Old 12-07-2012, 01:23 PM   #26
luciferMotorCade
Member#: 253611
2004 GeNOME
hey TAKE YOUR CAR TO A MECHANIC WHO CHARGES.
pg 2 PWND
luciferMotorCade is offline   Reply With Quote
Old 12-07-2012, 02:41 PM   #27
Stangy
Member#: 329676
1999 GC8 R-STI
Originally Posted by luciferMotorCade View Post
this is true. fxt05 and I have had more problems with our subies than my 28yr old vw. only issue was the cold start injector fuel line had a small hole in it. never left me stranded like our subies.
you have any build threads on your cars?
Somwhere lol
Stangy is offline   Reply With Quote
Old 12-07-2012, 08:47 PM   #28
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Changed the plugs and cleaned the maf but when I was putting everything back together I broke a nipple off part of the intake. Of course the dealer wasn't able to find this part so looks like jb weld will be the temp fix till I can get it running then I'll be upgrading to the apexi intake.
Tomorrow I'll be putting it back together to see if the plugs helped. Then I'll be checking the maf. Then changing the fuel filter again to see if that magically helps, if not I'll be checking the cat to see if its plugged.
Anyone have any other suggestions of what my problem might be?
How can I test the COP's to make sure they're good?
fxt05 is offline   Reply With Quote
Old 12-07-2012, 11:58 PM   #29
Stangy
Member#: 329676
1999 GC8 R-STI
Plugs. Injectors
Old 12-08-2012, 04:50 PM   #30
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Changed the plugs, cleaned the maf. Ran great for a couple miles. It starts stuttering when I cruise at a steady speed. if I push in the clutch and rev it stops for a little bit.
I think I'll try cleaning the iacv. Does it sound like it may be this?
Edit: it also happens after idling at a light for a little while.
Old 02-22-2013, 06:08 PM   #31
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
I think I finally fixed it. Cleaning the maf did not help but changing it sure seems to have. These things are expensive new but its fixed.
Old 02-27-2013, 06:32 PM   #32
V62.5rssti
Member#: 348501
Yep they are pricey
V62.5rssti is offline   Reply With Quote
