Old 04-24-2013, 11:31 AM   #26
1oldman
Member#: 325505
2015 WRX
Crystal Black Silica
Originally Posted by luan87us View Post
You my friend is a genius!!! I've been thinking of ways to put my amp in the car without drilling through it. Completely there's a thing call velcro lol. Been thinking about double sided tapes or those foam tape thing but I know those don't hold on to fabric very well. Ahhhh sometime it's better to think stuff a bit more simple so you can see all the options.
Question: How do you attach velcro to the carpet? Are you somehow having one on the carpet and one on the amp or do you just use the one rough side on the amp and have it cling to the carpet? (found out that's what people has been doing to mount amp on carpet =D)
Use the one rough side on the amp and have it cling to the carpet! That is how I attached my Alpine PDX 9V to the carpet the passenger seat. I can hardly move that thing when I want to, let alone by itself.
1oldman is offline   Reply With Quote
Old 04-27-2013, 12:10 PM   #27
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
The 2012 impreza (just looked under my hood) doesn't have any grommets that are accessible. It has one unoccupied grommet that is somehow blocked by several wires, pipes, and other crap, and it's just underneath the dashboard, you couldn't just reach up to it. (can't even see it from the inside)
Any advice?
goregasm is offline   Reply With Quote
Old 04-27-2013, 02:38 PM   #28
Rymar
Member#: 310672
2012 Impreza Ltd 5Dr
Dark Gray Metallic
I used the grommet towards the passenger side, which contains the main bundle of wires from the engine compartment to the passenger compartment. I cut a cross with an Xacto knife slightly to the side of the existing bundle (being careful not to nick any wires), and pushed the power cable through. It fell out from behind the heater/AC box, and was then easy to route to under the passenger seat, where my power amp is.
Rymar is offline   Reply With Quote
Old 04-27-2013, 07:21 PM   #29
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Thanks! I'll try that
Old 06-24-2013, 12:59 AM   #30
vhsandvinyl
Member#: 354995
2001 Brighton Wagon
Sadona Sunset
great write up. would you guys say 2 under seat 8's and two 10" subs in the trunk would be too much base? I plan to upgrade the speakers so I have a proper balance of bass and treble
vhsandvinyl is offline   Reply With Quote
Old 06-24-2013, 12:23 PM   #31
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Yes, you'll probably end up with weird cancellation between the multiple drivers and it might end up sounding worse than if you just had the two 10" or the two 8" units.
evilspoons is offline   Reply With Quote
Old 07-22-2013, 02:22 PM   #32
Angelus911
Member#: 89967
2012 Impreza Sport
Just wanted to say thank you for this step by step guide, it really helped me in my install of my amp!
Angelus911 is offline   Reply With Quote
Old 08-07-2013, 10:27 PM   #33
blk05wrx
Member#: 180559
2016 WRX STi Limited
Finally got mine installed over the weekend. Very happy with the sound. It doesn't compare to a 12" in a huge box, but for it's size it does very well.
I especially like the knob that lets me add or remove bass depending on what I'm listening to. I'm thinking of putting it where the cigarette lighter is. Anybody ever tried that?
blk05wrx is offline   Reply With Quote
Old 01-27-2014, 08:17 PM   #34
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Old thread bump, I know, but I just noticed your question.
I put the remote level control for my JL XD700/5 amp in the cubby next to the lighter socket on my 2012 STi. It's stuck upside-down on the upper side of the cubby using some velcro, the same velcro I used to stick my amp to the carpet under the passenger seat.
Old 01-27-2014, 10:07 PM   #35
blkstar15
Member#: 363892
2013 WRX Hatch Prem
great thread! Question...is this harness the only thing that you needed:
http://ae64.com/20-pincombinedharness.htm
Do you just tap into this and run the wires?
blkstar15 is offline   Reply With Quote
Old 01-28-2014, 11:52 PM   #36
GreyFixer
Member#: 332965
2013 Impreza Sport
I have an aftermarket head unit so I used the subwoofer RCA outputs for audio signal and the blue "remote turn-on" wire for power-on signal. If you are using the factory deck, that harness should work for you. You just have to tap into the ACC-on lead for power-on wire and the front speaker wires for the "high power input" leads. The harness should come with a diagram showing you which wire is which.
GreyFixer is offline   Reply With Quote
Old 01-30-2014, 12:11 AM   #37
GSR2STI
Member#: 342219
2014 WRX
Is there something you can buy to connect a RCA adapter to the stock unit so you can just use the RCA's to amp?
GSR2STI is offline   Reply With Quote
Old 01-30-2014, 09:38 AM   #38
spartanVR4
Member#: 166362
12 Chevy VOLT
Line out converter- you tap into your speaker wires and it provides you with an RCA input. Alternatively, your amp probably has high level inputs that you could just connect to the wires and skip the LOC.
spartanVR4 is offline   Reply With Quote
Old 08-01-2014, 08:11 PM   #39
bsmiley314
Member#: 396251
2015 WRX base
Lightning Red
Comment on the industrial-strength Velcro.... As others have said, a little goes a long way, and also as stated in another post, it will adhere so well that the adhesive side could peel off. To help prevent the Velcro from peeling off the adhesive side if/when you remove your component:
1) Clean the surface with alcohol before attaching the Velcro
2) Radius the corners of the Velcro to eliminate the sharp corners; this is where it will start to peel. Use a nickel or quarter as a template for marking the corners.
3) Press all the edges down firmly, then do it again just to be sure.
3) When removing the Velcro-attached component, go S-L-O-W!
bsmiley314 is offline   Reply With Quote
Old 05-26-2015, 12:32 PM   #40
tuf_ryda
Member#: 389557
Hello, I just installed the Sound Ordinance sub into my 2013 Subaru WRX. We connected power directly to the battery, RCAs to the head unit (kenwood dnx690hd), ground to a bolt, and remote we spliced off of the ignition cable behind the head unit. It works but everytime I start ignition there's a loud pop sound from the sub. How can I fix this issue?
tuf_ryda is offline   Reply With Quote
Old 05-26-2015, 03:21 PM   #41
subie_newbie13
Member#: 387191
2012 Impreza 5-Door
Dark Grey
Check your ground. If where you connected to the frame there is paint you may not have a good connection.
subie_newbie13 is offline   Reply With Quote
Old 05-26-2015, 03:39 PM   #42
bobditts
Member#: 392683
2014 LS hatch
quartz blue
This issue is most likely due to how you have your remote wired. Your amp is turning on before signal is received from the HU which causes a pop. Your HU should have a remote out wire which goes to the amp. You do not need to wire the remote from the ignition.
bobditts is offline   Reply With Quote
Old 05-30-2015, 03:21 AM   #43
cspark0
Member#: 277311
2013 WRX Prem Hatch
I mine does the same "boom" on startup and the remote is wired correctly to the HU (svx harness and stock HU). It comes down to the S-O being a cheap piece of electronics. Turn down the sub's gain before you power up and the boom won't be so loud.
cspark0 is offline   Reply With Quote
