3)
Member#: 206361
2011 sti
wrb
NOOOOO!!!! this is such a magnificent vehicle. the next owner of this car is going to be one happy lucky individual. Good luck
02wgn is offline   Reply With Quote
Old 11-24-2012, 01:14 PM   #11
Heedlessone
Member Sales Rating: (2)
Member#: 254130
1993 LS1 RX7
This makes me sad I don't live in the UK. Beautiful car.
Heedlessone is offline   Reply With Quote
Old 11-24-2012, 02:52 PM   #12
Kastley85891
Member Sales Rating: (57)
Member#: 127704
2015 Boosted Stang
MAP tuned
Matey - keep that thing, If I lived in England still I'd be re mortgaging but would feel bad for you driving it away! its perfect......
Kastley85891 is offline   Reply With Quote
Old 11-24-2012, 10:23 PM   #13
allen08sti
Member#: 314020
08 sti
red
Any way to ship to the us?
allen08sti is offline   Reply With Quote
Old 11-25-2012, 11:13 AM   #14
Tanktheory
Member Sales Rating: (6)
Member#: 239981
01 SF5 Ver 8 swap
Blu
Originally Posted by digitaljigga View Post
Dear Sir,
v/r
Corey White
01-360-977-3374 (M)
That's one of the most impressive LinkedIn profiles I've ever seen Mr. White.
Tanktheory is offline   Reply With Quote
Old 11-25-2012, 12:38 PM   #15
thrashdu2002
Member#: 199949
2006 WRX Wagon
Bump for a sweet bangers and mash ride(UK)
Cheers
thrashdu2002 is offline   Reply With Quote
Old 11-26-2012, 02:51 AM   #16
davidsti1
Member Sales Rating: (31)
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
Nice freaking car!!
davidsti1 is offline   Reply With Quote
Old 11-26-2012, 11:20 AM   #17
subiesean
Member#: 243565
2014 Accord Sport
black
holy mother of moses thats incredible
subiesean is offline   Reply With Quote
Old 11-28-2012, 10:11 PM   #19
kuneefay
Member Sales Rating: (13)
Member#: 266477
1996 F-250 7.3L
Not sure what has occurred in your mind Mr. Frayz the most convincing thing that I can gleen is that you've gone mad. This is with out flinching doubt the most impressive and maticulously built bugeye I've ever seen. Its the epitomy of my dream car and I wish you the best of luck with your sale.
kuneefay is offline   Reply With Quote
Old 11-28-2012, 10:19 PM   #20
GDB FAN
Member#: 105814
I've joked about selling organs before, but this time I'm serious. I'd even move.
Good luck and hope you hold out for a buyer worthy of the car.
GDB FAN is offline   Reply With Quote
Old 11-28-2012, 10:46 PM   #21
rmommandi
Member#: 335230
No doubt one of the cleanest cars i've seen on this forum!
Glws mate
rmommandi is offline   Reply With Quote
Old 11-29-2012, 04:22 AM   #22
frayz
Member#: 106909
Edition... Black!
As said guys. If I don't get a proper offer then she's not going. I'm not even listening to offers below 25000gbp. Realistically going to be much closer to 30,000gbp for me to let her go.
I've put my life's work into this car, and I think it shows.
Thanks for all the really kind comments.
Old 11-29-2012, 07:16 AM   #23
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Def shows... free bump, one sick ride
wrxlaunch is offline   Reply With Quote
Old 12-12-2012, 07:59 PM   #24
frayz
Member#: 106909
Edition... Black!
Corey White
You have email sir.
Kind regards
frayz
Old 12-13-2012, 09:29 PM   #25
WRXChops
Member#: 207179
2015 WRX Limited
WRB 6MT
Wow. U would be crazy to sell this.
WRXChops is offline   Reply With Quote
