Old 11-29-2012, 10:12 AM   #1
DSM Goat
Member#: 313071
1998 Forester L
Default Boosting Late but Strong
EJ20T
VF48
TGV deletes
One step colder plugs
EL headers
Invidia Up Pipe
Turbo XS TB exhaust w/o cats
SAMCO inlet w/AEM short ram
Larger-than-stock TMIC
SAMCO intercooler hoses
E85-converted (1000cc ID injectors, 255 Walbro, and tune in progress)
Stock EBC
My tuner is telling me that boost is coming on late and that he, "can't control it." He has, "turned the boost all the way up." He said to expect between 20-25 lbs of boost @ redline. And that's exactly what I get.
However, boost doesn't start until around 2800-3000 RPM. But once boost builds, it boosts all the way to 22-25 lbs @ redline.
So I need to figure out why I'm boosting late before my tuner can continue tuning.
I've read several threads on this and most point to a boost leak as the most likely culprit. But if I'm boosting all the way to 22-25 lbs (not losing boost), is boost leak still the most likely cause of my late boost?
I appreciate your guys thought on this.
Thanks.
DSM Goat is offline   Reply With Quote
Old 11-29-2012, 10:38 AM   #2
Stangy
Member#: 329676
1999 GC8 R-STI
So you dont get power as it builds quickly..then bam 25psi?
Stangy is offline   Reply With Quote
Old 11-29-2012, 10:56 AM   #3
DSM Goat
Member#: 313071
1998 Forester L
No boost until ~ 3000 RPM, then boost kicks in and builds to 22-25 lbs by the time I'm at redline.
Old 11-29-2012, 10:57 AM   #4
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
So, you have 0psi until 2800-3000?
What do you mean by boost doesn't start until 2800-3000?
What gear are you testing this in?
Can you post a log?
tachrev is offline   Reply With Quote
Old 11-29-2012, 11:02 AM   #5
DSM Goat
Member#: 313071
1998 Forester L
Actually - (vacuum) psi until 2800-3000.
So, what I mean is that yes, NO boost ~ 3000 RPM. At that point boost begins to build until I'm at 22-25 lbs @ redline in 3rd gear.
My tuner is having me do AP logs and has instructed me to do third gear @ 2000 RPM WOT pulls to redline.
Old 11-29-2012, 11:08 AM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Wait to see what the tuner says.
Old 11-29-2012, 11:10 AM   #7
DSM Goat
Member#: 313071
1998 Forester L
The tuner is telling me I need to figure out why I'm boosting late before he can complete my tune.
Old 11-29-2012, 11:54 AM   #8
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Try a 3-port electronic boost solenoid?
Subian is offline   Reply With Quote
Old 11-29-2012, 12:00 PM   #9
JUICEB0X
Member#: 243090
Maybe someone swapped a bigger turbo in without you knowing.
JUICEB0X is offline   Reply With Quote
Old 11-29-2012, 12:09 PM   #10
DSM Goat
Member#: 313071
1998 Forester L
I put the VF48 on myself, along with all the other work. I just don't know how to tune.
Old 11-29-2012, 12:21 PM   #11
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You say boost builds to redline, does that mean you aren't reaching target boost until redline? At what RPM are you achieving max boost?
It sounds like a boost leak or a pre turbo exhaust leak. They both won't always prevent you from hitting your boost target but they will make the turbo work harder to do so and boost response will be slower.
Old 11-29-2012, 12:25 PM   #12
NoGraffix
Member#: 276209
I am Rub
Function>Form
Sounds to me like there is an issue with your BCS. Also on a vf48 there is absolutely no way you can hold 25psi to redline it's completely out of the turbos efficency range, at the point you're doing much more harm then good. If you don't mind me asking who is the tuner? A log will be the best way to really analyse your issue, but I'd also get a boost leak tester (simple search of this and you can do it for around $30 and a trip to lowes).
NoGraffix is offline   Reply With Quote
Old 11-29-2012, 01:37 PM   #13
DSM Goat
Member#: 313071
1998 Forester L
I went home and looked at my logs...I'm hitting max boost (19.7 lbs) @ 5300 RPM. I was trying to recreate from memory, but I was off a bit - not 25lbs, but 19.7 lbs.
And I am starting to boost @ 2100 RPM (2 lbs). But I don't get into double digit boost (10.4 lbs) until ~ 3000 RPM.
Sorry for the confusion. I can post my logs when I get off work.
Old 11-29-2012, 02:43 PM   #14
Stangy
Member#: 329676
1999 GC8 R-STI
boost or exhaust leak. My 2 cents
Old 11-29-2012, 02:48 PM   #15
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
What do you have between the motor and the turbo on the exhaust side? Boost starting at 2100 rpm does not sound late to me.
guroove is offline   Reply With Quote
Old 11-29-2012, 02:59 PM   #16
DSM Goat
Member#: 313071
1998 Forester L
EL headers and an Invidia Up-Pipe.
Old 11-29-2012, 03:20 PM   #17
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
And are they leaking at any of the 4 flanges? and is the EGT plug in the uppipe?
2gnt2wrx is online now   Reply With Quote
Old 11-29-2012, 03:28 PM   #18
DSM Goat
Member#: 313071
1998 Forester L
The plug's in the up-pipe. But I will make sure the flanges are tight. Thanks for the advice!
Old 11-29-2012, 04:11 PM   #19
Stangy
Member#: 329676
1999 GC8 R-STI
Building boost at 2100 is normal, 10.4 at 3000rpm is not bad, your problem is from 3000rpm-6500rpm. You should hit 19.7 at 3800. I assume you are not getting the additional 9.3psi from 3000rpm-4000rpm are you?
Its sounds as simple as a leak. Check exhuast connections.
Old 11-29-2012, 04:44 PM   #20
DSM Goat
Member#: 313071
1998 Forester L
@3800 = 15 lbs.
@3000 = 12.2 lbs
@4000 = 15.5 lbs
Old 11-29-2012, 05:04 PM   #21
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Maybe it's me but from what i'm reading it seems as if boost is coming on normal.
Mike
GrimmSpeed is offline   Reply With Quote
Old 11-29-2012, 05:10 PM   #22
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
Mike
Yeah doesn't sound horrible to me for a 2.0L car. You probably can get it to spool quicker but its could just be in the tuning (timing). Make sure you tell your tuner its a 2.0L and not a 2.5L motor!
FXTSPORTS08 is offline   Reply With Quote
Old 11-29-2012, 05:23 PM   #23
ogboot
Member#: 170906
psm
Mike
Ditto. VF48 on a 2.0L
Hit this guy up for an EBCS if you want it to spool faster.
Disclaimer: will require retune.
ogboot is offline   Reply With Quote
Old 11-29-2012, 06:16 PM   #24
DSM Goat
Member#: 313071
1998 Forester L
Here's a log of a WOT 2k to redline pull. Let me know what you think.
https://docs.google.com/open?id=0B6Y...DE3ci1jNWJmZ1k
Old 11-29-2012, 06:27 PM   #25
wrxlaunch
Member#: 181298
Link does not work
wrxlaunch is offline   Reply With Quote
