Old 11-27-2012, 01:18 PM   #26
Serkan
Member#: 180514
2004 Sti
With a noise like that first thing is to check the belt tensioner. Have personal experience and sounded exactly the same. And it seemed like it was coming inside the block. Easiest thing to check before you go further with investigation.
Serkan is offline   Reply With Quote
Old 11-27-2012, 01:32 PM   #27
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Agreed. How old is the tensioner?
ckyguy68 is offline   Reply With Quote
Old 11-27-2012, 03:12 PM   #28
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
You guy's notice belt tension fading if you let it sit over night but as soon as you start it tension holds normally. Doesn't seem to make any noise maybe on first start up if any. 46k miles on mines.
It only seems normal honestly for it to fade tension. Then build tension under operating conditions. It seems if it held tension 24/7 it would over load itself causing it to leak past the seal. Before reusing my tensioner I let it sit with the pin in it for a few days didn't seem to show any leakage.
spoolinsti05 is offline   Reply With Quote
Old 11-27-2012, 05:32 PM   #29
Kyle_J
Member#: 292364
2011 WRX
ISM
I installed a new gates tensioner when I built the motor, so roughly 1900 miles on it. The noise increases perfectly with rpm as well. If this was a valve lash problem wouldn't it slowly get louder over time? Not all the sudden start making noise
Kyle_J is offline   Reply With Quote
Old 11-27-2012, 06:08 PM   #30
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
it sounds like tappet noise, I just listened to it again.
do you have the banjo filters still in? maybe pull those and see if you have a clog.
what kind of oil change interval did you do when you broke the motor in? Particulate stuck in one of the screens maybe
what oil are you running?
did you check the oil level?
it sounds like valvetrain noise to me.
Flat 4 Motorsport is offline   Reply With Quote
Old 11-27-2012, 06:37 PM   #31
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Could be a bad AVCS solenoid also start their check the oil pressure at that solenoid. Worse case you pull the motor again and check valve lash.
Can also take a 7/8 or 22mm with a nice solid breaker bar and wiggle it back and forth on the crank pulley bolt. This may help you decide if it's possibly a rod bearing or wrist pin but honestly it doesn't sound that bad. To me sounds like the bolt's may have snapped that hold your tensor in place check them and report back.
Another thing it could be is to much piston to wall clearance are these pistons skirts coated?
Old 11-27-2012, 07:52 PM   #32
Kyle_J
Member#: 292364
2011 WRX
ISM
I've been kinda wondering if it could be something avcs related as well. I wonder if there's anything I can watch on my ems to see if that avcs solenoid is operating. Yes the piston skirts are coated, ptw clearance was .003. Also in that video you can hear the normal piston slap from a cold motor. Running valvoline vr1 NONSYNTHETIC 10w30, used brad penn break in oil until 750 miles.
Old 11-27-2012, 08:00 PM   #33
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Subbed for solution.
Id also like to know if there's a way to monitor avcs in the aem ems as well. Lol.
Which version do you have? I have the v1.
05_wRex is offline   Reply With Quote
Old 11-28-2012, 02:27 AM   #34
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I think it's Cam#1 ADV And Cam#2 ADV I can look at the v2 software also pretty sure it's the same though.
Old 11-28-2012, 08:17 AM   #35
Kyle_J
Member#: 292364
2011 WRX
ISM
Yeah my v1 has the same parameters
Old 11-28-2012, 01:54 PM   #36
Maxwell Power
Member#: 190729
Sounds like you didn't do a cam break in.
Did you do a cam break in? Upon initial startup you hold the rpm at 2k for 20 minutes. Failure to do that frequently wipes the tip off a lob and ruins the buckets.
Maxwell Power is offline   Reply With Quote
Old 11-28-2012, 05:06 PM   #37
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Good point Maxwell.
what year sti is your block casting from? original 04 sti?
I seen you have a 2011 sti crank did they change anything with the bearings by then?
I know they changed the rod lengths as I bought a used sti block and found out later not to mention it had mixed case halves that went back to the seller with the quickness.
Old 11-28-2012, 06:55 PM   #38
Kyle_J
Member#: 292364
2011 WRX
ISM
Brand new case halves straight from Subaru. Cams were reused from the previous motor. Only thing new in the heads with this build were +1mm valves and supertech valve guides
Old 11-28-2012, 09:03 PM   #39
Kyle_J
Member#: 292364
2011 WRX
ISM
I'm taking the drivers side valve cover off tmr after work, here's to hoping I find broken **** lol.
Old 11-28-2012, 09:22 PM   #40
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
good luck man, here's to hoping its something as easy as swapping a few buckets.
Old 11-28-2012, 09:40 PM   #41
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Did I miss the post where you looked at the timing tensioner?
Old 11-28-2012, 10:26 PM   #42
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Lol who put the guides in I herd they had fitment issues.
Old 11-28-2012, 10:31 PM   #43
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
OP said he replaced with new gates tensioner at the beginning of the build.
Old 11-28-2012, 10:39 PM   #44
Kyle_J
Member#: 292364
2011 WRX
ISM
And it's not the same sound that a bad tensioner would make. Also took a stethoscope and about blew my eardrums out listening from the drivers side valve cover
Old 11-28-2012, 10:41 PM   #45
Kyle_J
Member#: 292364
2011 WRX
ISM
I hadn't ever heard of fitment issues with the valve guides, have any info? Local shop installed them, Willard auto machine.
Old 11-28-2012, 11:34 PM   #46
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
if they cut them properly I cant really see any issue there. not saying its impossible though. if you end up pulling the head, just knock the keepers out and pull the valves and measure the length on the guides. I guess if one was machined improperly it could unseat itself, they're pressed in so they would have had to really screw up.
waiting to see what the valve lash measures out to.
I have a feeling you have a bucket or two way out of spec.
if the sound is increasing with revs, and is coming from the head, it only makes sense that it's tappet noise.
did they replace buckets to set the lash or just tip the valves?
Old 11-29-2012, 01:24 PM   #47
Turn in Concepts
Member#: 93646
Many Track Records
Why I'm curious is because of the last case of failed tensioner we had here. Built a motor for the customer, with brand new timing equipment and 2000 miles later (almost on the dot) it started to make a similar noise. It was the tensioner that had de-tensioned.
Old 11-29-2012, 01:26 PM   #48
Turn in Concepts
Member#: 93646
Many Track Records
Ah - interesting. Keep all of us up to date. I for one am curious as to what it is.
Old 11-29-2012, 03:23 PM   #49
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Said it before say it again "Stick with the OEM belt tensor's" On any car. I've seen many gates failures in various applications not just Subaru's also many worked great. The tensor isn't made by gates btw. Take it from someone who work's on all makes and models. You will see less failures with OEM part's same goes for throw out bearing's.
If you put a scope on the valve cover. Then you narrowed down your issue all part of the diagnostic procedure my friend. I have my money on AVCS solenoid. BTW the electrical scopes are nice you can lower the volume
Old 11-29-2012, 03:39 PM   #50
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^+2
tensioner, and oil pump I always go OEM. Learned that from my DSM days
