Old 11-25-2012, 12:20 AM   #1
Patrick92
Member#: 330541
2004 STI
PSM (01G)
Default Weird ABS issue
Sometimes whenever I am driving the ABS light will pop on for a second and it will make my head lights flicker... Has anybody ever had that problem? I don't even know where to start diagnosing this issue.
Patrick92 is offline   Reply With Quote
Old 11-25-2012, 02:31 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
make sure the battery terminals are clean and the cables arent bad
if the cables are 'stiff' and dont bend easily...they are garbage
Old 11-25-2012, 12:02 PM   #3
motoman399
Member#: 270808
My ABS would randomly pulse as I would apply the brakes, then the ABS light would come on and stay on until the ignition was cycled. Shortly after that the pump quit working. Replaced it from one on ebay and now it works great.. good luck.
motoman399 is offline   Reply With Quote
Old 11-25-2012, 12:53 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Moved from powertrain, this does not relate to the motor of the vehicle.
Old 11-29-2012, 02:55 AM   #5
Patrick92
Member#: 330541
2004 STI
PSM (01G)
Thank you! For some reason the negative battery cable was loose... Problem solved!
