#1 |
Member#: 249659
Vehicle:2012 WRX Limited SWP |
Where is this oil coming from? I know it's hard to see on the second picture but its running down that spotty black hose. I'm looking at it underneath and from above,and can't find the culprit. Any ideas to look would be good. I didn't do anything to cause a leak. Only parts I have installed on the car is a short ram and pitch stop. Obviously neither of those would do it. But would removing the top mount have stirred something up? Thanks guys!
#2 |
Member#: 268931
Vehicle:2012 wrx ice silver |
Check the tmic to throttle body hose.
#3 |
Member#: 249659
Throttle body to top mount was sealed tight but if you look hard enough in the picture, there's some oil down in the valley. Getting closer! Sorry for iPhone pictures too.
#4 |
Member#: 249659
Pretty sure I found it. I can twist the throttle body hose. Now I'm just trying to get to the hose clamp without taking 50 things off
#5 |
Member#: 249659
![]() There we go! So is this common? Why would this have happened? Fill me in guys |
#6 |
Member#: 322385
Vehicle:2006 Civic LX Stage a lot 140BHP |
Remove that black condom from both end of the hose, spray some hairspray to help it seal before reattaching, use t clamps, and it won't happen again. It's common enough for there to be multiple threads about it. Happened to me as well.
#7 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
op, go to the dealer. you have a warranty. that much oil there isnt normal. stop taking it apart and go to the dealer.
#8 |
Member#: 249659
I'm stage 2 with a dp and intake. Pretty sure I'm screwed on that end. Or is it worth a shot?
#9 |
Member#: 171948
whats the worst they can say, no. i had a smaller oil issue on my 08. higher boost pressures make this issue worse. i installed a grimmspeed aos system and my tb hose and tmic are free of oil again. my car is also almost 5 years old come january. your is much newer. try the dealer id say.
#10 |
Member#: 249659
Very true. I'm taking it there this week
#11 |
Member#: 339007
Is it just me, or do 12 wrx's have alot of issues with seals? Taking my 12 in again soon with boost leaks....
#12 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
This means almost nothing. But if you want to continue to think because you modded your car in any way, that you no longer have any sort of dealer support, then go ahead.
#13 |
Member#: 204321
TXIC
Vehicle:2004 WRX/08 Bmw 335i WR Blue |
just remove your mods and go to dealer with is that a days work vs losing your warranty no brainer in my mind.
#14 |
Member#: 322775
Vehicle:2012 WRX White |
Same problem I had! Bring it to the dealer and get that warranty to work! Remove your mods though
#15 |
Member#: 309550
Vehicle:2012 WRX HATCH WRB AKA Scooter |
Same problem I had. Installed grimmspeed AOS, and problem solved.
I noticed a boost leak before installing the AOS and that added to the oil leak problem as well. Running 19.5 psi now. After AOS and boost leak fix= NO oil Leaks. Happened in the same area with close to the same, if not more oil. Screw taking your mods off. Current setup: 2012 WRX CNT TBE AEM CAI Stage "2" Protune - Covert Tuning Dynamics - Cbus, OH Cobb AP Cobb Short Throw Last edited by jackassofalltrades; 11-29-2012 at 02:04 AM. Reason: Revision. |
