Old 12-14-2012, 12:27 PM   #51
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Originally Posted by NW2TONE View Post
ohhhhhh shiiiiittttt soonnnnnn..... Now i know who you are on the forum lol
This is Dave btw lol
mps
I didnt know who your were and I was reading the shortblock desription and turbo **** and was like that sounds like brians build lol.
our local machine shop does the re thread of the larger studs. Benson just does the sleeves and o ringing and the rest of the case work like, bore, hone, deck, mainline hone.
Haha, hi!
Oh okay, my mistake.
Yeah... I still have a lot of work to do, and it would be nice of the snow/salt would stay away so I can do my break-in without feeling bad when the engine arrives.
RexFTW is offline   Reply With Quote
Old 12-14-2012, 02:37 PM   #52
Maxwell Power
Member#: 190729
Originally Posted by project_skyline View Post
Also I wouldn't run anything less then 9:1 compression no matter what but that's just me.
It is 9:1. Not sure why he put 8.3:1
Also, DO NOT run Five0 1400's. You will regret it. Any educated, reputable tuner won't tune it with those injectors either. They are horrid injectors that should have never been released to the public. You will fail the motor with those, I promise.
Maxwell Power is offline   Reply With Quote
Old 12-14-2012, 02:47 PM   #53
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Dom have you run into problems with their 1200 or 1600?
renosubby is offline   Reply With Quote
Old 12-14-2012, 02:49 PM   #54
Maxwell Power
Member#: 190729
I don't even bother tuning with them. I've seen the response curves for the injectors. Only a fool would waste his time with them.
Old 12-14-2012, 03:04 PM   #55
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Sounds good to me, I have have only tuned them with aeromotive pumps that keep failing and causing injector problems on e85 so I was planning to give them another go in case my annoyance with them was due to the pump problems. Guess I won't bother even trying them then.
My invoice says 4.030" bore 8.3:1 on the shortblock specs - I figured the 8.3:1 was the compression ratio, did I read it wrong or did the invoice get a typo?
Old 12-14-2012, 03:15 PM   #56
Maxwell Power
Member#: 190729
That was the original intent, then you and I spoke more about your setup and the size of your turbo. Increasing the ratio was going to help quite a bit.
Weldon Pumps. Aeromotive pumps have never been reliable. The A1000 for example is a 5 min of operation drag race pump... or at least it should be because they overheat very easily and quit.
Old 12-14-2012, 03:20 PM   #57
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Ahh okay, it must have just never stuck then.
What Weldon would you recommend for e98? From a quick search I might as well just do a 2345-A so I won't ever have to worry about it, what do you think?
Old 12-14-2012, 03:48 PM   #58
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Yep. burned through 3 of the A1000's in that white POS that's in your shop.
it has a Magnafuel now, been working great since install last year.
Z0rr0 is offline   Reply With Quote
Old 12-14-2012, 04:04 PM   #59
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
That was the original plan as that was in the surge tank that I want, but I'd rather do it right the first time if a Weldon is the better choice (I don't know either way just yet, I need to research more).
Old 12-14-2012, 06:04 PM   #60
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
well if Dom recommended the bigger studs in the middle he has a good reason for it---Dom knows what he is doing no doubt.
john 1badSTI is offline   Reply With Quote
Old 12-14-2012, 06:51 PM   #61
Maxwell Power
Member#: 190729
Quick analysis of the firing order shows us that the center studs do double duty.
There are 4 bolts per cylinder, which is a crap design as many V8 and I6 guys can attest to. The best engines have 6 or more per cylinder.
Anyway, 4 per cylinder at the far corners. Since the cylinders on each side fire one right after the other (1,3,2,4). This means the center bolts get two rapid events one after the other.
Ever noticed how the OEM center bolts have a higher torque spec even though they use the same bolts?
Old 12-14-2012, 07:02 PM   #62
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Excellent post. Never thought about it like that.
stretchedk7 is offline   Reply With Quote
Old 12-14-2012, 09:22 PM   #63
Maxwell Power
Member#: 190729
thank you. We think of all kinds of weird **** here.
Old 12-14-2012, 09:48 PM   #64
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
lol ^. it actually makes really good sense though obviously. bet thats exactly the reason the center 2 head bolts go that last step.
Old 12-20-2012, 10:05 PM   #65
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Got my exhaust bits the other day from fobiawrx and they look amazing!
Also looks like my engine ships in the morning!
Old 12-20-2012, 10:48 PM   #66
draco159
Member#: 204121
2005 WRX Wagon
CGM
Awesome! Can't wait to see pics.
draco159 is offline   Reply With Quote
Old 12-30-2012, 01:56 PM   #67
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
Any updates?
KillerRabbit is offline   Reply With Quote
Old 12-30-2012, 02:49 PM   #68
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
^^ I concur
Update pls
mtcs is offline   Reply With Quote
Old 12-30-2012, 10:07 PM   #69
Maxwell Power
Member#: 190729
They picked up his engine last week. He should see it in a couple days.
Old 12-31-2012, 11:29 PM   #70
WhatTurboLag?
Member#: 243992
2006 WRX TR
I saw some stuff on Instagram from people.
Dual fuel injector tgv's mmmmm
WhatTurboLag? is offline   Reply With Quote
Old 01-03-2013, 02:07 PM   #71
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
I got a message and a photo texted to me saying my engine arrived at 6* today. How the hell am I supposed to work the rest of the day now?!
Old 01-03-2013, 02:16 PM   #72
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
No photo, no proof.
Zee Biker is online now   Reply With Quote
Old 01-03-2013, 02:17 PM   #73
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Originally Posted by Zee Biker View Post
No photo, no proof.
I have the photos on my phone, that is all that matters to me. I will take more when I get to the shop this afternoon but probably nothing super pretty. The heads were mounted to the block before it got shipped from MPS so I can't show pretty sleeves or pistons or o-rings.
Old 01-03-2013, 02:22 PM   #74
Maxwell Power
Member#: 190729
you already have those pictures in your thread anyway!
I can't imagine it's going to be "pretty" as the heads were used and the block is seasoned. The dyno sheet should be somewhat pretty.
Old 01-03-2013, 02:36 PM   #75
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Yeah, I do, but it is kind of different, or at least in my head it is, when you see it personally. I can pet it gently and give it a name...
Yeah, it is going to be a bit before everything is ready for rape tune but at least driving it again is going to be a good time. Once it is go time though... I think it is going to be scary. Going from a car that traps 130ish to... whatever the hell this thing is going to do is going to be a more than trivial jump.
