Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 11-23-2012, 03:42 PM   #1
OxCitywrx09
Member#: 216362
2013 WRX
Default 2013 TMIC to TB Coupler Issues
Last night I was driving WOT up a grade to pass someone then all of a sudden my turbo spool got really loud with a loss of some power. After some research I found that the coupler has gotten loose on the TB. So today I took off the tmic but I can't get the coupler back on. I was wondering if any of you knew an easier way or a trick to get the coupler to slide on easier. I was thinking it needed some kind of lube but I didn't want to do that as it is right next to the TB.
Thanks in advanced for your help
-James
EDIT: issue fixed on pg. 2
OxCitywrx09 is offline   Reply With Quote
Old 11-23-2012, 03:48 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Take the sleeve off of the coupler, it's on the throttle body side of the coupler. It shouldn't be too difficult to do.
drewvdw is offline   Reply With Quote
Old 11-23-2012, 03:56 PM   #3
OxCitywrx09
Member#: 216362
2013 WRX
Thanks, I did just that now the coupler sits on the TB great. Should I take off the sleeve for the tmic too?
Old 11-23-2012, 04:48 PM   #4
kingme
Member#: 280943
'11 WRX
Yes.
Use hairspray as a lubricant to get the hose on. When it dries it acts as an adhesive.
kingme is offline   Reply With Quote
Old 11-23-2012, 05:07 PM   #5
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Mine didn't have a sleeve to the TMIC...If it has one, go for it.
Old 11-24-2012, 08:47 PM   #6
OxCitywrx09
Member#: 216362
2013 WRX
Thanks for all of the tips. I thought removing and reinstalling the tmic was going to be easy. I thought wrong. hahahaha.
Old 11-24-2012, 10:14 PM   #7
2011dubrx
Member#: 292943
^hey man im from ventura county, we have a subie meet every sat night around 9ish in camarillo del taco of las posas. Come stop by.
2011dubrx is offline   Reply With Quote
Old 11-25-2012, 02:51 AM   #8
OxCitywrx09
Member#: 216362
2013 WRX
Default Booost
That sounds great. I might be free next week so I will try to come and swing by!
I went out tonight to do some test pulls and I don't think I am hitting max boost now. Under WOT, I hit 15psi, then it tapers and stays at 13psi. From what I remember it should be at 14psi. I don't know if that is just me being paranoid, or is one psi a big deal? I will have to check it out tonight and make sure everything is seated properly. I didn't want to over torque some things so something might be loose. Is it normal to be at 13psi ?!
Old 11-25-2012, 09:23 AM   #9
BobChestnut
Member#: 335754
2013 WRX
WR Blue
I've noticed the same thing on my 2013 wrx as well except that it seems to sit around 10-11 psi and then usually I'm going to fast on roads i shouldn't be so i don't look at it again.
I've asked around and it seems to be normal just due to the nature of the waste-gate on these cars and what not, but i could be wrong feel free any one to correct me.
BobChestnut is offline   Reply With Quote
Old 11-25-2012, 10:44 AM   #10
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
This is a very common problem. If you don't plan to upgrade the tmic I'd suggest replacing that hose with an aftermarket one like the AVO.
ERL2011wrx is offline   Reply With Quote
Old 11-25-2012, 01:15 PM   #11
OxCitywrx09
Member#: 216362
2013 WRX
So am I at a good boost pressure or do I need to replace that hose to be back at 14psi ?
Old 11-25-2012, 02:31 PM   #12
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
If you remove the caps from both ends of that hose, you should not have to replace it. I run 27psi with the stock hose.
The stock turbo normally tapers at higher rpm. Unless you do a full 2k-redline pull and datalog it you won't know for sure if you're hitting your targets.
xluben is offline   Reply With Quote
Old 11-25-2012, 03:07 PM   #13
OxCitywrx09
Member#: 216362
2013 WRX
Thanks for the input Ben. I think I will be good for now as I have no means of data-logging, and the car feels great. The coupler seems to be holding on after going wot a few times. Ill probably go for a few more pulls later today to see if it will still hold up. If not I will have to try the hairspray trick.
The hairspray won't effect anything with the motor? I am just a little concerned because this is the coupler that attaches directly to the TB and I would think that you would want to keep any kind of chemical away from it for the sake of the motor.
Old 11-25-2012, 03:11 PM   #14
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
i hairsprayed mine. its been good since.those endcaps are terrible from the factory.
424wrx is offline   Reply With Quote
Old 11-25-2012, 03:22 PM   #15
OxCitywrx09
Member#: 216362
2013 WRX
Sounds great. I agree.. My coupler came right off when I removed the TMIC. It sure was a pain trying to get that thing back on tho lol.
Old 11-25-2012, 07:20 PM   #16
OxCitywrx09
Member#: 216362
2013 WRX
I went out for some 1-3rd gear pulls and noticed a few things. From first to second I heard a squeak or chirp sound. And it seemed to be fine from second to third. When I got home I popped the hood and found the coupler to become slightly unseated. I think I am going to buy the avo coupler and some t bar clamps just for extra assurance.
I am planning on going stage 2 as soon as cobb releases the 2013 software so I think it would be a good thing to do.
Old 11-25-2012, 07:49 PM   #17
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Not necessary, but certainly not a bad idea. Just like a Forge (or other quality) BPV on an 08+ WRX after upping boost pressure.
Old 11-25-2012, 10:36 PM   #18
OxCitywrx09
Member#: 216362
2013 WRX
This is kind of a long shot, but do any of you guys have a picture of the coupler with t bolts installed? I am curious to see how to position it since it will be a tight fit in there. I remember seeing it on a post a few days ago, however I can't seem to find it anywhere. I put in my order for 2 2.75" T bolts today and they should be here sometime this week and I couldn't find anything on how to position them.
Old 11-25-2012, 10:40 PM   #19
OxCitywrx09
Member#: 216362
2013 WRX
Originally Posted by Mike 01Hawk View Post
No point in wiping the oil away, it'll just come back
As for those 'socks', I think it has to do with an engine safety feature. They are meant to blow @ like 18psi or something low like that so you don't over-boost your engine. Go figure.
As for T-Bolt clamps, they were a SOAB to get them lined up, but after a lot of fiddling here's how I have mine situated.
Good luck
Found it! haha...
Here is the link to the thread to where I found the information.
http://forums.nasioc.com/forums/show...6#post38169596
It is amazing to see how many people have this issue straight from the factory.
Last edited by OxCitywrx09; 11-25-2012 at 10:42 PM. Reason: Added some information.
Old 11-25-2012, 10:55 PM   #20
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I haven't swapped over to T bolt clamps, but I have gotten stronger worm clamps when mine failed. Damn auto parts stores around here don't carry T bolt clamps.
Old 11-25-2012, 11:03 PM   #21
OxCitywrx09
Member#: 216362
2013 WRX
I didn't even bother to go to autozone or o'reilly's store around here. I just picked up the clamps from rallysport direct. I like their customer service, and buying out of state saves me from tax, so I can justify buying more parts haha :P.
http://www.rallysportdirect.com/ATP-...t-Clamp-2-75in
Old 11-26-2012, 03:33 AM   #22
OxCitywrx09
Member#: 216362
2013 WRX
I had some downtime today so I decided to give it another try. It looked like I had the coupler on backwards. Put everything back together and now there is a loud whistle and even lower boost. FML... I will just have to wait for my parts to come in the mail now
Old 11-26-2012, 07:02 AM   #23
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
go to the dealer.
Old 11-26-2012, 09:58 AM   #24
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Did you remove the rubber caps from both ends? If you do that, and install it properly, you should not have any issues. The AVO is actually a hair shorter than stock, so it can make the problem worse. I would just use the OEM hose with T-bolt clamps and no rubber end caps.
Old 11-26-2012, 02:47 PM   #25
OxCitywrx09
Member#: 216362
2013 WRX
That is really good to know. I would've thought the avo would be the same length. I did remove the end caps and the alignment of the tmic gets tricky since the coupler loses about a 1/4 inch in length without those rubber ends. I need to look everything over again tonight. Hopefully everything goes well. Hopefully i can put this behind me soon ! Thanks for the info.
