Old 11-25-2012, 01:42 AM   #1
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
Default 2000 impreza obs 2.2l oil in coolant reservoir
hey guys, today i went to do my timing belt/waterpump on my sohc 2.2l.
pulled the radiator cap, noticed slight oily sludge on the inside of the cap. drained coolant, and the coolant didnt look to be contaminated with oil. bright green like it should be
then it came time to check the overflow and i found this!
its thinner then fresh oil, but i normally see it being light brown when coolant is mixing with the oil, from a blown headgasket.
i am currently in school for automotive, and my hood is left open during class time for lab days.......thinking maybe some stupid kid could have put oil in there when i wasnt around my car?????
car runs perfect. did compression test a few weeks ago. 180psi on all cylinders.......no cel. no overheating. nothing.
thinking ill flush out the motor, radiator, and overflow. put everything back together and full it up. run the car and see if it is still there......to rule out maybe someone putting oil in my overflow tank???
let me know what u guys think......
thisisthenewsic is offline   Reply With Quote
Old 11-25-2012, 12:22 PM   #2
J-hop
Member#: 318428
I'm really hoping for your sake that it was just someone messing around. My only thoughts as to why you saw it only in the expansion tank and underside of the rad cap is that oil is less dense than water and therefore the oil should tend to collect in the highest points of the system.
J-hop is offline   Reply With Quote
Old 11-25-2012, 02:51 PM   #3
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
Yeah^^
And what makes me scratch my head is that the oil in the expansion tank/overflow seems like watered down oil, but was not separated with oil on top and coolant on bottom. like normally.
