Old 11-25-2012, 12:30 AM   #1
Rymaster
Member#: 296277
2002 Impreza WRX
Default 02 WRX Automatic with 05 STI cluster swap - Video / Explanation
Bought what I thought to be an 04 STI cluster, Ended up being an 05 STI cluster. Reason being I think its 05 is because like I've read, the left side plug had to be modified because the housing was too big for the plug to line up correctly and the ABS and rear differential temp lights were both on. Plus in addition to cutting the wire in the middle plug that blows the radio fuse, I had to cut one wire in the right plug of the cluster because it was doing to buzzing for reverse polarity. I've read that the 04 STI cluster is plug and play into a 02 WRX minus cutting wire in the middle plug so you don't blow the radio fuse.
I ended up using two layers of electrical tape over the DCCD, ABS, Rear Diff Temp. Lights. Figured I'd upload this video because all the ones i have seen, no one ever starts up the car, they only put it into accessory mode.
Please ignore what I said in the video about not having a security light, it does. What it does not do unlike the normal factory cluster is the whole cluster does not light up when you arm the alarm, only the blinkers light up. I'd assume this is because the cluster is setup to light up after the opening sweep. It's pretty nice for the most part though.
Even though i have an auto, i still like having the Speedo to the right because that way I don't have to move my hand when I drive to always be checking my speed. Yes I know, one should never drive just in the 12o'clock position, it's a bad habit I can't beat =P
Rymaster is offline   Reply With Quote
Old 11-25-2012, 12:51 AM   #2
s1eepR
Member#: 335330
2008 Impreza 5DR
Nice 5char
I would love an STI/WRX cluster in my 08 NA
s1eepR is offline   Reply With Quote
Old 11-25-2012, 01:05 PM   #3
Trustkevin13
Member#: 259184
2008 Subaru WRX
4eat ftw! my08 4eat. its such a sloppy tranny at stage 2 but i still love it :happybanana:
Trustkevin13 is offline   Reply With Quote
Old 11-25-2012, 08:49 PM   #4
Rymaster
Member#: 296277
2002 Impreza WRX
*update*
Cluster's speedo is off confirmed via GPS. No dyno or anything but GPs shows speedo reports +2mph then it should be. No biggie, I'll live without a speedo healer
Old 11-26-2012, 12:08 AM   #5
iAJrocks
Member#: 338919
2002 WRX Impreza
PSM Silver
sick video pretty awsome
iAJrocks is offline   Reply With Quote
Old 11-27-2012, 02:09 AM   #6
gongshowguy
Member#: 307617
2004 wrx
red
id like to talk to you about installing you if your up for it
gongshowguy is offline   Reply With Quote
Old 11-27-2012, 02:25 AM   #7
s1eepR
Member#: 335330
2008 Impreza 5DR
Me? If so, Let's not thread jack, pm me :happy banana:
Old 11-27-2012, 03:30 AM   #8
Rymaster
Member#: 296277
2002 Impreza WRX
Sure, like the whole process or anything specific?
