Old 11-27-2012, 12:11 AM   #1
ilganeli
Member#: 289660
2011 WRX Hatch
Default Hose clamps for Headers?
I am purchasing a GTSpec EL Header, I wanted to thermal wrap it but have had trouble finding appropriate hose clamps. Does anyone have a suggestion as to where I can get an appropriately sized set of these or suggest alternatives?
Thanks .
ilganeli is offline   Reply With Quote
Old 11-27-2012, 12:53 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Go to your local hardware store and buy some stainless steel hose clamps from the plumbing section the 1.5" to 2.5" variety are what I have used with great success. If you don't have a decent local hardware store, a Lowes, Home Depot, or Harbor Freight can probably suffice.
Or you can use SS lockwire, available from Pegasus Racing supply. It works just as well if you tie it off properly.
speedyHAM is offline   Reply With Quote
Old 11-27-2012, 09:04 AM   #3
ilganeli
Member#: 289660
2011 WRX Hatch
Did you wrap each pipe individually? The one photo of a wrapped gtspec el header I could find is this one:
It looks like I'd need something larger than a 2.5" hose clamp around the wider sections. Is it better to single wrap everything?
Old 11-27-2012, 02:28 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
HD/Lowe's have SS clamps up to 5" or 6" or maybe even bigger. Go look in the HVAC ducting section, they have a bunch of sizes.
Patrick Olsen is online now   Reply With Quote
Old 11-27-2012, 03:44 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Stainless tie wraps are what you want, unless you want them to be easily removable. In which case, worm drive clamps are available nearly anywhere in full stainless construction that will work easily.
Jay
