Old 11-25-2012, 11:13 PM   #1
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Default 2002 WRX leaking oil from passenger side head/valve cover
I have a 2002 WRX with 127k kms (79k miles) which started leaking oil onto the lower up pipe near the header flange around 4 weeks ago. I searched on heres and came to the conclusion that my valve cover gasket had started leaking. I replace the gasket using Permatex Ultra Black sealant. Two weeks later it was still smoking oil on the up pipe. I take the valve cover off again yesterday, scrape off all the sealant and clean up the sealing surfaces. I read the sealant tube and it says to assemble hand tight, wait an hour, torque bolts, then takes 24 hours to cure.
I redo everything with a little more sealant, follow the directions exactly, wait 28 hours and go for a drive to burn off the residual oil... now it is leaking way worse than before. Pretty embarassing with a cloud of smoke following you around.
The whole passenger side undercarriage is coated in oil.. it's dripping off the a-arm, sway bar, steering boot.. it's everywhere. How??
I just read another how-to thread on here and noticed a post saying to use hondabond rather than permatex or else you'll have to redo the job. Is this really that simple or is there something more to this? Thanks a lot
brett192 is offline   Reply With Quote
Old 11-25-2012, 11:40 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
You need to use new gaskets and replace the bolt washers.
Old 11-26-2012, 12:21 AM   #3
myk
Member#: 223143
2001 2.5rs Sedan
Brack
It doesn't actually call for us to use any type of gasket maker on the valve cover gaskets in the factory service manual except for the semi circle cam plugs and around the cam caps.
That being said I always use the grey RTV, which pretty much is equivalent to Honda bond. Make sure you tighten down in a X pattern so the gasket gets compressed evenly.
I have reused my VC gaskets twice already with low miles between each time I pulled them off, they are cheap enough though that if it is leaking again you might as well just get new ones.
I'd wipe down the area and let her run a while without driving around, never know it might be leaking from somewhere else and just getting spread/sprayed around.
myk is offline   Reply With Quote
Old 11-26-2012, 01:18 AM   #4
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I already replaced the spark plug and bolt gaskets. This is the second new gasket I have installed so I am thinking that it might be leaking from somewhere else, except for how it is worse now than before.
Old 11-26-2012, 09:23 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
It probably was my post you had read regarding that, and that was my personal experience with it. I redid it NUMEROUS times with permatex, every time it leaked. As the FSM calls for very little sealer and a very thin layer, I think the permatex was probably worse than nothing at all! The first time I redid it with HondaBond HT, it sealed perfectly.
Old 11-26-2012, 01:19 PM   #6
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Perfect, just the reply I wanted to hear.. I will go to the Honda dealership after school and buy a tube of hondabond. Thanks a ton!
Old 11-26-2012, 03:35 PM   #7
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Forgot to ask, did you just apply the hondabond, assemble, then drive? Or do you need to let it set up a bit, then assemble and let cure overnight? Thanks again
Old 11-26-2012, 03:52 PM   #8
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
Sure its not leaking at the air oil seperator at the top of the valve cover?
BoboTheMonkey is offline   Reply With Quote
Old 11-26-2012, 04:56 PM   #9
rkramer
Member#: 118209
2015 WRX Limitec
24 hour cure time before I even looked at the car.
Old 11-27-2012, 12:22 AM   #10
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Ok that's what I was thinking to be safe. Do you let it set for a while finger tight before torquing the bolts?
The black plastic piece bolted to the cover? It isn't leaking from there.. infact the vent hose wasn't even hooked up when I initially changed this gasket last month.
I went to the honda dealership after school and they were all out, and refused to sell me a partial tube.. So I phoned the other 3 honda dealerships (2 car lots and 1 powersport dealer) within an hour drive and NONE of them have any in stock for sale. I have to wait until Thursday at the earliest before it comes in from Calgary..
I get home and take my valve cover off and plainly see that the gasket was hung up on one of the lower cam retainers.. That's why it was leaking so badly Still doesn't explain why it was leaking before I redid it on Saturday
Sadly the gasket is torn in 2 places from when I tightened the cover on it I suppose. I will have to get a new gasket tomorrow..
To top it all off I dropped my iPhone and shattered the screen
Old 11-27-2012, 10:31 AM   #11
rkramer
Member#: 118209
2015 WRX Limitec
Non-automotive honda dealerships are more likely to have it and are usually more friendly also! (ie, honda motorcycle/powersports/lawn equipment dealers)
Old 11-27-2012, 11:35 AM   #12
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Fugibond.
sackytar is offline   Reply With Quote
Old 11-27-2012, 04:28 PM   #13
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I phoned the subaru dealership this morning and they don't have a gasket in stock so they had to order one, should be here on Thursday, same day the hondabond should arrive. Subaru dealership wants over $40 for a tube of fujibond, the honda equivalent is 'only' $23. Typical stealerships.
Old 11-27-2012, 04:34 PM   #14
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
I would double check the oil drain line on your turbo.
It is only made out of rubber with small, weak clamps. Over time the heat cycling of the turbo will cause the drain line to harden and crack, I wouldn't be surprised if that is the culprit of your oil leak.
Take your up-pipe out and look around your turbo oil drain, I'd be surprised to hear that there isn't any grime or buildup around it.
WhyHelloOfficer is offline   Reply With Quote
Old 11-27-2012, 05:05 PM   #15
liltoua
Member#: 206802
1998 2.5rs
If that doesn't fix it, it could be your cam seals...
liltoua is online now   Reply With Quote
Old 11-27-2012, 05:38 PM   #16
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
Did you run your fingers along the lines of which the gasket sits for any dried up sealant? Not doing this will damage your new gasket.
IheartAWD is offline   Reply With Quote
Old 11-27-2012, 09:33 PM   #17
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I will be taking my stock catted up pipe out and installing a catless up pipe in the next little while, so I can check the line then.
I did scrape all of the old sealant off the sealing surfaces, but that doesn't do much good when the gasket gets hung up on a bolt and isn't even close to sealing properly..
The Subaru dealership doesn't have any gaskets in stock so I have to wait until Thursday, which works out because that's when my Hondabond is supposed to arrive. Should have the car back on the road on Saturday.
Old 11-27-2012, 10:18 PM   #18
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I just crawled under the car and tried to locate the oil drain line for the turbo. Is it about 4 inches long and connects to the passenger side head? If this is it, mine is not leaking.
There is no oil residue around my cam seals, I believe it was initially leaking from the bottom rear corner of the valve cover.
Old 11-27-2012, 10:46 PM   #19
skater0422
Member#: 121162
04 Wrx
I use permatex grey on everything and never have any problems. I'm positive it is way cheaper than $23 a tube. Put it just on the half moons and a dab in the hard corners. If the gasket doesn't slip you definitely won't have a leak.
skater0422 is offline   Reply With Quote
Old 11-28-2012, 03:06 PM   #20
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Well I already have a tube of permatex ultra black @ $9, I might just say screw it and forget the hondabond. I talked to alcoolaid and he uses ultra black or grey with good results. I will be *carefully* installing a brand new gasket tomorrow evening. Crossing my fingers.
Old 12-08-2012, 08:13 PM   #21
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
So it has been a week and 1100 kms since I redid the valve cover gasket, no more leaks there.
However, I am still getting a small amount of smoke off the headers when I drive the car hard around left corners. Much less smoke than I have seen in the past, but I still lost a 1/2 qt. of oil in the past week. I jacked the car up today to look underneath, I don't see any drops of oil accumulated anywhere like before, but now there is a burnt oil stain on the header crosspipe. I remove my headers (pretty easy actually) and see 3 drops of oil on the timing belt cover.
Here's a photo of where the drops were if it matters:
Would redoing a seal in that area require the motor to be pulled or are they accessible with the motor in place? Thanks a lot
Old 12-12-2012, 09:35 PM   #22
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Bump, still leaking
Old 12-12-2012, 10:55 PM   #23
claythrow
Member#: 283663
2004 STI
Root Beer
You need the actual new gaskets not some RTV type solution, it's probably $20 in parts.
claythrow is offline   Reply With Quote
Old 12-12-2012, 11:00 PM   #24
claythrow
Member#: 283663
2004 STI
Root Beer
Did it look like it was coming from inside the timing belt cover? Or just like that is where it has accumulated.
If it's coming from inside it could be the crank seal, if outside it could be the oil filter seal or your oil pan seal.
Old 12-13-2012, 01:52 AM   #25
BugeyedBandit
Member#: 335225
2002 Stage 2 WRX
Watching this thread closely, I'm currently losing maybe 1 quart of oil per month. I sometimes see a small (half dollar) size spot of oil underneath the passenger side of the motor too... I'm hoping it's just the valve cover gasket
BugeyedBandit is offline   Reply With Quote
