Old 11-24-2012, 04:54 AM   #1
salvi
Member#: 188132
Default Vacuum leak near throttle body, help!
Tonight I finally turned on my 2.0 swapped GC8. Everything else is fine, but the car is dying off when I try to move the car. There is a crazy hissing sound coming from the throttle body area. I can't see where the leak is coming from. I used a brand new throttle body gasket. Are there any other vacuum leak areas on the throttle body besides the gasket?
salvi is offline   Reply With Quote
Old 11-24-2012, 08:48 AM   #2
danger1138
Member#: 279525
04 rex luger!
U know the small rubber line that goes to the bpv, is that connected?
danger1138 is offline   Reply With Quote
Old 11-24-2012, 11:54 AM   #3
salvi
Member#: 188132
Yes, that one is connected.
Old 11-24-2012, 01:04 PM   #4
danger1138
Member#: 279525
04 rex luger!
I not to the bpv itself but from where it originates underneath throttle body.. That connection..
Old 11-24-2012, 01:14 PM   #5
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
^^^ This would be my guess for starters especially since you can almost pinpoint where the sound is coming from. That is either poorly connected or the hose needs to be replaced. Are you throwing any codes?
Chaz2.5 is offline   Reply With Quote
Old 11-24-2012, 05:04 PM   #6
danger1138
Member#: 279525
04 rex luger!
Or try the soapy water trick. Spray some soapy water around the bpv, those gaskets wear out from time to time..
Old 11-24-2012, 05:46 PM   #7
salvi
Member#: 188132
No codes, it ended up being the AICV o-ring/gasket. Replaced it and the hissing sound is gone.
Old 11-24-2012, 07:13 PM   #8
danger1138
Member#: 279525
04 rex luger!
The IAVC?
Old 11-24-2012, 07:15 PM   #9
lavid2002
Member#: 226864
Soapy water around a vacuum leak? Lol
lavid2002 is offline   Reply With Quote
Old 11-25-2012, 12:04 AM   #10
danger1138
Member#: 279525
04 rex luger!
No...that whole soapy water ish gets confusing..
Old 11-25-2012, 02:52 AM   #11
salvi
Member#: 188132
Yeah, the idle control valve.
