Old 11-28-2012, 01:46 PM   #1
Cocoa Beach Bum
Member#: 17355
Default New Option for EJ Engines from King Engine Bearings
I see quite a few posts about engine bearing failures so I thought the article at http://www.autoserviceworld.com/news...es/1001890435/ might be of interest. According to the article:
King's new bearings are specifically engineered to solve premature bearing failure caused by low oil pressure or oil starvation that has plagued the high output Subaru EJ series boxer engines (EJ15, EJ16, EJ18, EJ20, EJ22, EJ25).
"King conducted extensive research into the unique oiling circumstances of the Subaru EJ series engines," explained Ron Sledge, King's performance and technical manager. "What resulted is a completely re-engineered main bearing set that eliminates oil leakage and increases oil flow to number two and number three rod bearings."
To improve oil flow, oil slots on the King XPG bearings are replaced with oil holes for better oil distribution in the groove and more consistent oil flow. Fully grooved number three main bearings enable 360 oiling to number two and number three rod bearings. King XPG bearings feature a unique lug design that eliminates the conventional lug recess so no oil escapes and full oil pressure is maintained. In addition, narrowed bearing lengths help eliminate fillet ride on high-radius cranks.
With enhanced tri-metal copper lead construction with nickel barrier and SecureBond adhesion, King XPG bearings have a 20 percent higher load capacity and better resist surface fatigue.
King XPG Bearings are available for Subaru EJ series boxer engine applications, including rod bearings (CR4125XPG - 52mm journal) and main bearings (MB5382XPG - flange in #5 position). These new XPG parts are available in STDX (.001” extra clearance), STD, .026, 0.25 and 0.5.
Their website at http://www.kingbearings.com has a Technical Info section which provides a lot of info about engine bearings in general.
Cocoa Beach Bum is offline   Reply With Quote
Old 11-28-2012, 07:25 PM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Seems like more of an issue on the 2.0L motors- but even so i'm not sure it's necessarily the design of the bearing that causes the failure.
mechatricity is offline   Reply With Quote
Old 11-28-2012, 09:09 PM   #3
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Pure marketing bull****.
i_c_the_light is offline   Reply With Quote
Old 11-29-2012, 12:08 AM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I heard about King Bearings doing something like this 6 months ago or more...There was a thread about it and I think I saw it floating around recently...
drewvdw is offline   Reply With Quote
Old 11-29-2012, 12:50 AM   #5
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
The crank is the issue, oil will always take the path of least resistance. The OEM EJ crank is not designed for high revs.
not the best of designs especially when you're trying to spin to 9k and make 400+WHP
It also depends on clearances, knock, ect.
the two rods being supplied by one main doesn't help
Flat 4 Motorsport is offline   Reply With Quote
Old 11-29-2012, 01:10 PM   #6
xdrian
Member#: 104200
000 WHP BUGEYE
Street Proven Performance
We have a set here that we are going to be using in our 800hp ej257 that revs to 8500rpm.
xdrian is offline   Reply With Quote
Old 11-30-2012, 02:33 AM   #7
Murphdog
Member#: 75414
2004 STi
Its the Blue one
I run ACLs on mine and am doing a bigger build that will rev to 8500. Anyone have data on why these would outperform the ACLs.
Murphdog is offline   Reply With Quote
Old 11-30-2012, 11:22 AM   #8
3MI Racing
Member#: 200987
I had spoken with Ron Sledge for a good deal of time at PRI last year. I was thoroughly unimpressed, especially after sitting in his seminar (where he spouted rules of thumb) however I did drop a load of issues that we have and why.
I also made some suggestions that I wanted to test for the EJ, including a full grove #3 main and trying a 3/4 or maybe even a 1/2 groove for the #1 and #5.
I guess he got someone to test it with!...or it's just marketing BS and it isn't tested yet
-Micah
P.S. IIRC Matt Ball pretty much gave him the same ear full that I did.
3MI Racing is offline   Reply With Quote
Old 12-01-2012, 10:27 AM   #9
GideonZ
Member#: 339388
Hi , I see some Questions about XPG bearings
THIS is the story about it:
We made research and found that Most of Bearing failure in Subaru EJ engines appear on CR #2 and #3.
We received few failed bearings for inspection and found similar symptoms of Oil starvation.
The question is why only CR#2 ,#3 and not CR #1 CR#4
Well, CR#1 get oil from MB#1, CR#4 get from MB#5, CR #2,#3 both get from MB #3
My conclusion was :the ability of single main (#3) to feed oil for 2 CR is limited
therefore, Oil In Feed from Block into MB#3
and
Oil Out Feed from MB#3 into CR#2,3 must improved.
In feed (to MB#3) can improved by adding more oil holes or changing oil to Slot
Out feed (to CR #2,3) can improved by changing oil grove to be folly 360 instead of partially 250 degrees.
explanation :In 250 the oil delivery from MB to CR are turned on-off-on-off while crank rotate ~66% on 33% off
In 360 degree it is 100% on
Oil Groove could not modify to be 360 without changing the inside geometry of the Locating Lug.
The oil will leak from oil Groove out trough the inside punched area of the Locating lug
So this is all about it
confused??
gideon
GideonZ is offline   Reply With Quote
Old 12-01-2012, 10:32 AM   #10
mboulton
Member#: 174433
Is this a joke Gideon?
Okay I will bite....
so why 360 oiling at journals 1 and 5? iI understand the theoretical benefit of #3.
How about sharing some data that a million dollar corp should have prior to little ol me buying unproven ideas on a $150 bearing set going into $20k engine rebuild?
mboulton is offline   Reply With Quote
Old 12-01-2012, 10:38 AM   #11
mboulton
Member#: 174433
Why don't you start on official KING bearing thread so everything stays together?
Old 12-01-2012, 10:39 AM   #12
mboulton
Member#: 174433
yi..... i purchased a full set normal and oversized. My normal ones are your redesign (which I never asked for) and the oversized are the previous design. Makes it more difficult to swap bearings to get proper tolerances.
feel a bit cheated to be honest.
Old 12-02-2012, 08:58 PM   #13
3MI Racing
Member#: 200987
I see that Mel is going for the jugular
Old 12-04-2012, 05:17 PM   #14
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
If some bearing company really wanted to listen and make some $$ they would make some oversized main bearings so one could align hone without decking the halves but what do I know
Crystal_Imprezav is offline   Reply With Quote
Old 12-04-2012, 09:13 PM   #15
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Agreed!!
aboothman is offline   Reply With Quote
Old 12-05-2012, 08:25 PM   #16
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
You get the cookie!
KillerRabbit is online now   Reply With Quote
Old 12-10-2012, 11:22 PM   #17
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
ok folks - I talked to the King guy at IMIS. I didn't beat around the bush at all. In fact, I was likely rather aggressively unfriendly.
Now, this is what I was told. Take it as you will.
1) The tang. They found that with the old stamped tang oil was getting behind the bearing though the cut and displacing the bearing into the crank. The new tang is upset as opposed to cut/stamped to eliminate the cut for oil to get into.
2) The feed holes #3 are now oval to keep from blocking the feed from the block.
3) the "trough" is now deeper to hold more oil
4) the holes for #5 are chamfered on the crank face side to hold more oil
Old 12-11-2012, 05:27 PM   #18
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
My thoughts:
Didn't see anything chamfered on #5 from my recollection but I will double check.
The tang makes a bit of sense. The Mahle bearings did the same thing a long time ago.
http://gruppe-s.blogspot.com/2010/07...ver-mahle.html
With the expanded U holes and deeper grooves, it makes me want to run a bigger oil pump.
Old 12-11-2012, 08:43 PM   #19
Matty_STi
Member#: 333602
2012 STi
What's your take on this then? Many here would trust your opinion. Would you go with these or recommend we look elsewhere?
Matt
Matty_STi is offline   Reply With Quote
Old 12-11-2012, 09:13 PM   #20
Turn in Concepts
Member#: 93646
Many Track Records
Matt
Honestly. I'm not sure. I'm only repeating what I was told, but at the same time I'm not too interested in running them on a customer build just to see what happens. I too would need validation that the changes add up to better performance than what is currently out there.
Old 12-11-2012, 10:00 PM   #21
GideonZ
Member#: 339388
Hey, please let me corect yuo
1) the Tang:
problem we found is in inside surface of the tang (inside of the bearing),
in the old Pahse1 engines, oil groove was 360 degs, the inside punched tang was very near to oil Groove, oil leaked from oil groove through tang and reduced oil pressure , to prevent oil leaks, Subaru engineers decided in phase2 engines to modified the oil groove , from 360 degs to be ~250 degs
that modification terminated the oil leak, but with price of oil starvation in CR 2,3.
we reverted the changed in the oil groove to be 360 again, and to prevent leaks we modified the lug.
Gideon Saslavsky
Old 12-11-2012, 10:18 PM   #22
Turn in Concepts
Member#: 93646
Many Track Records
1) the Tang:
Gideon Saslavsky
Ah! Awesome! Thank you.
Old 12-12-2012, 01:47 PM   #23
mboulton
Member#: 174433
I have been in contact with King Bearings, and they are sending me the bearings that I initially requested. It appears that they even listen to the no-name little guys plugging away in their garages.
mel
Old 12-12-2012, 02:56 PM   #24
3MI Racing
Member#: 200987
But those changes won't change the oil leakage during operation. It just ensures that it goes to the right place instead of out to the chamfer.
I think I'll probably toss a set in my personal destroker for my bugeye. Pistons have a due date of 12/27.
Last edited by 3MI Racing; 12-12-2012 at 03:02 PM. Reason: update on delivery of my pistons!
Old 12-12-2012, 03:02 PM   #25
mboulton
Member#: 174433
I am still not sold on the King theory. I would rather correct the oiling strategy with a proper crank. If I use these new XPG bearings, I will share any results good or bad.
