Old 11-29-2012, 07:31 PM   #26
DSM Goat
Member#: 313071
1998 Forester L
Should work now.
DSM Goat is offline   Reply With Quote
Old 11-29-2012, 07:57 PM   #27
wrxlaunch
Member#: 181298
Nope.
wrxlaunch is online now   Reply With Quote
Old 11-29-2012, 08:07 PM   #28
DSM Goat
Member#: 313071
1998 Forester L
What happens when you click it? I just tried it myself and it's working fine.
Old 11-29-2012, 08:33 PM   #29
wrxlaunch
Member#: 181298
Error... check ur pm
Old 11-29-2012, 08:36 PM   #30
DSM Goat
Member#: 313071
1998 Forester L
Old 11-29-2012, 10:09 PM   #31
wrxlaunch
Member#: 181298
Can u do another log and include target boost To what u already have....3rd and 4th gear pulls from 2500rpm
Old 11-30-2012, 08:03 AM   #32
DSM Goat
Member#: 313071
1998 Forester L
Sure. I'll do that this weekend. Any thoughts on the log attached?
Old 11-30-2012, 08:12 AM   #33
wrxlaunch
Member#: 181298
Wld like to see what ur target is... to see how far off u are and possibly what's going on
Old 11-30-2012, 11:11 AM   #34
DSM Goat
Member#: 313071
1998 Forester L
Anyone else have any thoughts on the log attached? I would appreciate your input.
Thanks.
Old 11-30-2012, 11:53 AM   #35
Extreme Turbo Systems
Member#: 194655
08 STI
Did you ever boost leak test it? That is the first thing I look for when car is spooling slow.
Extreme Turbo Systems is offline   Reply With Quote
Old 11-30-2012, 11:58 AM   #36
DSM Goat
Member#: 313071
1998 Forester L
No, I plan on doing that this weekend. Just looking for your guys' impression of the log. Like, does the log confirm that it's boosting late/slow, or is what the log is showing typical/acceptable/normal boosting?
Thanks.
Old 11-30-2012, 12:43 PM   #37
Stangy
Member#: 329676
1999 GC8 R-STI
Thanks.
I think its perfectly normal-slightly slow. Is your tuner reputable?
Stangy is offline   Reply With Quote
Old 11-30-2012, 12:44 PM   #38
DSM Goat
Member#: 313071
1998 Forester L
He is pretty well-known.
Old 11-30-2012, 02:43 PM   #39
Stangy
Member#: 329676
1999 GC8 R-STI
Technically:
IHI VF43
(435cfm, 250-325whp, Bolt-On)
The IHI VF43 comes stock on the 2007 STi. It has almost identical features of the VF39 with a thrust bearing and a P18 exhaust housing, but the wastegate opening is larger to relieve boost creep issues. . It can be found on both base STI's and STI Limited's. The VF43 utilizes a thrust bearing design and the P18 exhaust housing. The difference between the VF43 and the VF39 used previously on STI's is the size of the wastegate. The VF43 has a larger wastegate designed to reduce boost creep issues.
Expect to achieve full boost with the proper mods and a quality tune between 3000-3500rpms. 2002-2005 WRX owners will need fuel upgrades for this turbocharger and proper engine management is highly recommended for all vehicles that utilize this turbo aftermarket.
Old 11-30-2012, 02:56 PM   #40
DSM Goat
Member#: 313071
1998 Forester L
I'm running a VF48.
Old 12-02-2012, 12:19 AM   #41
DSM Goat
Member#: 313071
1998 Forester L
Boost leak @ intercooler.
Old 12-02-2012, 12:53 AM   #42
The_ManCub
Member#: 197010
2006 WRX vf39/ewg
CGM **Drunkmann tuned**
BPV gasket, Y pipe gasket? Or..
The_ManCub is offline   Reply With Quote
Old 12-03-2012, 08:02 AM   #43
DSM Goat
Member#: 313071
1998 Forester L
Y-pipe gasket.
Old 12-03-2012, 08:35 AM   #44
shano
Member#: 223839
2004 WRX
Java black
leak!!!! now you should feel the powaaaaa
shano is offline   Reply With Quote
Old 12-03-2012, 02:30 PM   #45
Stangy
Member#: 329676
1999 GC8 R-STI
beauty!
